ducko
Trouble booting from NVMe
Sun Feb 18, 2024 5:04 pm
Hi everyone, I am in need of your help. I am trying to boot my Raspberry Pi 4 using an NVMe SSD inside an Argon One case. I updated to the latest firmware and flashed the latest OS to the NVMe drive. When I boot the Pi, I get the colored square splash screen, then one line of code, then the HDMI kicks out. Here is a video of it happening. Any ideas on what might be going on? Thanks in advance!
https://imgur.com/a/0osqGbz
embeddedbarsha
Re: Trouble booting from NVMe
Sun Feb 18, 2024 5:42 pm
Make sure you're using a sufficient power supply for your Raspberry Pi 4.
framp
Sat Feb 24, 2024 6:49 pm
I also own an Argon1 case with a M2 SSD and everything works fine.
I know - that doesn't help you right now but did you try to boot from a SD card just to make sure your issue is related to the SSD ?
"Really, I'm not out to destroy Microsoft. That will just be a completely unintentional side effect." Linus Torvalds, 28.9.2003
Have you already backed up your Raspberries :?: For me raspiBackup creates them unattended every week :D
thagrol
Sat Feb 24, 2024 9:21 pm
AIUI there are two version of the Argon 1 M.2 case for the 4B. One supports SATA M.2 drives the other NVMe. They are not cross compatible so drive and case must match.
