Cbaymac
Re: RPi Cam Web Interface
Sun Mar 23, 2014 10:21 am
Great use of motion that really works. Can you explain how to store captured videos on a FAT32 USB drive? Thanks,
silvanmelchior
Sun Mar 23, 2014 10:01 pm
Update: Version 4.0
After many hours of programming it's now possible that the startup-settings of the camera and interface can be configured over the config-file /etc/raspimjpeg. Additionally are may new settings available, including video and image resolution+framerate, shutter speed, image effects, ...
To update, run the following commands:
git pull origin master
./RPi_Cam_Web_Interface_Installer.sh install
./RPi_Cam_Web_Interface_Installer.sh start
The default config-file /etc/raspimjpeg looks like this:
#  Config File for raspimjpeg  #
# Syntax: "Command Param", no spaces before/after line allowed
# Camera Options
sharpness 0
contrast 0
brightness 50
saturation 0
iso 0
metering_mode average
video_stabilisation false
exposure_compensation 0
exposure_mode auto
white_balance auto
image_effect none
colour_effect_en false
colour_effect_u 128
colour_effect_v 128
rotation 0
hflip false
vflip false
sensor_region_x 0
sensor_region_y 0
sensor_region_w 65536
sensor_region_h 65536
shutter_speed 0
raw_layer false
# Preview Options
# fps_preview = video_fps (below) / divider
width 512
quality 25
divider 1
# Video Options
video_width 1920
video_height 1080
video_fps 25
video_bitrate 17000000
MP4Box true
MP4Box_fps 25
# Image Options
image_width 2592
image_height 1944
image_quality 85
# File Locations
# preview path: add %d for number
# image+video path: add %d for number, year, month, day, hour, minute, second
preview_path /dev/shm/mjpeg/cam.jpg
image_path /var/www/media/image_%04d_%04d%02d%02d_%02d%02d%02d.jpg
video_path /var/www/media/video_%04d_%04d%02d%02d_%02d%02d%02d.mp4
status_file /var/www/status_mjpeg.txt
control_file /var/www/FIFO
# Autostart
# autostart: standard/idle
# motion detection can only be true if autostart is standard
autostart standard
motion_detection false
Try it out and please let me know if it works for you
@Questionario: I bought the Pi-Pan (http://openelectrons.com/index.php?modu ... PAGE_id=15), because it seems pretty cool. As soon as I get it and find the time, I'm going to program a pan/tilt-control on the website incl. the ability to turn on/off the light.
slabua
Sun Mar 23, 2014 10:40 pm
@silvanmelchior I just updated it and I get this error when trying to start it:
*** glibc detected *** raspimjpeg: double free or corruption (out): 0x011bb5b0 ***
also, everytime I try to run it and I get the above error, a .part file is created, and tree shows them as:
tree *part
\26672361210\26672361210 [error opening dir]
\26672362210\26672362210\22160750\22160750\22160011\22160025\22160041\22160055\22160071ɉ\26672361210\26672361210 [error opening dir]
0 directories, 0 files
Not sure what's going on, am I missing some newly required libs maybe?
UPDATE: Sorry, my bad! Since I'm using lighttpd, I usually do the install procedure of copying files by hand, and I misplaced the /etc/raspimjpeg file to /etc/raspimjpeg/raspimjpeg, my apologies. It's working fine now : )
Salvatore La Bua - www.slblabs.com
DICGIM - University of Palermo, Italy
0lly
Mon Mar 24, 2014 4:46 pm
Motions detection not working (no videorecord) anymor.
How i can back to previous Version ?
slabua
Mon Mar 24, 2014 5:04 pm
0lly wrote:Motions detection not working (no videorecord) anymor.
I can confirm motion is not working anymore for me either.
The problem lies in the image passed to motion that, for some reason, is now all grey (unable to open video device), but if I paste the neturl in the browser it works fine, I still don't get why then motion would read a grey image.
Screenshot from 2014-03-24 17.59.32 (copy).png (24.51 KiB) Viewed 13396 times
I also noticed that for at least some resolutions, like 640*480 and 1280*720 the ones I tested, doing a timelapse from the video settings (01 fps boxed to 30) yields to a black capture. Anyone else experiencing this too?
leol
Mon Mar 24, 2014 5:26 pm
preview does not alter when you change the Preview FOV
Leo
0lly
Mon Mar 24, 2014 5:37 pm
if i start motion manualy i get
pi@rpi / $ motion /etc/motion/motion.conf
[7100232] Processing thread 0 - config file /etc/motion/motion.conf
[7100232] Motion 3.2.12 Started
[7100232] ffmpeg LIBAVCODEC_BUILD 3482368 LIBAVFORMAT_BUILD 3478785
[0] Thread 1 is from /etc/motion/motion.conf
[1] Thread 1 started
[1] netcam image height (385) is not modulo 16
[1] Could not fetch initial image from camera
slabua
Mon Mar 24, 2014 7:19 pm
In version 4.1 motion is working again, thanks @silvanmelchior :)
How about the timelapse issue?
0lly
Mon Mar 24, 2014 7:22 pm
works also for me,thanks ;)
silvanmelchior
Mon Mar 24, 2014 7:42 pm
Update: 4.1
I found the bug, motion detection should work now for different resolutions
If it still doesn't work, empty the cache of your browser. Still no success? Ensure you are running the latest soft- and firmware:
sudo apt-get update
sudo apt-get dist-upgrade
sudo rpi-update
sudo reboot
If this still doesn't help, you might have an incompatible setup and so you might need to reinstall your RPi with a fresh Raspbian etc as explained in my first post step by step. I tested it with a second RPi and it worked.
@slabua: You're welcome. The bug with the black timelapse-capture seems to be a driver-problem, because raspivid -w 640 -w 480 -fps 1 -o test.h264 give's me a black preview, too. Anybody else the same thing?
@leol: I don't have this bug, maybe my instructions above help you to fix it. Or does anybody else have the same problem (preview doesn't change from 16:9 to 4:3 if you change the resolution from std FOV to full FOV for example?)
jarrah31
Mon Mar 24, 2014 7:58 pm
silvanmelchior wrote:Update: Version 4.0
Really great work, thank you very much for putting the time and effort into improving this fantastic application!
0lly
Mon Mar 24, 2014 8:08 pm
silvanmelchior wrote:The bug with the black timelapse-capture seems to be a driver-problem, because raspivid -w 640 -w 480 -fps 1 -o test.h264 give's me a black preview, too. Anybody else the same thing?
confirmed,the test.h264 is only 879 bytes.
Trixster
Mon Mar 24, 2014 8:18 pm
Great update!
But what do I need to change
# Preview Options
width 512
quality 25
divider 1
to in order to set full fov 4:3 as the default preview size? I cant quite get it to work without an error message being thrown up.
jbeale
Mon Mar 24, 2014 8:23 pm
silvanmelchior wrote:@slabua: You're welcome. The bug with the black timelapse-capture seems to be a driver-problem, because raspivid -w 640 -w 480 -fps 1 -o test.h264 give's me a black preview, too. Anybody else the same thing?
AFAIK that is a known issue. The slowest possible video is 2 fps, not 1 fps, some kind of MMAL limitation I guess.
The new RPi Cam Control page looks good. I did not get 4:3 full preview format either, it was stuck on the "STD" field of view and the "Custom Values" boxes were blank. Then I rebooted the Pi and after that I could get the full field of view and the values boxes were filled in. I did have to click on the "Load Preset: Select Option" pulldown before the boxes filled in. Note: during the install there was a complaint about not being able to remove symbolic link '/usr/bin/raspimjpeg' so I manually removed it, and then installed again.
Thanks again for your hard work silvanmelchior, I really appreciate the opportunity to save lower-res video (my old laptop has a hard time with playing full-HD).
slabua
Mon Mar 24, 2014 8:57 pm
Trixster wrote:Great update!
video_width and video_height
jbeale wrote: AFAIK that is a known issue. The slowest possible video is 2 fps, not 1 fps, some kind of MMAL limitation I guess.
Hm, though it works fine at native HD resolution.
jbeale
Mon Mar 24, 2014 9:00 pm
According to JamesH, at least back in November there was a 2 fps limit on raspivid, if you try slower it gets forced to 2 fps (he thought):
http://www.raspberrypi.org/phpBB3/viewt ... 08#p453600
slabua
Mon Mar 24, 2014 9:07 pm
jbeale wrote:According to JamesH, at least back in November there was a 2 fps limit on raspivid, if you try slower it gets forced to 2 fps (he thought):
Ah thanks, I wasn't aware of this. Although to my eye it seems that at least from the stream preview, 1 and 2 fps do look different.
jarrah31
Mon Mar 24, 2014 9:19 pm
Took me a moment to figure this one out too because it's not obvious that you need to change video_width and video_height to enable full FOV. I had to look at the index.html code to understand why.
<option value="1920 1080 25 25 2592 1944">Select option...</option>
<option value="1920 1080 25 25 2592 1944">Std FOV</option>
<option value="1296 0730 25 25 2592 1944">16:9 wide FOV</option>
<option value="1296 0976 25 25 2592 1944">4:3 full FOV</option>
<option value="1920 1080 01 30 2592 1944">Std FOV, x30 Timelapse</option>
The first two numbers relate to video_width and video_height in the /etc/raspimjpeg config file, so by changing them to the 4:3 full FOV resolution, you'll get full FOV. e.g.
For Std FOV:
# Video Options
video_width 1920
video_height 1080
video_fps 25
For 4:3 full FOV
# Video Options
video_width 1296
video_height 976
video_fps 25
Hope that helps.
UPDATE: I've added this information to the Wiki as well.
jarrah31
Mon Mar 24, 2014 9:27 pm
Just wondering whether this is an issue with my setup or not:
Basically in Night mode, my preview stream alternates between a very dark view of the scene and full night mode brightness. It seems to last 2 seconds in either mode and doesn't stay put in either. It does this even before enabling the Night Exposure Mode, and changing white balance to something other than auto makes no difference either.
It was doing this before the recent 4.x update, using the latest 3.x code. Performing a full dist-upgrade, rip-update, reboot, install updated raspimjpeg hasn't resolved it, so before I do a full reinstall I wanted to see if anyone else has a similar problem?
jarrah31
Mon Mar 24, 2014 9:31 pm
silvanmelchior wrote: @Questionario: I bought the Pi-Pan (http://openelectrons.com/index.php?modu ... PAGE_id=15), because it seems pretty cool. As soon as I get it and find the time, I'm going to program a pan/tilt-control on the website incl. the ability to turn on/off the light.
I discovered Pi-Pan recently too and had thought about getting one, but I'm even more keen to buy it now that you plan to integrate pan/tilt control because that would be sooo amazing!! :)
Trixster
Mon Mar 24, 2014 9:52 pm
For Std FOV:
# Video Options
video_width 1920
video_height 1080
video_fps 25
For 4:3 full FOV
# Video Options
video_width 1296
video_height 976
video_fps 25
Hope that helps.
Thanks for the reply. I think the problem is that I'm using chrome on an ipad. Making the changes you suggest does not bring up full fov 4:3 as the default option for the live video, rather it just keeps the video the default aspect but also makes the video much much smaller. I'm talking about the live video on the options screen here, not the preview video you can view of a recording.
slabua
Mon Mar 24, 2014 10:00 pm
Trixster wrote:Thanks for the reply. I think the problem is that I'm using chrome on an ipad. Making the changes you suggest does not bring up full fov 4:3 as the default option for the live video, rather it just keeps the video the default aspect but also makes the video much much smaller. I'm talking about the live video on the options screen here, not the preview video you can view of a recording.
Did you restart raspimjpeg after changing the config file? Those options are for both the preview and the recording.
luxomattic
Mon Mar 24, 2014 10:03 pm
Wonderful piece of software!
Would it be possible to add different filters to the image? Something like this maybe: http://camanjs.com/? I've seen something similar on the picam by adafruit: http://learn.adafruit.com/diy-wifi-rasp ... the-camera.
I'm very new to all this but looking forward to get more knowledge on the topic.
Kind regards
Trixster
Mon Mar 24, 2014 10:04 pm
Yep, I'm doing sudo reboot after each edit of the config file.
slabua
Mon Mar 24, 2014 10:11 pm
Trixster wrote:Yep, I'm doing sudo reboot after each edit of the config file.
Hm, not sure then. It's sufficient to do the following, though:
sudo ./RPi_Cam_Web_Interface_Installer.sh stop
sudo ./RPi_Cam_Web_Interface_Installer.sh start
Return to “Camera board”
