sic698
Terminal COlor change
Thu Jul 24, 2014 12:21 am
Hi Guys,
I want my terminal or bash to have a black background and green text, I want it something to look like the Matrix Movie, How do I make the changes permanent?
AndyD
Re: Terminal COlor change
Thu Jul 24, 2014 4:50 am
It depends on which terminal you are talking about.
If you are using a keyboard and logging using a TV/monitor attached to the Raspberry Pi (and not using the desktop) then
setterm -foreground green -background black
will work. To make it permanent you could add
/usr/bin/setterm -foreground green -background black
to the file /etc/rc.local
If you are using the Desktop and using LXTerminal use the edit->preference menu item and select the style tab.
sic698
Fri Jul 25, 2014 3:59 pm
will this work in console? I use my Raspberry pi as a headless server.
AndyD
Fri Jul 25, 2014 11:02 pm
sic698 wrote:will this work in console? I use my Raspberry pi as a headless server.
If it is headless, how do you view the console? I think I have misunderstood your question. Do you mean you want the boot message to be displayed in green rather than white?
AndyD
Fri Jul 25, 2014 11:04 pm
To be honest that wasn't a good solution!
Return to “Beginners”
