arwald
Difference between B and B+
Tue Jul 29, 2014 12:49 pm
I would like to know if anyone knows, what are the difference between Rpi B and B +, except some hardware modification.
I was never able to manipulate B, I am using some screens I saw and what I saw on the B +.
It seems to me that the processor remains the same (ARMv6 compatible processor rev 7 (v61).
2 additional USB port.
Transition from SD to μSD.
some change, but which one exactly?
And most importantly, the question I ask myself, why it affects the functioning of a OS working properly in B and not in B +?
RaTTuS
Contact: Twitter YouTube
Re: Difference between B and B+
Tue Jul 29, 2014 12:56 pm
http://www.raspberrypi.org/forums/viewt ... 63&t=81736
better power management
the LAN9514 is now clocked from the SOC for less cost so the old firmware could not drive the new options
Covfefe
Tue Jul 29, 2014 12:57 pm
Don't forget the composite video moved from an RCA connector to the 3.5mm jack.
http://www.raspberrypi-spy.co.uk/2014/0 ... ideo-jack/
RaTTuS
Tue Jul 29, 2014 1:02 pm
better analogue audio ;)
Covfefe
MattHawkinsUK
Tue Jul 29, 2014 1:03 pm
Plus ...
  • 4 mounting holes
    40 pin GPIO header
    Power socket moved to HDMI side
    Ethernet port now has status LEDs
My Raspberry Pi blog and home of the BerryClip Add-on board : http://www.raspberrypi-spy.co.uk/
Follow me on Google+, Facebook, Pinterest and Twitter (@RPiSpy)
arwald
Tue Jul 29, 2014 1:05 pm
Thanks everyone to answer so quickly :) :)
I have forgot about composite in jack :oops:
The main thing i don't understand, is why, even if the architecture of the processor seems to remain the same, the raspberry B+ is unable to recognize an OS which is known to work on B.
Does status LEDs of ethernet port are the same than the former led on the board?cause i can see two led on the ethernet but from what i've seen, there were 3 leds on the board for the ethernet port.
Tue Jul 29, 2014 1:07 pm
arwald wrote:The main thing i don't understand, is why, even if the architecture of the processor seems to remain the same, the raspberry B+ is unable to recognize an OS which is known to work on B.
That's because the 25MHz crystal for the USB and ethernet has been removed and replaced with a GPIO based signal generator. That fundamental hardware change needs a firmware/bootcode change to implement it.
AndrewS
Tue Jul 29, 2014 2:00 pm
...and the LAN_RUN signal (which 'turns on' the LAN9514) has moved to a different GPIO pin, and the Activity LED has been moved to a different GPIO pin, and (other changes we're unaware of until the schematics get released) ...
The old firmware / operating systems technically will boot (since the SD card is still connected to the same pins on the SoC), but for two different reasons described above the LAN9514 will be non-functional, which means no access over Ethernet, and no access using a USB mouse or keyboard. Which makes them not very useful ;)
hampi
Tue Jul 29, 2014 4:53 pm
Summary
http://elinux.org/RPi_Hardware
My ears do not hear problem in RPiB sound so RPiB+ must be real HiFi then.
AndrewS
Tue Jul 29, 2014 5:00 pm
hampi wrote:My ears do not hear problem in RPiB sound so RPiB+ must be real HiFi then.
More info: http://www.raspberrypi.org/forums/viewt ... 35#p577735
mahjongg
Tue Jul 29, 2014 5:46 pm
Also,
  • current monitors on the USB ports mean the B+ now supports hot plugging.
  • Current limiter on the 5V for HDMI means HDMI cable powered VGA converters will now all work
  • 14 more GPIO pins,
  • Four mounting holes
  • EEPROM readout support for the new HAT expansion boards
  • Higher drive capacity for analog audio out, form a clean separate regulator, means a better audio DAC.
  • No more backpowering problems, due to the USB current limiters which also inhibit back flow, together with the "ideal power diode".
  • And probably many other things i've forgotten
Tue Jul 29, 2014 6:03 pm
mahjongg wrote:Also,
  • A power LED that can be disabled for "stealth" mode :)
  • Rounded corners :?:
  • and probably many other things I've forgotten too ;)
AndrewS
Tue Jul 29, 2014 6:55 pm
  • A '+' in the name. That must make it better, right? :lol:
Tue Jul 29, 2014 6:58 pm
Have you just announced a new model????
AndrewS
Tue Jul 29, 2014 7:05 pm
:P :P :P :lol:
Wed Jul 30, 2014 8:48 am
I'm finding it odd that there doesn't seem to be a Foundation page describing the differences! I've not got much on, perhaps I'll knock one up for the documentation!
RaTTuS
Wed Jul 30, 2014 8:50 am
Eban's already mentioned it....
I still want a six pack ;)
I suppose there have already been people asking for a B- :roll:
Covfefe
AndrewS
Wed Jul 30, 2014 8:58 am
jamesh wrote:I'm finding it odd that there doesn't seem to be a Foundation page describing the differences! I've not got much on, perhaps I'll knock one up for the documentation!
I noticed the other day that http://www.raspberrypi.org/product/model-b/ and http://www.raspberrypi.org/product/model-b-plus/ both say "... is the higher-spec variant of the Raspberry Pi" ;)
Burngate
Wed Jul 30, 2014 9:15 am
AndrewS wrote:... that http://www.raspberrypi.org/product/model-b/ and http://www.raspberrypi.org/product/model-b-plus/ both say "... is the higher-spec variant of the Raspberry Pi" ;)
... Both of which are true, since both B & B+ are higher-spec than A
Jim JKla
Wed Jul 30, 2014 9:34 am
I suppose I have a B- as its one of the ones with poly fuses and 256Meg.
Note: This is not a complaint. I am happy with what I have. I will be getting a B+ as soon as I have the cash. ;)
Noob is not derogatory the noob is just the lower end of the noob--geek spectrum being a noob is just your first step towards being an uber-geek ;)
If you find a solution please post it in the wiki the forum dies too quick
pluggy
Wed Jul 30, 2014 9:53 am
Black tape.........
Jim JKla
Wed Jul 30, 2014 9:59 am
Even tidier black nail varnish. ;)
Or even stealthier put it in a sealed box. :D
mahjongg
Wed Jul 30, 2014 11:51 am
There is this page already! http://www.raspberrypi.org/product/model-b-plus/
granted, it leaves many improvements unmentioned!
AndrewS
Wed Jul 30, 2014 11:54 am
mahjongg wrote:There is this page already! http://www.raspberrypi.org/product/model-b-plus/
I guess my earlier link must have been too subtle ;)
mahjongg
Wed Jul 30, 2014 1:20 pm
yeah, it must have been. :oops: sorry.
