jwzumwalt
Howto: Disable Screen Saver In Raspbian
Mon Oct 07, 2013 5:55 am
I became very frustrated in my attempts to disable the screen saver. I finally found that there are two steps to this. The bash (shell) text terminal has its own blanking software, while the Xserver uses independant graphic settings.
To add to the frustration, many recommendations just don't work on the Raspbian version of Debian, or (as I found out) Raspbian used different files.
To view your Xsession screen saver setting, use this command (must be used from xterminal)
xset q
In brief, this is what must be done for Raspbian...
Disable text terminals from blanking
change two settings in /etc/kbd/config
BLANK_TIME=0
POWERDOWN_TIME=0
Disable Xsession from blanking
Additional info https://wiki.archlinux.org/index.php/Di ... _Signaling
Add these lines to /etc/xdg/lxsession/LXDE/autostart
@xset s noblank
@xset s off
@xset -dpms
UpDate: (Jan 27th, 20115) - I just received an email from "Dirk" saying the file location has changed...
The file changed from /etc/xdg/lxsession/LXDE/autostart -to- /etc/xdg/lxsession/LXDE-pi/autostart
If the file location has changed on the version you are using, the script will need to be edited
Here is a script that will permanently disable Xsession blanking
no_blank.sh
#!/bin/bash
NOBLANK="
@xset s noblank
@xset s off
@xset -dpms
  # Pretty ANSI text colors
  OFF="\033[0m"
  BOLD="\033[1m"
  DIM="\033[2m"
  RED="\033[1;31m"
  GREEN="\033[1;32m"
  YELLOW="\033[1;33m"
  BLUE="\033[1;34m"
  clear
  printf "\n\n\t $YELLOW           "; date ; printf "$OFF"
  printf "\n $GREEN"
  printf "\t +------------------------------------------------+\n"
  printf "\t |                  no_blank.sh                   |\n"
  printf "\t |                rev Oct 1, 2013                 |\n"
  printf "\t |                                                |\n"
  printf "\t |  by: Jan Zumwalt - net-wrench.com              |\n"
  printf "\t |                                                |\n"
  printf "\t |  This script permanently disables the xsession |\n"
  printf "\t |  screen saver for RASPBIAN PI OS. It allows    |\n"
  printf "\t |  the user to abort before any change is made.  |\n"
  printf "\t +------------------------------------------------+$OFF\n\n"
  printf "\t This program will disable your xsession\n"
  printf "\t screen saver permanently, is this what \n"
  printf "\t you really want to do? $YELLOW<y/n>$OFF"; read -n 1 KEYIN
  if [[ $KEYIN == "N"  ||  $KEYIN == "n" ]]; then
    printf "\n\n\t OK, I quit and did not do anything.\n\n"
    exit 0
  fi
  printf "\n\n\t I intend to modify your current \n"
  printf "\t /etc/xdg/lxsession/LXDE/autostart \n"
  printf "\t I will add the$GREEN GREEN$OFF lines to the file...\n\n"
  printf "$DIM\n"
  pr -t -o 9 /etc/xdg/lxsession/LXDE/autostart
  printf "$OFF$GREEN$NOBLANK" | pr -t -o 9
  printf "$OFF\n\n"
  printf "\t Is this really what you want to do? $YELLOW<y/n>$OFF"; read -n 1 KEYIN
    exit 0
  fi
  cat /etc/xdg/lxsession/LXDE/autostart > /etc/xdg/lxsession/LXDE/autostart.`date +%m-%d-%Y_%I:%M:%S`
  printf "\n\t Created backup copy of the autostart file...\n"
  printf "$NOBLANK" >> /etc/xdg/lxsession/LXDE/autostart
  printf "\t Your new file looks like this\n"
  printf "$DIM\n"
  printf "$OFF\n\n"
  printf "\t$RED Modified file. Screensaver is now disabled.$OFF\n"
  # required so xterm will not close
  printf "\n\t press any key to exit: "; read -n 1 KEYIN
  printf "\t$GREEN Program ended normaly $OFF\n\n"
For completeness here are the other methods that reportedly worked for other OS.
Stop Screen Blanking
1 & 2 work for the Raspbian
1) Stop text terminals from blanking
change in /etc/kbd/config these two:
BLANK_TIME=0
POWERDOWN_TIME=0
2) Stop Xsession from blanking
@xset s noblank
@xset s off
@xset -dpms
A) Change your ~/.xinitrc or /etc/X11/xinit/xinitrc or /etc/xdg/lxsession/LXDE/autostart
NOTE: attempting to create a ~/.xinitrc and use in Raspbian crashed my Xserver
@xset s noblank
@xset s off
@xset -dpms
B) Change the /etc/lightdm/lightdm.conf and paste under the [SeatDefault]
xserver-command=X -s 0 dpms
"only effective if you boot straight into X using that particular display manager."
C) Use the xdotool to send a benign keyboard input to midori every ten minutes e.g. over crontab
...not a real solution, but it could work for my purpose.
D) Use a Display-Manager such as LXDE and run your browser there. User coolblue2000
had the same issue and finally went the way over a window manager, disabling the panel
(menu bar at the bottom) and setting the background picture to black - so you can't
see the whole LXDE. Here's a description:
http://pikiosk.tumblr.com/post/38721623 ... -static-ip
-- This will use more CPU - if anybody tries this, please leave a comment how much.
I'm really short of CPU, so I don't want to run an unnecessary windowmanager just to
prevent a screensaver... :(
E) Create a shell script disableblank.sh that runs the xset commands and add an entry
in .config/autostart/ calling that script. That way, everything is started with the
same method and either both work or neither works.
ramstrong
Re: How2 Disable Screen Saver In Raspbian
Mon Oct 07, 2013 7:56 pm
Ha ha. Yeah, disabling screen saver can be a pain. That's why I added that capability on my Noob Tools script. Just do "noob noblank" to disable screen saver. "noob blank" to enable it. It only works on GUI, though. I didn't make it for terminal.
Add gpicview program, and you have a full screen slide show pictures capability all day long. Very nice.
Raspberry Pi Journal: http://simpletongeek.blogspot.com/p/raspberry-pi-journal-directory_4.html
SoftSpot
Sat Mar 08, 2014 4:29 am
jwzumwalt: thanks for this explanation. This one did the trick! Finally. :D
carolinarider
Thu May 15, 2014 11:33 pm
I am a new user. I have a model b that I want to use for digital signage using Impress. I found this thread and have copied the code for the "no_blank".
I was hoping that someone would provide some additional instructions on how to implement the code. I suspect it is fairly straight forward. Any assistance would be appreciated.
Jim
sammyrox
Thu Jun 26, 2014 9:17 pm
Please forgive me, as I am basically computer illiterate.
I have tried this solution on my raspberry pi and yet the screen still blanks after the 10 minutes. I checked the files to insure the changes saved, and they have been. Why am I still getting blanking?
NeilEric
Thu Aug 14, 2014 6:51 pm
jwzumwalt,
Finally! Thank you for posting this.
Neil
vallieres
Tue Aug 19, 2014 6:04 pm
I'm having the same problem even after doing all the steps.
We have a wall display powered by a Raspberry Pi. It worked fine for about 2-3 months then I had issues with memory corruption on the SD card. So I reinstalled it with the latest Raspbian.
Followed this guide that worked before (http://bloguedegeek.net/2014/05/13/cree ... -tutoriel/), and now after about 10 minutes I still have the screen go black, still open and green, just nothing being pushed via video.
I did the BLANK_TIME=0 and POWERDOWN_TIME=0 without success.
I also added the same @xset commands to the two xinitrc files I have
And finally added this SeatDefault thing too. No success.
I'm at a loss! How can I get that wall display to stay lit?
Thanks!
vallieres
Wed Aug 20, 2014 3:08 pm
Nevermind, I forgot to install the x11-xserver-utils... :P
On my previous setup I had installed Chromium, x11-xserver-utils and unclutter. That's why it worked fined after going with Iceweasel.
I did this to fix the problem:
 sudo apt-get install x11-xserver-utils unclutter
Thanks!
bearsarepeopletoo
Tue Apr 07, 2015 5:41 pm
Question for: jwzumwalt regarding your script posted on Jan 2015.. where do I insert this?
Sorry, new to Raspbian and first step is getting the monitor to stay on.
Thanks!
kusti8
Tue Apr 07, 2015 7:56 pm
bearsarepeopletoo wrote:Question for: jwzumwalt regarding your script posted on Jan 2015.. where do I insert this?
Thanks!
You should probably look at some Linux books. You put the script into a file using leaf pad or nano and then exexute it like this:
./script.sh where script is the name of the file.
klricks
Tue Apr 07, 2015 11:15 pm
The easiest way to disable screen blanking in the Raspbian GUI is to install xscreensaver then configure it to disabled.
sudo apt-get update
sudo apt-get install xscreensaver
In the [Display Mode] tab, set like this - Mode: [Disable Screen Saver]
3B+ & 4B4G Running RPi OS Bookworm w/ Desktop
bearsarepeopletoo
Wed Apr 08, 2015 4:03 pm
Thanks! This worked well for a non-programmer like me
spatieman
Re: Howto: Disable Screen Saver In Raspbian
Thu Apr 09, 2015 10:30 am
aah, the xscreensaver package did the trick for me !
tjnxs.
Krassegrand
Sat May 09, 2015 2:31 pm
jwzumwalt wrote: In brief, this is what must be done for Raspbian...
BLANK_TIME=0
POWERDOWN_TIME=0
I would like to have the blank screen option but not the power down, or at least set it for a few hours.
I tried to set BLANK_TIME=1 and
POWERDOWN_TIME=0 but the file is write protected.
Do I have to edit it on another PC?
Jörgen
Krassegrand
Sat May 09, 2015 3:02 pm
I tried to open the config file from the terminal but I am doing somethingwrong
pi@raspberrypi /etc $ cd kbd
pi@raspberrypi /etc/kbd $ ls
config remap
pi@raspberrypi /etc/kbd $ sudo config
sudo: config: command not found
pi@raspberrypi /etc/kbd $ run config
bash: run: command not found
pi@raspberrypi /etc/kbd $ open config
Couldn't get a file descriptor referring to the console
J;rgen
PS how do I get swedish keyboard_
Sat May 09, 2015 5:14 pm
You need to open the file with a text editor with root (superuser) permissions. Try
sudo nano config
or
sudo nano /etc/kbd/config
kusti8
Sat May 09, 2015 5:16 pm
Krassegrand wrote: PS how do I get swedish keyboard_
Go to:
sudo raspi-config
and you can change it under Internationalization.
Krassegrand
Sat May 09, 2015 5:35 pm
Go to:
sudo raspi-config
I have been there but there seems to be only 1 alternative.
Or is it not supposed to be called something like SE?
Jörgen
Sat May 09, 2015 6:45 pm
From the man 5 page for keyboard
The standard location of the keyboard file is /etc/default/keyboard.
Description of all available keyboard models, layouts, variants and op‐
tions is available in /usr/share/X11/xkb/rules/xorg.lst. In most cas‐
es, in /usr/share/keymaps/ or /usr/share/syscons/keymaps/ you will find
several keymaps that can be used with the variable KMAP.
Krassegrand
Sat May 09, 2015 8:11 pm
rpdom wrote:You need to open the file with a text editor with root (superuser) permissions. Try
sudo nano config
or
I will try this tomorrow morning!
Thank You
Jörgen
Krassegrand
Sun May 10, 2015 4:30 am
How do I exit from nano?
Jörgen
I have entered ^X but nothing happens!
Sorry sorry sorry!
I have read the manual now!
^ means control!
Thank You guys!
Krassegrand
Sun May 10, 2015 6:32 am
Jörgen
I did it now with nano (sudo) and when I open after restart it is still
BLANK_TIME=1 and
POWERDOWN_TIME=0
but it don't seem to change any behaviour. it still blanks after about 15 minutes (it was originally set to 30 in the config) as it did from the beginning.
This is a very minor problem so I will let it be for now.
Thanks for the help guys.
Jörgen
rosignol
Fri May 29, 2015 4:41 pm
Hi I'm(well I was) desperately in need of help.
I'm trying to run a scrolling notice board and have looked at all (well most) of the posts regarding this. and eventually got there this way
My problem was that
1) I couldn't get in to where I needed to be to over write the "lightdm.conf" file.
[OK I've managed to do this now with "sudo" what is sudo?
(if you are following this to solve a similar problem here is what I did)
i] click on the LXTerminal (the little black screen at top of page) and when it appears you will see "raspberrypi$- ", now type "sudo leafpad" (btw don't put the " "s in) and hit return, you'll see some
code appear on the screen and then leafpad will open. (leafpad is your text editor btw)
(explanation of what you have just done)[ sudo stands for 'super user do' so you are now a super user also known as 'root'
So you have just opened the leafpad editor as a su or root user (this is just temporary for the current session)
ii] go to the file menu and click on pi and then go down to the file icon below 'python games' (the one with just a folder followed by a / , click on it and then follow the path "etc/lightdm/lightdm.conf" this will open the file lightdm.conf
iii] tab down until you find the line that begins [SeatDefaults] and the code line #xserver-command=x
iv]now you need to change that line to read xserver-command=x -s 0 -dpms ( leave the hash{#} out and note the spaces between x&-s, s&0, and 0&-dpms)
v) now go up to the file menu and click save and in the dialog box that comes up click 'save' again. now close and reboot your pi
vi) this should stop the Pi falling asleep.
2) having explained all this I find that in some cases (mine for instance) this does not work but it was good fun trying. At last though I have come upon a working solution. Here it is.
3) Go to the LXTerminal and type the following sudo apt-get install xscreensaver (press enter), when it has loaded reboot your Pi
4) when Pi has rebooted click on File manager and open screensaver. The first line of the screen saver menu says "disable screen saver" click on it close it, reboot Pi again and hey presto Pi will stay awake. yippee!!!!!!!
Finally Thanks to all those who between them supplied the answers I needed, but please remember that newbies(like me) need very,very detailed instructions
best regards Rosignol
Krassegrand
Sun May 31, 2015 8:04 am
Try using the sudo nano command to open lightdn.con.
It will overwrite the existing file when you save it.
The changes should take place after restart if I understand it.
Jörgen
Edit
By the way,
What do You want to change in lightdn.con?
Return to “Beginners”
