tdenson
Cable Matters USB/LAN adapter
Mon May 04, 2015 2:49 pm
Anyone had any luck getting one of these to work. It doesn't appear on the wiki list of known to work adapters, but I just happen to have one kicking around. When I do an ifconfig I see an eth1 device, but it's not got an ip address.
Re: Cable Matters USB/LAN adapter
Mon May 04, 2015 3:31 pm
It sounds like your device is being detected correctly and the driver loaded.
In order to use it as eth1 you will have to set up entries for eth1 in /etc/network/interfaces. Copying the existing eth0 configuration should work.
tdenson
Mon May 04, 2015 10:07 pm
rpdom wrote:It sounds like your device is being detected correctly and the driver loaded.
Brilliant thanks, works a treat.
