STICKY: Jessie (now defunct and replaced with Stretch) Q&A
Tue Sep 29, 2015 11:05 am
Please put any questions about the new Jessie release in this thread. We will endeavour to answer then as soon as possible.
Please keep it to Q&A, posts not answering that description may be deleted without warning, to keep things tidy.
RogerW
Re: Jessie Q&A
Tue Sep 29, 2015 11:13 am
I am getting errors from apt-get update and an attempt to install geany failed with a problem accessing 'mirrordirector.raspian.org'. Is this down to heavy traffic or something more fundamental?
plugwash
Re: Jessie Q&A
Tue Sep 29, 2015 11:17 am
RogerW wrote:I am getting errors from apt-get update and an attempt to install geany failed with a problem accessing 'mirrordirector.raspian.org'. Is this down to heavy traffic or something more fundamental?
Was this during an upgrade to jessie or just during normal administration of the system? (if the latter then i'll split this to it's own thread)
Can you reproduce the problem now? if so can you post the complete output of the failing commands?
RogerW
Re: Jessie Q&A
Tue Sep 29, 2015 11:30 am
Just normal administration. I installed Jessie image to a new sdcard. I will try to reproduce later - not sure I can show output because I use a PC to access this forum.
RogerW
Re: Jessie Q&A
Tue Sep 29, 2015 1:05 pm
Just tried again and everything worked as normal. Ithink there must have been a hiccup on the server.
proudindiv
Re: Jessie Q&A
Tue Sep 29, 2015 4:44 pm
The official zip file appears to be corrupt. I down loaded it from the torrent and from the direct download and both matched the SHA-1 check. However, the zip file contains "2015-09-24-raspbian-jessie.img" file with size 807,167,523,358,810 KB! That's 807 PETABYTES! I can't extract it.
MrEngman
Re: Jessie Q&A
Tue Sep 29, 2015 5:14 pm
It isn't corrupt. The problem will be with your unzipper which cannot handle files bigger than 4GB.
Take a look here viewtopic.php?f=28&t=121867&view=unread#unread.
MrEngman
PeterO
Re: Jessie Q&A
Tue Sep 29, 2015 8:14 pm
Command line NFS mounts no longer seems to work !
PeterO
Only been using Jessie for an hour, and already hacked off with systemd not doing the right things !
PeterO
dom
Re: Jessie Q&A
Tue Sep 29, 2015 8:30 pm
PeterO wrote:Command line NFS mounts no longer seems to work !
PeterO
How about describing what command you entered and what the result was?
The command I used to run on wheezy still works on jessie:
sudo mount 192.168.0.10:/home/dom/TestMedia -o _netdev,nfsvers=3,rw,intr,noatime,rsize=32768,wsize=32768,nolock,proto=tcp /home/pi/dell
PeterO
Re: Jessie Q&A
Tue Sep 29, 2015 8:34 pm
pi@raspberrypi ~ $ sudo -s
root@raspberrypi:/home/pi# mount -t nfs 192.168.1.21;/opt/RPI /opt/RPI -o vers=2
mount: can't find 192.168.1.21 in /etc/fstab
bash: /opt/RPI: Is a directory
ARGHHHH Now I paste it into here on a big screen I immediately see the problem ! I blame the small text and my failing eyes :-)
PeterO
PuppetHoundZ
Re: Jessie Q&A
Tue Sep 29, 2015 8:45 pm
I've made an image using the image from the web page (without noobs) and plan on booting it for the first time later today.
Is the first time setup the same as the Weezy version?
Has an effort been put into having pre-installed CUPS gui for printer users?
MikeDunn
Re: Jessie Q&A
Tue Sep 29, 2015 8:53 pm
Just upgraded (new install on new SD card), and installed TightVNC, following AdaFruit's Lesson 7. However - despite putting an autostart script in for VNC, I find it (mostly) won't ? Occasionally, it does start (once every 5-6 restarts ? but no more), meaning I almost always need to SSH & start it manually.
Any ideas ? Works perfectly in Wheezy ... ;)
Mike
Woll
Re: Jessie Q&A
Tue Sep 29, 2015 11:29 pm
Will Raspbian turn into a version of Jessie with a sudo apt-get dist-upgrade in a couple of weeks time?
Or does it need a completely new installation?
Will all the software work on Jessie?
Who ate all the Pi's? Who ate all the Pi's?
Boris Johnson, Boris Johnson,
ShiftPlusOne
Re: Jessie Q&A
Wed Sep 30, 2015 12:20 am
Woll wrote:Will Raspbian turn into a version of Jessie with a sudo apt-get dist-upgrade in a couple of weeks time?
I don't have the link handy, but the blog post links to a thread with upgrade instructions. However, it's not the safe or recommended method.
I can't say anything about ALL the software, so you will have to be more specific with the second part of that question. Pretty much everything will work as it did, with some minor exceptions. Some things are now done differently with the move away from sysvinit to systemd.
AndyD
Re: Jessie Q&A
Wed Sep 30, 2015 12:23 am
ShiftPlusOne wrote:I don't have the link handy, but the blog post links to a thread with upgrade instructions. However, it's not the safe or recommended method...
Here it is.
metalj
Re: Jessie Q&A
Wed Sep 30, 2015 4:25 am
What is different about scratch in Jessie? It says version 1.4 and that was the previous version.
Backspace 28 times :)
cjan
Re: Jessie Q&A
Wed Sep 30, 2015 4:26 am
vlc, does it H/W supported? can not play .mkv.
neuralassembly
Re: Jessie Q&A
Wed Sep 30, 2015 5:24 am
The new Raspbian does not have the directory /usr/share/fonts/truetype/droid.
Therefore, I cannot show Japanese characters on UIs with default Raspbian
because there is no /usr/share/fonts/truetype/droid/DroidSansJapanese.ttf.
Is it possible to add the "droid" fonts in the future release of Raspbian?
If no, I hope that some Japanese font package is added to Raspbian, such as fonts-ipafont.
talm
Re: Jessie Q&A
Wed Sep 30, 2015 6:55 am
Synaptic requests a Password when started. pi does not work.
I downloaded Jessie yesterday and put it onto fresh cards.
Then I installed synaptic using apt-get as usual.
When started it requests a root password.
HELP!
Torbjörn Alm, Sweden
fruitoftheloom
Re: Jessie Q&A
Wed Sep 30, 2015 7:02 am
talm wrote:Synaptic requests a Password when started. pi does not work.
HELP!
default user is pi with the password raspberry
metalj
Re: Jessie Q&A
Wed Sep 30, 2015 9:45 am
Why doesn't Stella work?
talm
Re: Jessie Q&A
Wed Sep 30, 2015 10:19 am
Synaptic again
The dialogue asks for password for root.
Neither pi nor raspberry is accepted.
root can not be changed
Torbjörn Alm, Seden
plugwash
Re: Jessie Q&A
Wed Sep 30, 2015 10:28 am
A workaround would probablly be to start synaptic using "sudo synaptic" from the command line.
il_diavolo
Jessie and CV2
Wed Sep 30, 2015 11:41 am
I would be grateful if someone could confirm which version of CV2 is included in Jessie. What I really mean is - is it a later version than the one included in Wheezy?
Colin
plugwash
Re: Jessie Q&A
Wed Sep 30, 2015 12:37 pm
Systems will not be upgraded unless the user explitictly changes their sources.
Upgrading should work but some people have reported problems and so the raspberry pi foundation don't consider it a supported option. They did however post some instructions which other people have linked.
Return to “Raspberry Pi OS”
