Re: TP-Link TL-WN725N V2 works out of the box on Raspbian
Hi MrEngman,
I tried a lot of things, but didn't get the wifi up like it should.
At last I bought an edimax (EW-7811UN) wifi adapter and it was up and running in seconds.
Don't know why, but it does. No workarounds or nothing.
Hello all,
I have the same problem that patrick31698 has. The only different is that I am using the compilation 3.12.35+ #730.
When try to connect the log report this error:
What can I do?
I am trying to connect to a wifi network encrypted with WPA2-AES.
Thank you very much.
Trying to associate with e0:91:53:5f:18:9c (SSID='WLAN_11' freq=2452 Mhz)
Association request to the driver failed
CTRL-EVENT-DISCONNECTED bssid=e0:91:53:5f.18:9c reason=0
CTRL-EVENT-SCAN-RESULT
WPS-AP-AVAILABLE
How have you configured your connection? Using file /etc/network/interfaces or using wpa_supplicant?conde wrote:Hello all,
What can I do?Code: Select all
Trying to associate with e0:91:53:5f:18:9c (SSID='WLAN_11' freq=2452 Mhz) Association request to the driver failed CTRL-EVENT-DISCONNECTED bssid=e0:91:53:5f.18:9c reason=0 CTRL-EVENT-SCAN-RESULT WPS-AP-AVAILABLE
Can you provide a print out of the files?
MrEngman
This thread is so confusing
I'm running Raspbian 3.18.7-v7+ #755 and just bought the WN725N.
Where can I find the correct drivers for this?
You could take a look here.oskars wrote:This thread is so confusing
Otherwise you could run these commands to download and install the driver.
wget https://dl.dropboxusercontent.com/u/80256631/8188eu-v7-20150212.tar.gz
tar xzf 8188eu-v7-20150212.tar.gz
./install.sh
I have a TP-Link TL-WN725N adapter, but I do not know if it is the V1 or V2. However, I tried to install the latest driver following this thread viewtopic.php?f=28&t=62371 without success.
I have the following kernel
and I tried with this
Do you a suggestion?
Thank you
uname -a
Linux raspbian 3.18.5+ #748 PREEMPT Wed Feb 4 21:24:41 GMT 2015 armv6l GNU/Linux
wget https://dl.dropboxusercontent.com/u/80256631/8188eu-20150130.tar.gz
tar xzf 8188eu-20150130.tar.gz
./install.sh
Thank you
That is the right version of the driver for your version of raspbian. So what is the problem?erotavlas wrote:Hi,
I have the following kerneland I tried with thisCode: Select all
uname -a Linux raspbian 3.18.5+ #748 PREEMPT Wed Feb 4 21:24:41 GMT 2015 armv6l GNU/Linux
Do you a suggestion?Code: Select all
wget https://dl.dropboxusercontent.com/u/80256631/8188eu-20150130.tar.gz tar xzf 8188eu-20150130.tar.gz ./install.sh
Thank you
You can check if the wifi module works with this driver with command lsusb. It will show "ID 0bda:8179 Realtek Semiconductor Corp." for the version of module working with this driver.
When installing it did you get any errors running any of the commands? With the wifi module connected to the Pi does command lsmod show 8188eu or maybe r8188eu?
What does command ifconfig show?
Also what do you see when you use command
sudo iwlist wlan0 scan
Thank you for your fast reply. I did not experimented any error message during the installation of driver with ./install.sh
My lsusb output
and my lsmod output
They seem ok, but if I type /sbin/ifconfig I get this
and with sudo iwlist wlan0 scan
So there is no wifi interface. My current /etc/network/interfaces, should I modify it?
My lsusb output
Bus 001 Device 005: ID 0a5c:21e8 Broadcom Corp. BCM20702A0 Bluetooth 4.0
Bus 001 Device 004: ID 0bda:8179 Realtek Semiconductor Corp.
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Module Size Used by
bnep 11433 2
nfsd 276617 2
ecb 2279 1
btusb 23104 0
8188eu 709203 0
bluetooth 320752 23 bnep,btusb
rfkill 22347 2 bluetooth
uio_pdrv_genirq 3666 0
uio 9897 1 uio_pdrv_genirq
snd_bcm2835 21342 2
snd_pcm 93100 1 snd_bcm2835
snd_timer 23007 1 snd_pcm
snd 67211 7 snd_bcm2835,snd_timer,snd_pcm
fuse 92121 3
ipv6 351566 49
eth0 Link encap:Ethernet HWaddr b8:27:eb:13:ae:3f
inet addr:192.168.0.2 Bcast:192.168.0.255 Mask:255.255.255.0
inet6 addr: fe80::ba27:ebff:fe13:ae3f/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:7566 errors:0 dropped:0 overruns:0 frame:0
TX packets:7723 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:1987777 (1.8 MiB) TX bytes:1345039 (1.2 MiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:422662 errors:0 dropped:0 overruns:0 frame:0
TX packets:422662 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:40819810 (38.9 MiB) TX bytes:40819810 (38.9 MiB)
wlan0 No scan results
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet dhcp
You need to set up your /etc/network/interfaces file correctly to include the wifi interface configuration.
/etc/network/interfaces should look likeYou will need to set network-name and network-password to the ones your network uses.
This format is for a network using WPA/WPA2 security. If your network uses a different security type you will need to change the last two lines.
MrEngman
auto lo
allow-hotplug wlan0
iface wlan0 inet dhcp
wpa-ssid "network-name"
wpa-psk "network-password"
MrEngman
Thank you MrEngman as I supposed I have to modify the configuration files /etc/network/interfaces.
Now I discovered that there are two way to connect to WiFi network. The first is to modify the configuration file /etc/network/interfaces as you described in your previous post while the second is to use the WPA supplicant by changing the /etc/network/interfaces as
and the /etc/wpa_supplicant/wpa_supplicant.conf as
Where are the differences between them?
auto lo
allow-hotplug wlan0
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
network={
ssid="network-name"
psk="network-password"
Using wpa_supplicant can make it simpler to connect your wifi to many different wifi networks if you move around to different locations and take your Pi with you. It makes it possible to configure your wifi to connect to different access points without having to edit any files.erotavlas wrote:Thank you MrEngman as I supposed I have to modify the configuration files /etc/network/interfaces.
Now I discovered that there are two way to connect to WiFi network. The first is to modify the configuration file /etc/network/interfaces as you described in your previous post while the second is to use the WPA supplicant by changing the /etc/network/interfaces asand the /etc/wpa_supplicant/wpa_supplicant.conf asCode: Select all
auto lo iface lo inet loopback iface eth0 inet dhcp allow-hotplug wlan0 iface wlan0 inet dhcp wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
Where are the differences between them?Code: Select all
network={ ssid="network-name" psk="network-password" }
There are many different ways to configure the wifi connection. I prefer to just use /etc/network/interfaces.
To use wpa_supplicant there are also many ways to configure it. You should be able to connect your network using wpa_supplicant using the default format of the file /etc/network/interfaces which is like
auto lo
allow-hotplug wlan0
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
I do not use wpa_supplicant so I am not too familiar with how it works but using the way you have set up it would be possible to set it up to connect to different networks by adding new network{...} sections for each network you connect to and it will connect automatically. Using the default format for /etc/network/interfaces then wpa_supplicant can be configured to connect to different networks just the same but I believe you will need to manually select the network to connect to. As it says in the default /etc/network/interfaces
Personally I think the main difference is not so much how it is set up but how each person prefers to set up their wifi, and I prefer /etc/network/interfaces.iface wlan0 inet manual
MrEngman
Okay so I have one of these wifi dongles. I followed the instructions doing the wget then I modified the install.sh as my raspbian is 3.18.11-v7+ and the install went fine did the reboot and my dongle is still dark.
the lsmod shows
____________________________________
lsmod
Module Size Used by
snd_bcm2835 18649 3
snd_pcm 73475 1 snd_bcm2835
snd_seq 53078 0
snd_seq_device 5628 1 snd_seq
snd_timer 17784 2 snd_pcm,snd_seq
snd 51038 11 snd_bcm2835,snd_timer,snd_pcm,snd_seq,snd_seq_device
joydev 8879 0
cfg80211 386508 0
rfkill 16651 1 cfg80211
evdev 9950 4
uio_pdrv_genirq 2958 0
uio 8119 1 uio_pdrv_genirq
_________________________________________
So I am not seeing the realtek 8818eu
the lsusb shows
dmesg | more shows
3.518130] usb 1-1.4: new high-speed USB device number 4 using dwc_otg
[ 3.629397] usb 1-1.4: New USB device found, idVendor=0bda, idProduct=8179
[ 3.643737] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.657296] usb 1-1.4: Product: 802.11n NIC
[ 3.667605] usb 1-1.4: Manufacturer: Realtek
[ 3.677966] usb 1-1.4: SerialNumber: 00E04C0001
so I believe the right driver is installed. I believe I need to get this squared away before I tinker with /etc/network/interfaces
the lsmod shows
lsmod
Module Size Used by
snd_bcm2835 18649 3
snd_seq 53078 0
joydev 8879 0
cfg80211 386508 0
evdev 9950 4
the lsusb shows
dmesg | more shows
What file did you download and why did you modify the file install.sh? You should not need to modify install.sh.diefledermaus wrote:Okay so I have one of these wifi dongles. I followed the instructions doing the wget then I modified the install.sh as my raspbian is 3.18.11-v7+ and the install went fine did the reboot and my dongle is still dark.
the lsmod shows
lsmod
Module Size Used by
snd_bcm2835 18649 3
snd_seq 53078 0
joydev 8879 0
cfg80211 386508 0
evdev 9950 4
the lsusb shows
dmesg | more shows
If you downloaded the right driver it will show in the list of loaded modules when you use command lsmod, but it does not so I expect you downloaded the wrong driver.
What does the complete output of command uname -a show so I can tell you which file to download and install?
MrEngman
I downloaded
when it ran it tried to put it in
/lib/modules/3.18.5+/kernel/drivers/net/wireless
I have
/lib/modules/3.18.11-v7+/kernel/drivers/net/wireless
thus the modification to the install.sh
the uname command produces
Linux raspberrypi 3.18.11-v7+ #781 SMP PREEMPT Tue Apr 21 18:07:59 BST 2015 armv7l GNU/Linux
the 20150130 is the only driver I came across and from my research the 8188eu looked to be the correct driver.
I have
If you look at the first post here viewtopic.php?p=462982#p462982 there is a complete list of drivers for all versions of raspbian.diefledermaus wrote:I downloaded
I have
The driver you need is 8188eu-v7-20150406.tar.gz so download and install it using commands
wget https://dl.dropboxusercontent.com/u/80256631/8188eu-v7-20150406.tar.gz
tar xzf 8188eu-v7-20150406.tar.gz
./install.sh
MrEngman
your drivers are functional now but I am not picking up a DHCP address
ifconfig shows this.
wlan0 Link encap:Ethernet HWaddr c4:6e:1f:23:f0:ee
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
my /etc/network/interfaces
auto lo
allow-hotplug wlan0
iface wlan inet dhcp
wpa-ssid "**********"
wpa-psk "********"
I have used both a hidden network and a non hidden one and so far nothing.
the etc/wpa_supplicant/wpa_supplicant.conf
is empty.
Yes the ssid are correct yes the passwords are correct. yes I can get an ip on the ethernet via DHCP
all I have on the dongle is a steady green light.
auto lo
allow-hotplug wlan0
wpa-psk "********"
is empty.
Hi MrEngma,
I read the whole thread because I have same issue here (TP Link WN725N disconnect after a while).
TP Link WN725N connected to Raspberry 2 model B.
All the thread talk about linux kernel 3.x.x but last osmc version include 4.4.1 kernel.
uname -a returns:
Linux osmc 4.4.1-1-osmc #1 SMP PREEMPT Mon Feb 15 01:00:53 UTC 2016 armv7l GNU/Linux
lsusb shows this:
Bus 001 Device 004: ID 1d57:ad02 Xenta SE340D PC Remote Control
At the moment I have connected my Raspberry with Ethernet in order to have a stable connection. I have also a IRC remote controlled attached to USB.
I tried also:
wget https://dl.dropboxusercontent.com/u/802 ... 406.tar.gz
tar xzvf 8188eu-v7-20150212.tar.gz
./install.sh
to let the script to determine the version but it failed with this error:
sudo cp 8188eu.conf /etc/modprobe.d/.
sudo install -p -m 644 8188eu.ko /lib/modules/3.18.11-v7+/kernel/drivers/net/wireless
install: cannot create regular file '/lib/modules/3.18.11-v7+/kernel/drivers/net/wireless': No such file or directory
sudo depmod 3.18.11-v7+
depmod: ERROR: could not open directory /lib/modules/3.18.11-v7+: No such file or directory
depmod: FATAL: could not search modules: No such file or directory
Do I have to assume that this driver works only with 3.x.x kernel?
If so, do I have to switch to OpenElec?
uname -a returns:
lsusb shows this:
I tried also:
./install.sh
Hi again,
anyone can help?
Reading this post:
I tried the driver
8188eu-20160219.tar.gz
but it still not work. Now the driver not start at all, the light on device is turned off and wireless connection disappeared completely.
Is there a driver for 4.4.1?
anyone can help?
Reading this post:
I tried the driver
The drivers I compile are for Raspbian wheezy and Jessie and so probably will not work with osmc which is the version I think you are using.sasadangelo wrote:Hi again,
anyone can help?
Reading this post:
I tried the driver
There is a version of the 8188eu driver included in various OS, but if you try and install my driver it will disable the driver included in the OS. To enable the built in driver you need to delete the file /etc/modprobe.d/8188eu.conf. e.g. use command
sudo rm /etc/modprobe.d/8188eu.conf
MrEngman
Hi MrEngman,
It worked. My problem was that the connection drop after a while. At the moment I am checking if it will occurs again. For the moment not.
I have V2 adapter (I asked to the official support team and they told me that if device has 1588 printed on it then it is a V2)
Now I have few questions:
1. which driver I am using now? If I do "cd /lib/modules/4.4.1-1-osmc" and "find . -type f | grep 8188" I get
./kernel/drivers/net/wireless/8188eu.ko
./kernel/drivers/staging/rtl8188eu/r8188eu.ko
how I can understand which one I am using? Is there any command to understand this?
3. I have to activate the driver manually each time I start Raspberry. How I can activate it at startup?
The command lsmod shows the drivers that are being used.sasadangelo wrote:Hi MrEngman,
My driver is ./kernel/drivers/net/wireless/8188eu.ko and I don't expect it to work with osmc so I would suggest you delete it using
sudo rm /lib/modules/4.4.1-1-osmc/kernel/drivers/net/wireless/8188eu.ko
ls -l /lib/firmware/rtlwifi/rtl8188eufw.bin
sudo wget https://github.com/lwfinger/rtl8188eu/raw/master/rtl8188eufw.bin -O /lib/firmware/rtlwifi/rtl8188eufw.bin
MrEngman
Ok, thanks it works.
I will monitor the connection to check if the drop occurs again and I'll let you know.
In the meanwhile I have two other problems:
1. connect wireless automatically at startup
2. request a fixed hostname to dhcp so I do not have to try to figure out the ip assigned.
Hi MrEngma,
I monitored the raspberry and I noticed few things. I have windows with putty (with and without keep alive). Leaving the shells in idle after a while they become inactive.
If I try to reconnect the wireless is still up and running.
Looking on dmesg I found the error below.
[ 2102.508682] R8188EU: ERROR linked_status_chk(wlan0) disconnect or roaming
[ 2104.519938] R8188EU: ERROR assoc success
[ 2194.508839] R8188EU: ERROR linked_status_chk(wlan0) disconnect or roaming
[ 2198.524289] R8188EU: ERROR assoc success
[ 2428.512534] R8188EU: ERROR linked_status_chk(wlan0) disconnect or roaming
[ 2430.464843] R8188EU: ERROR assoc success
[ 2518.509463] R8188EU: ERROR linked_status_chk(wlan0) disconnect or roaming
[ 2520.474851] R8188EU: ERROR assoc success
[ 2652.509783] R8188EU: ERROR linked_status_chk(wlan0) disconnect or roaming
[ 2654.519394] R8188EU: ERROR assoc success
[ 2766.510068] R8188EU: ERROR linked_status_chk(wlan0) disconnect or roaming
[ 2770.437125] R8188EU: ERROR assoc success
It's not clear to me if only ssh connection go down or the whole wireless.
PS
I have this power adapter
http://www.samsung.com/sg/consumer/mobi ... U90EWEGSTD
OUTPUT 5.0V 2.0A
but on another line is written100-240V Frekuensi 50-60Hz 0.35 A (it's not clear here if current is 2.0A or 0.35A)
PS
OUTPUT 5.0V 2.0A
The errors should probably really be warnings.sasadangelo wrote:Hi MrEngma,
I monitored the raspberry and I noticed few things. I have windows with putty. On one putty I configured keep alive to 60 secs. Leaving the shell in idle after a while it become inactive. On the other putty with no keep alive (and this is strange) the connect remain in open. When I go back for few secs it is unresponsive but later it become responsive and everything work properly.
So it's not clear to me if this kind of work is normal or I am experiencing problems.
PS
OUTPUT 5.0V 2.0A
You could try the following to keep the wifi alive. Create a file using command
sudo nano /etc/modprobe.d/r8188eu.conf
options r8188eu rtw_power_mgnt=0 rtw_enusbss=0
I have not tried this file with the r8188eu driver but it seems to be a standard format for wifi adapters using Realtek chip sets. You can check if it working using command
cat /sys/module/r8188eu/parameters/rtw_power_mgnt
Your power supply output to the Pi is 5.0V 2.0A. The other info is for the power supply input from the mains supply.
MrEngman
return 0
but problem persist. I must say it seems less frequent.
return 0
