muda
Re: DietPi | Minimal Raspbian. Optional "ready to run" softw
Tue Jan 19, 2016 8:52 pm
Thanks , this is exactly what I wanted.
How about disks ?
As I remember , I have to answer question if I want dedicated HDD during installation and if I want it to be formatted.
I don't want it to be formatted .
fourdee4d
Wed Jan 20, 2016 2:15 pm
muda wrote:Thanks , this is exactly what I wanted.
How about disks ?
Currently, the only way to use an existing drive with automation is to use the following setting which prompts the user:
AUTO_DietpiSoftware_SkipUsbDrive=0
This will require user input at the system if you are using:
AUTO_AutoLogin=1
You can install DietPi and use the automation settings over SSH by using:
AUTO_AutoLogin=0
DietPi.com - Lightweight justice for your Raspberry Pi. Optimized, simplified linux for everyone
DietPi's web hosting is powered by MyVirtualServer.com
muda
Wed Jan 20, 2016 2:26 pm
thanks for effort but seems I am too noob to understand last post at all :cry:
I only need SSH, deluge, transmission , samba and DLNA.
( I like Deluge more, but some sites banned it so I use Transmission)
My media files are already on HDD so I no way want it to format.
fourdee4d
Wed Jan 20, 2016 4:50 pm
muda wrote:thanks for effort but seems I am too noob to understand last post at all :cry:
You are probably best to ignore the automation options.
Just write the DietPi image and go through the standard installation process.
- Say Yes to USB dedicated drive setup. Then say No when it asks if you want to format.
- Under "DietPi Optimized software" select Transmission and MiniDLNA for install.
- Under "File Server" select Samba.
- "Go Start install".
muda
Wed Jan 20, 2016 5:00 pm
Ok thanks again .
I'll do that
AfouToPatisa
Thu Jan 21, 2016 3:11 pm
AfouToPatisa wrote:
fourdee4d wrote:
AfouToPatisa wrote: EDIT: Running cat /proc/1/comm returns init which makes me realise I'm on SYSVInit and not systemd?
If you are running Wheezy, the script will need to be written/converted to LSB (sysvinit): https://wiki.debian.org/LSBInitScripts. The script i gave you is for Jessie (systemd).
If you need any assistance with the above, give me a shout.
Thanks Dan, yes I am on Wheezy indeed but unfortunately I do not have physical access so I cannot update to Jessie.
I am looking at init at the moment, I will post back if I have anything successful so that other people can use it.
OK to anyone interested I have resolved this by "hacking" it inside fakehwclock since it runs first (S01):
First, get hub-ctrl
sudo apt-get install build-essential libusb-dev
wget https://github.com/codazoda/hub-ctrl.c/blob/master/hub-ctrl.c
gcc -o hub-ctrl hub-ctrl.c -lusb
cp hub-ctrl /usr/bin
chmod +x /usr/bin/hub-ctrl
Then,
nano /etc/rcS.d/S01fake-hwclock
added hub-ctrl -P 2; inside start)
then, nano /etc/profile and I've put in a script that runs my startup programs, including command hub-ctrl -P 2 -p 1 which re-enables the USB ports.
The only problem is that the USBs are still activated for 3-4 seconds at the very start, and I haven't figured out how to disable them. Probably need to hack the kernel?
Sorry if this is off-topic, but it might help someone!
Regards,
Bill
layr
Sat Jan 23, 2016 1:08 am
I have no access to external monitors, so ssh is the only option.
There seems to be an issue sshing to the pi (this is show right after entering the correct password):
ssh root@192.168.1.37's password:
packet_write_wait: Connection to 192.168.1.37: Broken pipe
Tried also setting ssh server to openssh in dietpi.txt; client ssh keepalive is set to 120.
Note this issue does not reproduce with vanilla raspbian images.
fourdee4d
Sat Jan 23, 2016 12:26 pm
layr wrote:Tried also setting ssh server to openssh in dietpi.txt; client ssh keepalive is set to 120.
The SSH settings in dietpi.txt are for automation, these settings only get applied on 1st run setup only. To change SSH server you would need to use dietpi-software and select either dropbear or openSSH.
This is not an issue we have seen previously. So we need some additional information:
- SSH clients tested
- SSH server installed on DietPi
- Have you modified the dropbear/openssh server confs, if so what changes
- Software you have installed with dietpi-software
- Manual software you have installed/configured using apt-get or dpkg -i
- Network configuration on DietPi system (eg: dhcp/static).
- Does the issue reoccur when the system is rebooted (in your case, a hard power off/on cycle)
- PSU (eg RPi 5v/2a)
- Overclocking settings (if any)
- SD card (eg: sandisk ultra 16gb)
- USB devices attached
layr
Wed Jan 27, 2016 12:58 pm
fourdee4d wrote: This is not an issue we have seen previously. So we need some additional information:
Got it solved
As i said, it was vanilla dietpi, as i had no way to access it. The issue might have been connected usb wifi dongle, although i definitely connected against the eth0 interface.
After couple of reinstalls the issue magically disappeared and everything is running perfectly, usb wifi included.
pikaede
Thu Jan 28, 2016 1:49 am
any plan to include docker on ur dietpi-software ?
fourdee4d
Thu Jan 28, 2016 1:25 pm
pikaede wrote:any plan to include docker on ur dietpi-software ?
Very unlikely.
I would need to compile and support custom kernels on all DietPi systems for docker to work. Its a big task and I dont have the time available at the moment. It may have to be a community/team driven addition.
pikaede
Fri Jan 29, 2016 1:20 am
in that case no need to. anyway this build its already solid. very helpfull for people with less linux experience.
thank you
fourdee4d
Sun Jan 31, 2016 7:15 pm
v108 Released!
http://DietPi.com
DietPi-Software Additions:
BruteFIR
EQ and Digital Room Correction via ALSA:
http://fuzon.co.uk/phpbb/viewtopic.php?f=8&t=5&p=57#p57
The DietPi installation of BruteFIR was created specifically for the GiBi project with Jean and Gilles. Details of which will be disclosed at a later date.
SqueezeLite
Audio player for SqueezeBox (Logitech Media Server):
http://fuzon.co.uk/phpbb/viewtopic.php? ... 1009#p1009
Pydio
A feature rich cloud based backup and sync server. A feature-rich alternative to Owncloud:
http://fuzon.co.uk/phpbb/viewtopic.php? ... 1064#p1064
Change Log:
https://github.com/Fourdee/DietPi/blob/ ... NGELOG.txt
Follow us on Twitter:
Get the latest news, updates and releases.
http://twitter.com/dietpi_
fourdee4d
Sat Feb 13, 2016 6:16 pm
v109 Released!
http://DietPi.com
Lighttpd Webserver Stacks: Lightweight an optimized webserver stacks.
  • LLMP Webserver = Linux, Lighttpd, MySql, PHP
  • LLAP Webserver = Linux, Lighttpd, MariaDB, PHP
  • LLSP Webserver = Linux, Lighttpd, SQlite, PHP
More Info: http://fuzon.co.uk/phpbb/viewtopic.php? ... 1335#p1335
MariaDB based webserver stacks: An alternative to MySql database, by the creators of MySql.
Change Log:
saycheese87
Wed Feb 24, 2016 2:47 pm
Hi Dan,
I've recently installed the Hotspot and purchased a compatible wireless adapter.
the software successfully installed and when i searched for the network on my phone's wifi, Dietpi_Hotspot showed up.
I then changed the SSID and the passkey to something more personalized and restarted the network to apply the changes. After this the network could no longer be found and i have no clue why.
Any tips?
thanks - Ryan
AfouToPatisa
Wed Feb 24, 2016 2:55 pm
Hi Dan,
I'm a big fan of DietPi, and have been using it for quite a while, I think it's the best & most lightweight option for the RPi right now. However, recently I have been getting into microcontrollers and specifically the infamous ESP8266 and I'm amazed at its capabilities combined with its low power consumption (of course I understand that the two boards are targeted to different markets and the RPi runs an entire operating system, but there is some overlap). Power consumption is vital for battery projects and especially now with the RPi Zero, there are many options for such projects.
That said, are there any plans in the horizon for releasing a super-minimal version of DietPi - possibly an AnorexicPi :lol: ?
I feel like there is a niche to cover, especially with the RPi0 out.
fourdee4d
Wed Feb 24, 2016 2:58 pm
saycheese87 wrote:Hi Dan,
Any tips?
thanks - Ryan
Hi Ryan,
Did you set the SSID/KEY in DietPi-Config, or via /etc/hostapd/hostapd.conf? Either way, lets check some settings.
If you can upload/paste the contents of these configuration files, I would be greatful:
cat /etc/hostapd/hostapd.conf
cat /etc/network/interfaces
Also, please paste results of:
ifconfig -a
And lets check the hostapd service state:
service hostapd status
And finally, I need to see your IPtables:
cat /etc/iptables.ipv4.nat
fourdee4d
Wed Feb 24, 2016 3:15 pm
AfouToPatisa wrote:Hi Dan,
Regards,
Bill
HI Bill,
Thanks for the feedback :)
I've always aimed at making DietPi as "minimal as possible" without breaking core features like wifi support, GPIO etc etc.
The DietPi image is already 3x~ smaller than the Official Raspbian Lite image.
See the full DietPi vs Official Raspbian Lite comparision here:
https://docs.google.com/spreadsheets/d/ ... sp=sharing
The only real options we have to make DietPi more "minimal", would be a lightweight Kernel:
The main issues with doing are that knowing what the user would need, do they need GPIO, sound, wifi? There are far too many possible combinations for a near-zero performance benefit and slightly lower memory usage reduction.
You can also do the following to get a little more from your device:
- Disable BCM soundcard. dietpi-config > audio options
- Disable HDMI (headless). dietpi-config > display options > resolution
- If not using WiFi, apt-get purge all wifi related packages
I'am always up for suggestions to make DietPi more optimized. So if you have any ideas on what I could look into, let me know :)
saycheese87
Wed Feb 24, 2016 8:53 pm
Hi Dan,
Please find below copied results;
Also, i used dietpi-config to change the settings.
root@DietPi:~# cat /etc/hostapd/hostapd.conf
interface=wlan0
driver=rtl871xdrv
ssid=Camber_wifi
hw_mode=g
channel=11
macaddr_acl=0
auth_algs=1
ignore_broadcast_ssid=0
wpa=2
wpa_passphrase=230289
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
root@DietPi:~# ifconfig -a
eth0 Link encap:Ethernet HWaddr b8:27:eb:7a:30:ad
inet addr:192.168.0.100 Bcast:192.168.0.255 Mask:255.255.255.0
inet6 addr: fe80::ba27:ebff:fe7a:30ad/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:70272 errors:0 dropped:185 overruns:0 frame:0
TX packets:4916 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:3363736 (3.2 MiB) TX bytes:351609 (343.3 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:24 errors:0 dropped:0 overruns:0 frame:0
TX packets:24 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:2492 (2.4 KiB) TX bytes:2492 (2.4 KiB)
wlan0 Link encap:Ethernet HWaddr f4:f2:6d:1d:2c:36
inet addr:192.168.42.1 Bcast:192.168.42.255 Mask:255.255.255.0
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
root@DietPi:~# service hostapd status
● hostapd.service - LSB: Advanced IEEE 802.11 management daemon
Loaded: loaded (/etc/init.d/hostapd)
Active: active (exited) since Tue 2016-02-23 22:05:17 GMT; 22h ago
Process: 767 ExecStart=/etc/init.d/hostapd start (code=exited, status=0/SUCCESS)
Feb 23 22:05:17 DietPi hostapd[767]: Starting advanced IEEE 802.11 manageme...d!
Feb 23 22:05:17 DietPi systemd[1]: Started LSB: Advanced IEEE 802.11 manage...n.
Hint: Some lines were ellipsized, use -l to show in full.
root@DietPi:~# cat /etc/iptables.ipv4.nat
# Generated by iptables-save v1.4.21 on Tue Feb 23 22:03:42 2016
*nat
:PREROUTING ACCEPT [0:0]
:INPUT ACCEPT [0:0]
:OUTPUT ACCEPT [0:0]
:POSTROUTING ACCEPT [0:0]
-A POSTROUTING -o eth0 -j MASQUERADE
COMMIT
# Completed on Tue Feb 23 22:03:42 2016
*filter
:INPUT ACCEPT [0:0]
:FORWARD ACCEPT [0:0]
-A FORWARD -i eth0 -o wlan0 -m state --state RELATED,ESTABLISHED -j ACCEPT
-A FORWARD -i wlan0 -o eth0 -j ACCEPT
COMMIT
If you need anymore information please let me know.
AfouToPatisa
Thu Feb 25, 2016 10:35 am
fourdee4d
Thu Feb 25, 2016 5:35 pm
saycheese87 wrote:root@DietPi:~# cat /etc/hostapd/hostapd.conf
interface=wlan0
driver=rtl871xdrv
ssid=Camber_wifi
hw_mode=g
channel=11
macaddr_acl=0
auth_algs=1
wpa=2
wpa_pairwise=TKIP
rsn_pairwise=CCMP
Hi Ryan,
The wireless key must be at least 8 characters in length.
There is no sanity check for this, so you must manually ensure its 8 or more characters in length.
I personally use the area code without the zero, then the phone number eg:
1536123456
attachments appear to be broken
Hosted on http://dietpi.com
Once you have changed the wifi key, let me know if the issue is resolved.
saycheese87
Fri Feb 26, 2016 8:51 am
Hi Dan,
Yes this sorted the issue out.
Thank you for your time.
Rich.T.
Sat Feb 27, 2016 1:44 pm
Hey Dan,
I backed Open Energy Monitor's emonPi Kickstarter campaign about a year ago.
https://www.kickstarter.com/projects/op ... energy-mon
I received my device, wired it in, read up on it, set it up, designed a cool dashboard to monitor my electricity usage and various connected sensors, including my ones for my solar panels, temperature, humidity etc. (via their "emonCMS") and then pretty much left it well alone for several months.
https://openenergymonitor.org/emon/
I recently found some time to look in to my problem and discovered that, in my absence, there had been a lot of new development into this project, including adding many new features and (post PiZero) switching to Raspbian Light.
http://openenergymonitor.org/emon/node/12212
One of the new additions caught my attention in a big way: It was the addition of openHAB. The openHAB project seems incredibly useful and very wide-ranging in it's scope and in it's compatibility with many commercial and open-source "Connected Things".
http://www.openhab.org/
It might be worthwhile to take a look at both of the projects I have mentioned and maybe have a chat the these guys about including some of this stuff in DietPi.
They would both fit very well into the "Home Automation" section of the installer.
Thanks,
Rich.
fourdee4d
Sat Feb 27, 2016 2:45 pm
Rich.T. wrote:Hey Dan,
Hi Rich,
Thanks for the info on this. I've seen a few similar projects going around at the moment.
I think all we need to do is add the code to install the emonCMS software: https://github.com/emoncms/emoncms/blob ... /readme.md
An Arduino compatible ATmega328 is used to perform the energy monitoring ADC sampling and power calculations. Data is passed to the Raspberry Pi via its GPIO internal serial port in JeeLabs packet format. Arduino compatible firmware sketches can be uploaded directly to the emonPi's ATmega328 via the Raspberry Pi GPIO.
There's probably some python scripts that we would need for the GPIO stuff. I'll have to do some digging.
If i'am right, shouldn't be too much work to get it into DietPi as emonCMS runs on a basic LAMP stack with a few modifications.
I've created a Git Ticket for this: https://github.com/Fourdee/DietPi/issues/210. If you have any further information , possible contacts and/or anything else that would assist in adding this to DietPi , please let me know :)
fourdee4d
Thu Mar 03, 2016 6:46 pm
v111 Released!
http://DietPi.com
Raspberry Pi 3:
Is now supported in DietPi. Give those 1.2ghz cores some lightweight lovin'. Please grab the updated image from: http://goo.gl/EsIvUp
Change Log:
