MikeDunn
Re: New 8MP Camera - Q&A thread
Sun May 08, 2016 10:27 am
Depends on how old your image is, I believe ...
May be worth building a new one & copying your data across ? Or as a minimum, backing up the SD card before running these !!!
Koepi
Sun May 08, 2016 10:31 am
gordon77 wrote: Do I need both of these...?
sudo apt-get install rpi-update
sudo rpi-update
I've only been using the 2nd.
The first command installs the rpi-update script - it's not installed by default, at least not in the wheezy images or in jessie-lite.
After that it will self-update upon execution, so if something happens after calling rip-update, everything is alright and as expected. :)
gordon77
Sun May 08, 2016 10:43 am
MikeDunn wrote:Depends on how old your image is, I believe ...
My image was the latest raspbian download. I always backup any data etc.
anat
Sun May 08, 2016 10:45 am
Does Camera V2 need the new kernel or other related libraries/firmware? If the latter, I hope there is a different approach to get it without changing the kernel version.
dom
Sun May 08, 2016 11:45 am
anat wrote:Does Camera V2 need the new kernel or other related libraries/firmware? If the latter, I hope there is a different approach to get it without changing the kernel version.
I believe for raspivid/raspistill use the kernel doesn't require updating. But do update firmware (start_x.elf/fixup_x.dat and /opt/vc/). "sudo SKIP_KERNEL=1 rpi-update" should do this.
For V4L2 use you would want to also update the kernel.
9aed
Sun May 08, 2016 3:23 pm
New day, new tests. New results!
This time we look at borders, left and right. There are 4 images, which show that resolution is better near the unit and gets worse further away. The near resolution is so good that couple of images from center area were re-acquired, but those resulted the same findings as last round.
These images are from distances of 0.46 and 3.16 m. They show that the lens is able to to resolve around 1.6 arc minutes on borders at 0.46 m, but then perhaps around 3.4 arc minutes or so at 3.16 m. Both left and right borders are found to be relatively symmetrical, contrary to some initial claims seen here.
If asymmetrical imaging is indeed found, then these cameras differ markedly.
As can be seen, the 0464-images have slightly oval rings, since the targets were not aligned on image plane, but instead normal to line-of-sight. These show the best resolution so far. A bit further away Troy Towns happened on these targets.
So here are the inlined^H^H^H^H^H^H^Htar-file (*) of the results:
LR.tar
(50 KiB) Downloaded 409 times
jbeale wrote:Is that set of resolution rings available as a PDF for download somewhere?
Unfortunately - no. But I think the original PostScript is somewhat yielding for the purpose and nonetheless easier to hack:
%!PS
% 1.46779926762 - 6th root of 10, 1.21152765863 - 12th root of 10
% .215 .261 .316 .383 .464 .562 .681 .825 1 1.21 1.47 1.78
72 25.4 div dup scale
0 setlinecap
/Courier-Bold findfont 5 scalefont setfont
/line_target {
	gsave
	/linescale exch def
		linescale (     ) cvs
		newpath 0 0 moveto dup true charpath flattenpath pathbbox
		pop exch pop sub 2 div 0 11.5 moveto 0 rmoveto show
	} if
	linescale setlinewidth
	0 linescale 2 mul 10 {
		newpath 0 exch 0 exch 0 360 arc closepath stroke
	} for
	grestore
} def
/pattern-collection {
	dup dup scale (     ) cvs
	pop exch pop sub 2 div 0 39 moveto 0 rmoveto show
	gsave 0 21 translate true 0.316 line_target grestore
	gsave -60 rotate 0 21 translate true 0.383 line_target grestore
	gsave -120 rotate 0 21 translate true 0.464 line_target grestore
	gsave -180 rotate 0 21 translate true 0.562 line_target grestore
	gsave -240 rotate 0 21 translate true 0.681 line_target grestore
	gsave -300 rotate 0 21 translate true 0.825 line_target grestore
	false 1 line_target
	newpath
	25 0 moveto 45 0 lineto stroke
	-25 0 moveto -45 0 lineto stroke
	35 5 moveto 35 -5 lineto stroke
	-35 5 moveto -35 -5 lineto stroke
} def
% produce 3 sets of test targets
gsave 70 230 translate 1 pattern-collection grestore
gsave 110 90 translate 2.15 pattern-collection grestore
gsave 150 230 translate 0.464 pattern-collection grestore
showpage
This version is a bit modified, since the smallest targets were not usable and ended up more of a printer test. Central ring now corresponds to size "1". Also, alignment markers might prove to be handy.
So there. The camera is not bad, at a first glance. Can anybody test any "bad" cameras?
(*) Cannot add another attachment, 3 is the maximum. -- forum software
jbeale
Sun May 08, 2016 8:32 pm
9aed wrote:This version is a bit modified, since the smallest targets were not usable and ended up more of a printer test. Central ring now corresponds to size "1". Also, alignment markers might prove to be handy.
Thanks! Here is a PDF version of the PostScript file.
set of 3 groups, ring test pattern: http://www.bealecorner.org/best/RPi/RingTestPattern.pdf
single group, ring test pattern: http://www.bealecorner.org/best/RPi/Cir ... attern.pdf
ring test with corner fiducials: http://www.bealecorner.org/red/test-pat ... attern.pdf
I printed out the "single group" ring pattern PDF above as large as would go on a 8.5x11" sheet of paper. The two T alignment marks are 179 mm apart. I put this target at 2.60 m from the Pi NoIR v2.1 camera and took an image with the target at center of the frame. I took four more images with the camera re-aimed to put the target at upper left, lower left, upper right, and lower right, but all still at the same distance. Center is definitely better. Also, notice how much the scale changes; images at the corner of the frame are magnified relative to the center (pincushion distortion).
Center: Image Upper Left:Image Lower Left:Image Upper Right:Image Lower Right:Image
jbeale
Mon May 09, 2016 12:48 am
Here is the same test done with the v1.3 Pi Camera. Note the color balance changes more, as I point the camera around to get the test pattern into the 4 corners of the frame. However, would say the actual resolved detail in the corners is better with v1.3, and there is less pincushion distortion than on Pi NoIR v2.1. Interestingly, the v1.3 seems to show more detail at LL and UR than in the center.
Note: I assembled these using Picasa Collage and I think it upscaled the image slightly. That won't add any true detail of course, and it will hurt apparent per-pixel sharpness.
Koepi
Mon May 09, 2016 4:07 am
The camera crashes after a few hours after reboot now. I updated to the latest firmware and kernel (4.4.9).
pi@CamPi:~ $ raspistill -o test.jpg
mmal: mmal_vc_component_enable: failed to enable component: ENOSPC
mmal: camera component couldn't be enabled
mmal: main: Failed to create camera component
mmal: Failed to run camera app. Please check for firmware updates
sudo vcdbg malloc:
Pool 0x8f4c5bf8 (ef46454)
Malloc pool size=11M (pool=0xf4c5bf8-0xff7ff2c)
0xf4c5c20 = malloc(128K) [call from 0xee2d496]
0xf4e5c40 = malloc(56)   [call from 0xedcf8ec]
0xf4e6000 = malloc(138K) [call from 0xec969cc]
0xf5095c0 = malloc(512)  [v3d_gfxh16_thre]
0xf5097e0 = malloc(7.3K) [dma_transfer_xfers]
0xf50b500 = malloc(7.0K) [Gencmd service state]
0xf50d140 = malloc(180)  [vcos_cmd_entries]
0xf50d220 = malloc(4.0K) [reaper]
0xf50e240 = malloc(8.0K) [call from 0xeebb1c0]
0xf510260 = malloc(100)  [call from 0xeebb1dc]
0xf510300 = malloc(32K)  [call from 0xed0cd7e]
0xf518320 = malloc(512)  [call from 0xed8a5c2]
0xf518540 = malloc(272)  [call from 0xed0ce6c]
0xf518680 = malloc(272)  [call from 0xed0ce6c]
0xf5187c0 = malloc(272)  [call from 0xed0ce6c]
0xf518900 = malloc(272)  [call from 0xed0ce6c]
0xf518a40 = malloc(272)  [call from 0xed0ce6c]
0xf518b80 = malloc(272)  [call from 0xed0ce6c]
0xf518cc0 = malloc(272)  [call from 0xed0ce6c]
0xf518e00 = malloc(272)  [call from 0xed0ce6c]
0xf518f40 = malloc(272)  [call from 0xed0ce6c]
0xf519080 = malloc(272)  [call from 0xed0ce6c]
0xf5191c0 = malloc(272)  [call from 0xed0ce6c]
0xf519300 = malloc(272)  [call from 0xed0ce6c]
0xf519440 = malloc(272)  [call from 0xed0ce6c]
0xf519580 = malloc(272)  [call from 0xed0ce6c]
0xf5196c0 = malloc(272)  [call from 0xed0ce6c]
0xf519800 = malloc(272)  [call from 0xed0ce6c]
0xf519940 = malloc(272)  [call from 0xed0ce6c]
0xf519a80 = malloc(272)  [call from 0xed0ce6c]
0xf519bc0 = malloc(272)  [call from 0xed0ce6c]
0xf519d00 = malloc(272)  [call from 0xed0ce6c]
0xf519e40 = malloc(272)  [call from 0xed0ce6c]
0xf519f80 = malloc(272)  [call from 0xed0ce6c]
0xf51a0c0 = malloc(272)  [call from 0xed0ce6c]
0xf51a200 = malloc(272)  [call from 0xed0ce6c]
0xf51a340 = malloc(272)  [call from 0xed0ce6c]
0xf51a480 = malloc(272)  [call from 0xed0ce6c]
0xf51a5c0 = malloc(272)  [call from 0xed0ce6c]
0xf51a700 = malloc(272)  [call from 0xed0ce6c]
0xf51a840 = malloc(272)  [call from 0xed0ce6c]
0xf51a980 = malloc(272)  [call from 0xed0ce6c]
0xf51aac0 = malloc(272)  [call from 0xed0ce6c]
0xf51ac00 = malloc(272)  [call from 0xed0ce6c]
0xf51ad40 = malloc(272)  [call from 0xed0ce6c]
0xf51ae80 = malloc(272)  [call from 0xed0ce6c]
0xf51afc0 = malloc(272)  [call from 0xed0ce6c]
0xf51b100 = malloc(272)  [call from 0xed0ce6c]
0xf51b240 = malloc(272)  [call from 0xed0ce6c]
0xf51b380 = malloc(272)  [call from 0xed0ce6c]
0xf51b4c0 = malloc(272)  [call from 0xed0ce6c]
0xf51b600 = malloc(272)  [call from 0xed0ce6c]
0xf51b740 = malloc(272)  [call from 0xed0ce6c]
0xf51b880 = malloc(272)  [call from 0xed0ce6c]
0xf51b9c0 = malloc(272)  [call from 0xed0ce6c]
0xf51bb00 = malloc(272)  [call from 0xed0ce6c]
0xf51bc40 = malloc(272)  [call from 0xed0ce6c]
0xf51bd80 = malloc(272)  [call from 0xed0ce6c]
0xf51bec0 = malloc(272)  [call from 0xed0ce6c]
0xf51c000 = malloc(272)  [call from 0xed0ce6c]
0xf51c140 = malloc(272)  [call from 0xed0ce6c]
0xf51c280 = malloc(272)  [call from 0xed0ce6c]
0xf51c3c0 = malloc(512)  [call from 0xec64b28]
0xf51c5e0 = malloc(16K)  [call from 0xec64b5a]
0xf520600 = malloc(4.0K) [call from 0xec64bb6]
0xf521620 = malloc(4.0K) [call from 0xed67198]
0xf522640 = malloc(4.0K) [call from 0xed671c4]
0xf523660 = malloc(60)   [GPIOMAN_DEFINE_T]
0xf5236c0 = malloc(60)   [GPIOMAN_DEFINE_T]
0xf523720 = malloc(60)   [GPIOMAN_DEFINE_T]
0xf523780 = malloc(60)   [GPIOMAN_DEFINE_T]
0xf5237e0 = malloc(60)   [GPIOMAN_DEFINE_T]
0xf523840 = malloc(60)   [GPIOMAN_DEFINE_T]
0xf5238a0 = malloc(60)   [GPIOMAN_DEFINE_T]
0xf523900 = malloc(60)   [GPIOMAN_DEFINE_T]
0xf523960 = malloc(60)   [GPIOMAN_DEFINE_T]
0xf5239c0 = malloc(60)   [GPIOMAN_DEFINE_T]
0xf523a20 = malloc(60)   [GPIOMAN_DEFINE_T]
0xf523a80 = malloc(60)   [GPIOMAN_DEFINE_T]
0xf523ae0 = malloc(60)   [GPIOMAN_DEFINE_T]
0xf523b40 = malloc(60)   [GPIOMAN_DEFINE_T]
0xf523ba0 = malloc(60)   [GPIOMAN_DEFINE_T]
0xf523c00 = malloc(60)   [GPIOMAN_DEFINE_T]
0xf523c60 = malloc(60)   [GPIOMAN_DEFINE_T]
0xf523cc0 = malloc(60)   [GPIOMAN_DEFINE_T]
0xf523d20 = malloc(60)   [GPIOMAN_DEFINE_T]
0xf523d80 = malloc(60)   [GPIOMAN_DEFINE_T]
0xf523de0 = malloc(60)   [GPIOMAN_DEFINE_T]
0xf523e40 = malloc(60)   [GPIOMAN_DEFINE_T]
0xf523ea0 = malloc(60)   [GPIOMAN_DEFINE_T]
0xf523f00 = malloc(60)   [GPIOMAN_DEFINE_T]
0xf523f60 = malloc(60)   [GPIOMAN_DEFINE_T]
0xf523fc0 = malloc(60)   [GPIOMAN_DEFINE_T]
0xf524020 = malloc(60)   [GPIOMAN_DEFINE_T]
0xf524080 = malloc(60)   [GPIOMAN_DEFINE_T]
0xf5240e0 = malloc(60)   [GPIOMAN_DEFINE_T]
0xf524140 = malloc(8)    [call from 0xec8722a]
0xf524180 = malloc(4.0K) [powerman]
0xf5251a0 = malloc(3.0K) [call from 0xece1e7e]
0xf525dc0 = malloc(356K) [call from 0xece1eb4]
0xf57ede0 = malloc(356K) [call from 0xece1eee]
0xf5d7e00 = malloc(66K)  [call from 0xece1f30]
0xf5e85e0 = malloc(1.1K) [call from 0xee780f0]
0xf5e8a60 = malloc(16K)  [call from 0xec7def0]
0xf5eca80 = malloc(4.0K) [stack]
0xf5edaa0 = malloc(32)   [q]
0xf5edae0 = malloc(32)   [q]
0xf5edb20 = malloc(4.0K) [stack]
0xf5eeb40 = malloc(32)   [q]
0xf5eeb80 = malloc(32)   [q]
0xf5eebc0 = malloc(16K)  [mbox_read]
0xf5f2be0 = malloc(4.0K) [display_update]
0xf5f3c00 = malloc(4.0K) [temp_check]
0xf5f4c20 = malloc(16K)  [vchiq dma_xfer]
0xf5f8ce0 = malloc(16K)  [vchiq dma_xfer]
0xf5fcda0 = malloc(16K)  [vchiq dma_xfer]
0xf600e60 = malloc(16K)  [vchiq dma_xfer]
0xf604f20 = malloc(8.0K) [VCHIQ-0]
0xf606f40 = malloc(8.0K) [VCHIQr-0]
0xf608f60 = malloc(8.0K) [VCHIQs-0]
0xf60af80 = malloc(56)   [imageconv stats]
0xf60afe0 = malloc(36)   [vchiq_shim]
0xf60b040 = malloc(256)  [vchiu_queue_init]
0xf60b160 = malloc(476)  [VCHIQ service]
0xf60b360 = malloc(36)   [vchiq_shim]
0xf60b3c0 = malloc(256)  [vchiu_queue_init]
0xf60b4e0 = malloc(476)  [VCHIQ service]
0xf60b6e0 = malloc(36)   [vchiq_shim]
0xf60b740 = malloc(256)  [vchiu_queue_init]
0xf60b860 = malloc(476)  [VCHIQ service]
0xf60ba60 = malloc(36)   [vchiq_shim]
0xf60bac0 = malloc(256)  [vchiu_queue_init]
0xf60bbe0 = malloc(476)  [VCHIQ service]
0xf60bde0 = malloc(36)   [vchiq_shim]
0xf60be40 = malloc(256)  [vchiu_queue_init]
0xf60bf60 = malloc(476)  [VCHIQ service]
0xf60c160 = malloc(36)   [vchiq_shim]
0xf60c1c0 = malloc(256)  [vchiu_queue_init]
0xf60c2e0 = malloc(476)  [VCHIQ service]
0xf60c4e0 = malloc(36)   [vchiq_shim]
0xf60c540 = malloc(256)  [vchiu_queue_init]
0xf60c660 = malloc(476)  [VCHIQ service]
0xf60c860 = malloc(36)   [vchiq_shim]
0xf60c8c0 = malloc(256)  [vchiu_queue_init]
0xf60c9e0 = malloc(476)  [VCHIQ service]
0xf60cbe0 = malloc(2.0K) [call from 0xeebb1c0]
0xf60d3e0 = malloc(100)  [call from 0xeebb1dc]
0xf60d480 = malloc(4.0K) [GCMD_V]
0xf60e4a0 = malloc(2.0K) [HAUDVCHI]
0xf60ecc0 = malloc(36)   [vchiq_shim]
0xf60ed20 = malloc(256)  [vchiu_queue_init]
0xf60ee40 = malloc(476)  [VCHIQ service]
0xf60f040 = malloc(37K)  [ILCS State]
0xf618340 = malloc(1.0K) [vchiu_queue_init]
0xf618760 = malloc(476)  [VCHIQ service]
0xf618960 = malloc(52)   [ILCS_VC_COMMON]
0xf6189c0 = malloc(4.0K) [ILCS_VC]
0xf6199e0 = malloc(3.0K) [call from 0xee81910]
0xf61a600 = malloc(36)   [vchiq_shim]
0xf61a660 = malloc(256)  [vchiu_queue_init]
0xf61a780 = malloc(476)  [VCHIQ service]
0xf61a980 = malloc(36)   [vchiq_shim]
0xf61a9e0 = malloc(256)  [vchiu_queue_init]
0xf61ab00 = malloc(476)  [VCHIQ service]
0xf61ad00 = malloc(36)   [vchiq_shim]
0xf61ad60 = malloc(256)  [vchiu_queue_init]
0xf61ae80 = malloc(476)  [VCHIQ service]
0xf61b080 = malloc(36)   [vchiq_shim]
0xf61b0e0 = malloc(256)  [vchiu_queue_init]
0xf61b200 = malloc(476)  [VCHIQ service]
0xf61b400 = malloc(36)   [vchiq_shim]
0xf61b460 = malloc(256)  [vchiu_queue_init]
0xf61b580 = malloc(476)  [VCHIQ service]
0xf61b780 = malloc(36)   [vchiq_shim]
0xf61b7e0 = malloc(256)  [vchiu_queue_init]
0xf61b900 = malloc(476)  [VCHIQ service]
0xf61bb00 = malloc(36)   [vchiq_shim]
0xf61bb60 = malloc(256)  [vchiu_queue_init]
0xf61bc80 = malloc(476)  [VCHIQ service]
0xf61be80 = malloc(36)   [vchiq_shim]
0xf61bee0 = malloc(256)  [vchiu_queue_init]
0xf61c000 = malloc(476)  [VCHIQ service]
0xf61c200 = malloc(3.0K) [call from 0xee81984]
0xf61ce20 = malloc(36)   [vchiq_shim]
0xf61ce80 = malloc(256)  [vchiu_queue_init]
0xf61cfa0 = malloc(476)  [VCHIQ service]
0xf61d1a0 = malloc(36)   [vchiq_shim]
0xf61d200 = malloc(256)  [vchiu_queue_init]
0xf61d320 = malloc(476)  [VCHIQ service]
0xf61d520 = malloc(36)   [vchiq_shim]
0xf61d580 = malloc(256)  [vchiu_queue_init]
0xf61d6a0 = malloc(476)  [VCHIQ service]
0xf61d8a0 = malloc(36)   [vchiq_shim]
0xf61d900 = malloc(256)  [vchiu_queue_init]
0xf61da20 = malloc(476)  [VCHIQ service]
0xf61dc20 = malloc(36)   [vchiq_shim]
0xf61dc80 = malloc(256)  [vchiu_queue_init]
0xf61dda0 = malloc(476)  [VCHIQ service]
0xf61dfa0 = malloc(36)   [vchiq_shim]
0xf61e000 = malloc(256)  [vchiu_queue_init]
0xf61e120 = malloc(476)  [VCHIQ service]
0xf61e320 = malloc(36)   [vchiq_shim]
0xf61e380 = malloc(256)  [vchiu_queue_init]
0xf61e4a0 = malloc(476)  [VCHIQ service]
0xf61e6a0 = malloc(36)   [vchiq_shim]
0xf61e700 = malloc(256)  [vchiu_queue_init]
0xf61e820 = malloc(476)  [VCHIQ service]
0xf61ea20 = malloc(60)   [call from 0xedc0c50]
0xf61ea80 = malloc(16K)  [vchiu_queue_init]
0xf622aa0 = malloc(476)  [VCHIQ service]
0xf622ca0 = malloc(60)   [call from 0xedc0c50]
0xf622d00 = malloc(16K)  [vchiu_queue_init]
0xf626d20 = malloc(476)  [VCHIQ service]
0xf626f20 = malloc(60)   [call from 0xedc0c50]
0xf626f80 = malloc(16K)  [vchiu_queue_init]
0xf62afa0 = malloc(476)  [VCHIQ service]
0xf62b1a0 = malloc(476)  [VCHIQ service]
0xf62b3a0 = malloc(320K) [KHRN_S]
0xf67b3c0 = malloc(36)   [vchiq_shim]
0xf67b420 = malloc(256)  [vchiu_queue_init]
0xf67b540 = malloc(476)  [VCHIQ service]
0xf67b740 = malloc(4.0K) [HREQ task]
0xf67c760 = malloc(4.6K) [call from 0xee81a44]
0xf67d9e0 = malloc(4.0K) [FILESERV]
0xf67ea00 = malloc(36)   [vchiq_shim]
0xf67ea60 = malloc(256)  [vchiu_queue_init]
0xf67eb80 = malloc(476)  [VCHIQ service]
0xf67ed80 = malloc(608)  [Shared Memory Service]
0xf67f000 = malloc(4.0K) [sm_thread]
0xf680020 = malloc(36)   [vchiq_shim]
0xf680080 = malloc(256)  [vchiu_queue_init]
0xf6801a0 = malloc(476)  [VCHIQ service]
0xf6803a0 = malloc(488)  [Shared Memory Cache Test]
0xf6805c0 = malloc(4.0K) [smct_thread]
0xf6815e0 = malloc(36)   [vchiq_shim]
0xf681640 = malloc(256)  [vchiu_queue_init]
0xf681760 = malloc(476)  [VCHIQ service]
0xf681960 = malloc(1.3K) [CEA modes table]
0xf681ea0 = malloc(1.7K) [DMT modes table]
0xf6825a0 = malloc(4.0K) [call from 0xee82816]
0xf6835c0 = malloc(36)   [vchiq_shim]
0xf683620 = malloc(256)  [vchiu_queue_init]
0xf683740 = malloc(476)  [VCHIQ service]
0xf683940 = malloc(36)   [vchiq_shim]
0xf6839a0 = malloc(256)  [vchiu_queue_init]
0xf683ac0 = malloc(476)  [VCHIQ service]
0xf683cc0 = malloc(36)   [vchiq_shim]
0xf683d20 = malloc(256)  [vchiu_queue_init]
0xf683e40 = malloc(476)  [VCHIQ service]
0xf684040 = malloc(36)   [vchiq_shim]
0xf6840a0 = malloc(256)  [vchiu_queue_init]
0xf6841c0 = malloc(476)  [VCHIQ service]
0xf6843c0 = malloc(36)   [vchiq_shim]
0xf684420 = malloc(256)  [vchiu_queue_init]
0xf684540 = malloc(476)  [VCHIQ service]
0xf684740 = malloc(36)   [vchiq_shim]
0xf6847a0 = malloc(256)  [vchiu_queue_init]
0xf6848c0 = malloc(476)  [VCHIQ service]
0xf684ac0 = malloc(36)   [vchiq_shim]
0xf684b20 = malloc(256)  [vchiu_queue_init]
0xf684c40 = malloc(476)  [VCHIQ service]
0xf684e40 = malloc(36)   [vchiq_shim]
0xf684ea0 = malloc(256)  [vchiu_queue_init]
0xf684fc0 = malloc(476)  [VCHIQ service]
0xf6851c0 = malloc(4.0K) [call from 0xee82892]
0xf6861e0 = malloc(36)   [vchiq_shim]
0xf686240 = malloc(256)  [vchiu_queue_init]
0xf686360 = malloc(476)  [VCHIQ service]
0xf686560 = malloc(36)   [vchiq_shim]
0xf6865c0 = malloc(256)  [vchiu_queue_init]
0xf6866e0 = malloc(476)  [VCHIQ service]
0xf6868e0 = malloc(36)   [vchiq_shim]
0xf686940 = malloc(256)  [vchiu_queue_init]
0xf686a60 = malloc(476)  [VCHIQ service]
0xf686c60 = malloc(36)   [vchiq_shim]
0xf686cc0 = malloc(256)  [vchiu_queue_init]
0xf686de0 = malloc(476)  [VCHIQ service]
0xf686fe0 = malloc(36)   [vchiq_shim]
0xf687040 = malloc(256)  [vchiu_queue_init]
0xf687160 = malloc(476)  [VCHIQ service]
0xf687360 = malloc(36)   [vchiq_shim]
0xf6873c0 = malloc(256)  [vchiu_queue_init]
0xf6874e0 = malloc(476)  [VCHIQ service]
0xf6876e0 = malloc(36)   [vchiq_shim]
0xf687740 = malloc(256)  [vchiu_queue_init]
0xf687860 = malloc(476)  [VCHIQ service]
0xf687a60 = malloc(36)   [vchiq_shim]
0xf687ac0 = malloc(256)  [vchiu_queue_init]
0xf687be0 = malloc(476)  [VCHIQ service]
0xf687de0 = malloc(4.0K) []
0xf688e00 = malloc(36)   [vchiq_shim]
0xf688e60 = malloc(256)  [vchiu_queue_init]
0xf688f80 = malloc(476)  [VCHIQ service]
0xf689180 = malloc(36)   [vchiq_shim]
0xf6891e0 = malloc(256)  [vchiu_queue_init]
0xf689300 = malloc(476)  [VCHIQ service]
0xf689500 = malloc(36)   [vchiq_shim]
0xf689560 = malloc(256)  [vchiu_queue_init]
0xf689680 = malloc(476)  [VCHIQ service]
0xf689880 = malloc(36)   [vchiq_shim]
0xf6898e0 = malloc(256)  [vchiu_queue_init]
0xf689a00 = malloc(476)  [VCHIQ service]
0xf689c00 = malloc(36)   [vchiq_shim]
0xf689c60 = malloc(256)  [vchiu_queue_init]
0xf689d80 = malloc(476)  [VCHIQ service]
0xf689f80 = malloc(36)   [vchiq_shim]
0xf689fe0 = malloc(256)  [vchiu_queue_init]
0xf68a100 = malloc(476)  [VCHIQ service]
0xf68a300 = malloc(36)   [vchiq_shim]
0xf68a360 = malloc(256)  [vchiu_queue_init]
0xf68a480 = malloc(476)  [VCHIQ service]
0xf68a680 = malloc(36)   [vchiq_shim]
0xf68a6e0 = malloc(256)  [vchiu_queue_init]
0xf68a800 = malloc(476)  [VCHIQ service]
0xf68aa00 = malloc(4.0K) []
0xf68ba20 = malloc(36)   [vchiq_shim]
0xf68ba80 = malloc(256)  [vchiu_queue_init]
0xf68bba0 = malloc(476)  [VCHIQ service]
0xf68bda0 = malloc(36)   [vchiq_shim]
0xf68be00 = malloc(256)  [vchiu_queue_init]
0xf68bf20 = malloc(476)  [VCHIQ service]
0xf68c120 = malloc(36)   [vchiq_shim]
0xf68c180 = malloc(256)  [vchiu_queue_init]
0xf68c2a0 = malloc(476)  [VCHIQ service]
0xf68c4a0 = malloc(36)   [vchiq_shim]
0xf68c500 = malloc(256)  [vchiu_queue_init]
0xf68c620 = malloc(476)  [VCHIQ service]
0xf68c820 = malloc(36)   [vchiq_shim]
0xf68c880 = malloc(256)  [vchiu_queue_init]
0xf68c9a0 = malloc(476)  [VCHIQ service]
0xf68cba0 = malloc(36)   [vchiq_shim]
0xf68cc00 = malloc(256)  [vchiu_queue_init]
0xf68cd20 = malloc(476)  [VCHIQ service]
0xf68cf20 = malloc(36)   [vchiq_shim]
0xf68cf80 = malloc(256)  [vchiu_queue_init]
0xf68d0a0 = malloc(476)  [VCHIQ service]
0xf68d2a0 = malloc(36)   [vchiq_shim]
0xf68d300 = malloc(256)  [vchiu_queue_init]
0xf68d420 = malloc(476)  [VCHIQ service]
0xf68d620 = malloc(36)   [vchiq_shim]
0xf68d680 = malloc(256)  [vchiu_queue_init]
0xf68d7a0 = malloc(476)  [VCHIQ service]
0xf68d9a0 = malloc(36)   [vchiq_shim]
0xf68da00 = malloc(256)  [vchiu_queue_init]
0xf68db20 = malloc(476)  [VCHIQ service]
0xf68dd20 = malloc(36)   [vchiq_shim]
0xf68dd80 = malloc(256)  [vchiu_queue_init]
0xf68dea0 = malloc(476)  [VCHIQ service]
0xf68e0a0 = malloc(36)   [vchiq_shim]
0xf68e100 = malloc(256)  [vchiu_queue_init]
0xf68e220 = malloc(476)  [VCHIQ service]
0xf68e420 = malloc(36)   [vchiq_shim]
0xf68e480 = malloc(256)  [vchiu_queue_init]
0xf68e5a0 = malloc(476)  [VCHIQ service]
0xf68e7a0 = malloc(36)   [vchiq_shim]
0xf68e800 = malloc(256)  [vchiu_queue_init]
0xf68e920 = malloc(476)  [VCHIQ service]
0xf68eb20 = malloc(36)   [vchiq_shim]
0xf68eb80 = malloc(256)  [vchiu_queue_init]
0xf68eca0 = malloc(476)  [VCHIQ service]
0xf68eea0 = malloc(36)   [vchiq_shim]
0xf68ef00 = malloc(256)  [vchiu_queue_init]
0xf68f020 = malloc(476)  [VCHIQ service]
0xf68f220 = malloc(476)  [VCHIQ service]
0xf68f420 = malloc(476)  [VCHIQ service]
0xf68f620 = malloc(476)  [VCHIQ service]
0xf68f820 = malloc(476)  [VCHIQ service]
0xf68fa20 = malloc(476)  [VCHIQ service]
0xf68fc20 = malloc(476)  [VCHIQ service]
0xf68fe20 = malloc(476)  [VCHIQ service]
0xf690020 = malloc(476)  [VCHIQ service]
0xf690220 = malloc(476)  [VCHIQ service]
0xf690420 = malloc(476)  [VCHIQ service]
0xf690620 = malloc(4.3K) [mmal debug log]
0xf691760 = malloc(16K)  [mmal_host_log]
0xf6957a0 = malloc(512)  [vchiu_queue_init]
0xf6959b0 = hole(504)
0xf695bc0 = malloc(40)   [call from 0xedd9faa]
0xf695c20 = malloc(40)   [call from 0xedd9faa]
0xf695c80 = malloc(40)   [call from 0xedd9faa]
0xf695ce0 = malloc(40)   [call from 0xedd9faa]
0xf695d40 = malloc(40)   [call from 0xedd9faa]
0xf695da0 = malloc(40)   [call from 0xedd9faa]
0xf695e00 = malloc(40)   [call from 0xedd9faa]
0xf695e60 = malloc(40)   [call from 0xedd9faa]
0xf695ec0 = malloc(40)   [call from 0xedd9faa]
0xf695f20 = malloc(40)   [call from 0xedd9faa]
0xf695f80 = malloc(40)   [call from 0xedd9faa]
0xf695fe0 = malloc(40)   [call from 0xedd9faa]
0xf696040 = malloc(40)   [call from 0xedd9faa]
0xf6960a0 = malloc(40)   [call from 0xedd9faa]
0xf696100 = malloc(40)   [call from 0xedd9faa]
0xf696160 = malloc(40)   [call from 0xedd9faa]
0xf6961c0 = malloc(40)   [call from 0xedd9faa]
0xf696220 = malloc(40)   [call from 0xedd9faa]
0xf696280 = malloc(40)   [call from 0xedd9faa]
0xf6962e0 = malloc(40)   [call from 0xedd9faa]
0xf696340 = malloc(40)   [call from 0xedd9faa]
0xf6963a0 = malloc(256)  [mmal msg queue mem]
0xf6964c0 = malloc(4.0K) [mmal msg queue ]
0xf6974e0 = malloc(4.0K) [mmal msg queue ]
0xf698500 = malloc(4.0K) [mmal worker]
0xf699520 = malloc(476)  [VCHIQ service]
0xf699720 = malloc(4.0K) [vc watchdog]
0xf69a740 = malloc(476)  [VCHIQ service]
0xf69a930 = hole(67K)
0xf6ab740 = malloc(164)  [call from 0xed820c2]
0xf6ab820 = malloc(164)  [call from 0xed820c2]
0xf6ab900 = malloc(164)  [call from 0xed820c2]
0xf6ab9e0 = malloc(164)  [call from 0xed820c2]
0xf6abab0 = hole(8.8M)
Malloced:1.8M Remaining:8.9M
sudo vcdbg reloc:
Relocatable heap version 4 found at 0x8000000
total space allocated is 108M, with 108M relocatable, 0 legacy and 0 offline
0 legacy blocks of size 2359296
free list at 0xeb74920
107M free memory in 1 free block(s)
largest free block is 107M bytes
0x8000000: free 107M
[   4] 0xeb74940: used  576 (refcount 1 lock count 0, size      512, align    4, data 0xeb74960, d0rual) 'ILCS VC buffer pool'
[   3] 0xeb74b80: used 537K (refcount 1 lock count 8, size   545792, align 4096, data 0xeb75000, d3rual) 'ARM FB'
[   2] 0xebfafa0: used  16K (refcount 1 lock count 0, size    16384, align   32, data 0xebfafc0, d0ruAl) 'audioplus_tmp_buf'
[   1] 0xebfefe0: used 4.0K (refcount 1 lock count 0, size        0, align 4096, data 0xebff000, d1rual) 'camera fast alloc arena'
small allocs not requested
sudo vcdbg log msg:
000824.524: HDMI:EDID error reading EDID block 0 attempt 0
000825.787: HDMI:EDID error reading EDID block 0 attempt 1
000827.045: HDMI:EDID error reading EDID block 0 attempt 2
000828.304: HDMI:EDID error reading EDID block 0 attempt 3
000829.562: HDMI:EDID error reading EDID block 0 attempt 4
000830.820: HDMI:EDID error reading EDID block 0 attempt 5
000832.078: HDMI:EDID error reading EDID block 0 attempt 6
000833.336: HDMI:EDID error reading EDID block 0 attempt 7
000834.594: HDMI:EDID error reading EDID block 0 attempt 8
000835.853: HDMI:EDID error reading EDID block 0 attempt 9
000836.874: HDMI:EDID giving up on reading EDID block 0
000839.805: HDMI:Setting property pixel encoding to Default
000839.825: HDMI:Setting property pixel clock type to PAL
000839.845: HDMI:Setting property content type flag to No data
000839.865: HDMI:Setting property fuzzy format match to enabled
000879.212: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
000879.237: hdmi: HDMI:>>>>>>>>>>>>>Rx sensed, reading EDID<<<<<<<<<<<<<
000879.626: hdmi: HDMI:EDID error reading EDID block 0 attempt 0
000880.894: hdmi: HDMI:EDID error reading EDID block 0 attempt 1
000882.162: hdmi: HDMI:EDID error reading EDID block 0 attempt 2
000883.425: hdmi: HDMI:EDID error reading EDID block 0 attempt 3
000884.688: hdmi: HDMI:EDID error reading EDID block 0 attempt 4
000885.951: hdmi: HDMI:EDID error reading EDID block 0 attempt 5
000887.214: hdmi: HDMI:EDID error reading EDID block 0 attempt 6
000888.477: hdmi: HDMI:EDID error reading EDID block 0 attempt 7
000889.740: hdmi: HDMI:EDID error reading EDID block 0 attempt 8
000891.003: hdmi: HDMI:EDID error reading EDID block 0 attempt 9
000892.029: hdmi: HDMI:EDID giving up on reading EDID block 0
000892.060: hdmi: HDMI: No lookup table for resolution group 0
000892.077: hdmi: HDMI: hotplug attached with DVI support
000892.139: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
000892.505: hdmi: HDMI:EDID error reading EDID block 0 attempt 0
000893.768: hdmi: HDMI:EDID error reading EDID block 0 attempt 1
000895.030: hdmi: HDMI:EDID error reading EDID block 0 attempt 2
000896.292: hdmi: HDMI:EDID error reading EDID block 0 attempt 3
000897.554: hdmi: HDMI:EDID error reading EDID block 0 attempt 4
000898.816: hdmi: HDMI:EDID error reading EDID block 0 attempt 5
000900.078: hdmi: HDMI:EDID error reading EDID block 0 attempt 6
000901.340: hdmi: HDMI:EDID error reading EDID block 0 attempt 7
000902.602: hdmi: HDMI:EDID error reading EDID block 0 attempt 8
000903.865: hdmi: HDMI:EDID error reading EDID block 0 attempt 9
000904.890: hdmi: HDMI:EDID giving up on reading EDID block 0
000904.953: hdmi: HDMI: hotplug deassert
000904.969: hdmi: HDMI: HDMI is currently off
000904.983: hdmi: HDMI: changing mode to unplugged
000905.005: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
000905.803: *** Restart logging
000907.209: Read command line from file 'cmdline.txt'
dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
001148.518: Loading 'kernel.img' to 0x8000 size 0x3edbd0
001152.157: Kernel trailer DTOK property says yes
001152.173: Kernel trailer DDTK property says yes
001154.583: Loading 'bcm2708-rpi-b-plus.dtb' to 0x3f5bd0 size 0x2e3f
001195.935: dtparam: pwr_led_gpio=35
001201.369: dtparam: uart0_clkrate=3000000
001210.056: dtparam: audio=on
001216.038: dtparam: i2c_arm=on
001252.703: dtparam: arm_freq=700000000
001254.631: Unknown dtparam 'arm_freq' - ignored
001254.666: dtparam: core_freq=250000000
001261.197: dtparam: cache_line_size=32
001274.924: Device tree loaded to 0x7fecc00 (size 0x338b)
001276.188: gpioman: gpioman_get_pin_num: pin SDCARD_CONTROL_POWER not defined
003845.568: vchiq_core: vchiq_init_state: slot_zero = 0x47880000, is_master = 1
003849.949: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
064393.660: camsubs: Looking for camera 0: i2c_port = 0, led gpio = 32, power enable gpio = 41
064395.288: camsubs: Camera found OK
064397.395: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
066853.163: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
098609.116: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
159089.097: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
218918.345: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
278655.963: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
398521.301: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
458883.948: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
519525.641: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
579109.657: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
638639.630: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
698770.351: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
758794.336: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
819276.691: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
879378.187: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
938762.698: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
999310.048: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1058829.262: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1119314.817: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1178637.201: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1238946.728: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1299328.531: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1358660.056: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1419572.913: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1478775.834: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1539157.119: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1598429.507: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1658991.393: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1719585.747: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1778812.250: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1839178.463: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1898714.402: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1959055.617: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2019553.148: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2139506.529: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2198775.182: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2259312.423: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2318964.932: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2379003.054: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2439438.491: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2498894.488: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2558649.444: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2619043.894: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2679142.198: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2739249.530: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2798638.816: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2859069.720: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2918856.055: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2978774.979: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3039039.055: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3099423.357: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3158751.050: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3219037.716: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3278797.871: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3339131.226: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3399136.390: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3458701.763: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3519410.457: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3578867.455: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3638609.981: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3699240.164: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3758749.729: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3819662.431: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3879225.484: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3938778.180: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3999013.690: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4058589.124: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4119275.162: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4179312.218: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4238736.368: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
004241.388: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
064460.072: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
124055.183: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
184272.118: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
243854.792: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
304278.154: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
364389.439: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
424109.519: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
484309.834: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
543760.442: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
604327.338: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
663695.113: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
724504.596: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
784417.348: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
843999.049: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
904321.046: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
963854.575: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1024493.660: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1083926.180: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1144714.017: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1204596.272: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1264439.563: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1324531.281: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1384788.149: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1444009.004: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1504000.699: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1564628.531: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1624698.908: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1684367.901: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1744674.475: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1804601.784: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1864568.308: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1924705.043: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1983983.354: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2043962.653: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2104623.430: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2164604.603: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2224648.118: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2284117.518: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2344765.610: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2404380.283: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2463854.779: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2524355.584: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2584215.159: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2644547.532: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2703916.060: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2763871.995: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2824208.252: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2884255.823: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2944363.136: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3004495.204: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3064705.817: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3124117.436: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3183904.141: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3244090.290: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3304267.960: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3364567.665: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3425072.050: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3484077.710: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3544201.578: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3604273.725: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3664348.827: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3724735.871: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3784470.705: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3844660.030: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3904805.116: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3963909.219: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4024994.772: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4122754.511: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4183237.732: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4242690.997: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
008217.607: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
067964.458: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
127473.316: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
187926.876: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
247414.381: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
307919.642: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
367571.527: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
428064.701: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
487582.910: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
548065.293: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
607515.630: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
668231.356: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
727717.616: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
788318.758: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
847835.477: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
908560.959: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
968407.585: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1028095.912: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1087821.180: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1148252.469: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1207695.643: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1268447.818: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1327925.770: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1387396.766: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1447869.963: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1507388.204: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1568053.023: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1627502.110: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1687990.767: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1747516.840: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1807984.891: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1867652.627: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1928142.814: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1987596.539: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2048083.273: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2107598.337: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2168240.330: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2227687.742: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2288173.734: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2347688.611: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2408147.709: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2467810.321: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2528298.410: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2587748.317: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2648233.049: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2707743.375: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2768416.677: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2827859.086: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2888346.251: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2947856.767: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3008311.504: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3067991.721: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3127510.093: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3187982.244: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3247457.507: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3307944.585: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3367687.724: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3428153.827: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3487607.169: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3548114.615: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3607596.956: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3668282.411: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3727794.565: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3788266.202: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3847718.707: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3908243.488: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3967981.995: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4027466.416: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4087911.780: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4147396.963: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4207884.308: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4268594.447: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
033138.480: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
092809.179: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
153269.210: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
272756.584: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
333226.770: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
392669.195: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
453149.693: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
512665.071: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
573325.493: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
632797.084: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
693292.574: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
752744.063: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
813224.845: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
872954.236: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
932473.040: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
992941.572: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1053425.870: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1112926.391: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1173584.458: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1233079.891: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1292593.607: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1353064.274: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1412499.754: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1473218.323: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1532710.950: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1593164.194: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1652582.873: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1713059.352: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1772742.297: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1833202.287: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1892704.208: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1953149.690: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2012580.609: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2073296.547: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2132793.710: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2193244.745: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2252674.761: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
I did yet another complete fresh install, this time on a 16GB MicroSD card, as the fresh install on a 8GB crashed two days ago and left the file system broken; e2fsck ran two hours and left a mostly empty SDcard behind. So the system is clean, everything is fresh from scratch, no modifications.
I have a DS3231 as RTC added via a kernel module, this is different "from factory". Two further I2C sensors are polled directly via python/i2c and don't influence the kernel.
The Pi seems otherwise stable - and was with the old cam. My data logging (temp/humidity/pressure/luminosity) runs stable since fresh installation, no missed measurements (it runs every 5 minutes).
I use wifi for network connection, a rtl8192cu stick. Power supply still has a lot of headroom for supplying other devices with power, but only the Pi A+ is connected.
My webcam script is still the same. Every minute I take a photo via cronjob.
During daytime this call:
raspistill -mm spot -n -t 1500 -q 82 -w 1920 -h 1080 -o $FILE
In the night time:
raspistill -mm matrix -ISO 800 -ev 6 -ss 4000000 -t 1500 -n -q 82 -w 1920 -h 1080 -o $FILE
It stopped working at 4:50 p.m. already yesterday, which I fixed by reboot at 7p.m.. Then it stopped again at 11:49p.m. - I noticed after sleep, so debug data is now from 5:50a.m.
I hope this helps debugging why it keeps crashing. Thanks!
gkreidl
Mon May 09, 2016 6:07 am
Test of the new V2 camera compared with V1 (and other cameras and Iphone 5). It's in German, but there's a slide show with lots of example pictures.
http://www.heise.de/make/artikel/Raspbe ... 98015.html
Minimal Kiosk Browser (kweb)
jbeale
Mon May 09, 2016 6:25 am
They do some nice tests, but has their camera expert has tested many fixed-focus cameras? Looks like the lab tests were all done at close range? The largest problem (in my opinion) with the new 8MP v2.1 camera is that the fixed-focus is soft for more distant objects. I see they do confirm their sample of the v2 camera is not as good in the corners, even at close range.
Koepi
Mon May 09, 2016 6:35 am
The test was done from 93cm (v1.3) and due to the bigger FoV at 73cm with the V2 cam to get the same area.
That's of course something different when compared to "infinity focus" scenarios, but it gives some hints and clues.
Edit: https://translate.google.com/ will work quite well for the article.
Ongelma
Mon May 09, 2016 7:36 am
new camera board mounting holes (4 holes) are different size in diameter and thus this reason wont stay in place on my camera cases... bummer.
Koepi
Mon May 09, 2016 12:47 pm
Again, this time at 14:38h - camera crashes after a few hours after reboot.
uname -a:
Linux CamPi 4.4.9+ #884 Fri May 6 17:25:37 BST 2016 armv6l GNU/Linux
sudo vcdbg malloc:
0xf6959c0 = malloc(476)  [VCHIQ service]
0xf69a730 = hole(68K)
sudo vcdbg reloc:
sudo vcdbg log msg:
001084.977: HDMI:EDID error reading EDID block 0 attempt 0
001086.240: HDMI:EDID error reading EDID block 0 attempt 1
001087.498: HDMI:EDID error reading EDID block 0 attempt 2
001088.757: HDMI:EDID error reading EDID block 0 attempt 3
001090.014: HDMI:EDID error reading EDID block 0 attempt 4
001091.273: HDMI:EDID error reading EDID block 0 attempt 5
001092.531: HDMI:EDID error reading EDID block 0 attempt 6
001093.789: HDMI:EDID error reading EDID block 0 attempt 7
001095.048: HDMI:EDID error reading EDID block 0 attempt 8
001096.306: HDMI:EDID error reading EDID block 0 attempt 9
001097.327: HDMI:EDID giving up on reading EDID block 0
001100.259: HDMI:Setting property pixel encoding to Default
001100.279: HDMI:Setting property pixel clock type to PAL
001100.299: HDMI:Setting property content type flag to No data
001100.319: HDMI:Setting property fuzzy format match to enabled
001139.623: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
001139.648: hdmi: HDMI:>>>>>>>>>>>>>Rx sensed, reading EDID<<<<<<<<<<<<<
001140.037: hdmi: HDMI:EDID error reading EDID block 0 attempt 0
001141.305: hdmi: HDMI:EDID error reading EDID block 0 attempt 1
001142.570: hdmi: HDMI:EDID error reading EDID block 0 attempt 2
001143.833: hdmi: HDMI:EDID error reading EDID block 0 attempt 3
001145.096: hdmi: HDMI:EDID error reading EDID block 0 attempt 4
001146.359: hdmi: HDMI:EDID error reading EDID block 0 attempt 5
001147.622: hdmi: HDMI:EDID error reading EDID block 0 attempt 6
001148.885: hdmi: HDMI:EDID error reading EDID block 0 attempt 7
001150.148: hdmi: HDMI:EDID error reading EDID block 0 attempt 8
001151.411: hdmi: HDMI:EDID error reading EDID block 0 attempt 9
001152.437: hdmi: HDMI:EDID giving up on reading EDID block 0
001152.468: hdmi: HDMI: No lookup table for resolution group 0
001152.485: hdmi: HDMI: hotplug attached with DVI support
001152.546: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
001152.913: hdmi: HDMI:EDID error reading EDID block 0 attempt 0
001154.175: hdmi: HDMI:EDID error reading EDID block 0 attempt 1
001155.437: hdmi: HDMI:EDID error reading EDID block 0 attempt 2
001156.699: hdmi: HDMI:EDID error reading EDID block 0 attempt 3
001157.961: hdmi: HDMI:EDID error reading EDID block 0 attempt 4
001159.223: hdmi: HDMI:EDID error reading EDID block 0 attempt 5
001160.485: hdmi: HDMI:EDID error reading EDID block 0 attempt 6
001161.747: hdmi: HDMI:EDID error reading EDID block 0 attempt 7
001163.009: hdmi: HDMI:EDID error reading EDID block 0 attempt 8
001164.272: hdmi: HDMI:EDID error reading EDID block 0 attempt 9
001165.297: hdmi: HDMI:EDID giving up on reading EDID block 0
001165.360: hdmi: HDMI: hotplug deassert
001165.375: hdmi: HDMI: HDMI is currently off
001165.389: hdmi: HDMI: changing mode to unplugged
001165.411: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
001166.210: *** Restart logging
001167.626: Read command line from file 'cmdline.txt'
001408.937: Loading 'kernel.img' to 0x8000 size 0x3edbd0
001412.576: Kernel trailer DTOK property says yes
001412.591: Kernel trailer DDTK property says yes
001415.001: Loading 'bcm2708-rpi-b-plus.dtb' to 0x3f5bd0 size 0x2e3f
001456.353: dtparam: pwr_led_gpio=35
001461.787: dtparam: uart0_clkrate=3000000
001470.475: dtparam: audio=on
001476.457: dtparam: i2c_arm=on
001513.023: dtparam: arm_freq=700000000
001514.943: Unknown dtparam 'arm_freq' - ignored
001514.986: dtparam: core_freq=250000000
001521.518: dtparam: cache_line_size=32
001535.247: Device tree loaded to 0x7fecc00 (size 0x338b)
001536.511: gpioman: gpioman_get_pin_num: pin SDCARD_CONTROL_POWER not defined
004100.581: vchiq_core: vchiq_init_state: slot_zero = 0x47880000, is_master = 1
004104.931: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
063927.528: camsubs: Looking for camera 0: i2c_port = 0, led gpio = 32, power enable gpio = 41
063929.156: camsubs: Camera found OK
063931.261: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
066369.204: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
102429.650: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
163026.788: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
222094.828: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
283072.453: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
342631.647: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
402370.261: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
462207.478: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
522204.684: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
582435.528: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
642862.456: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
702780.964: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
762465.266: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
822271.072: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
882685.442: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
942868.660: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1002846.233: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1062862.444: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1122873.504: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1183086.942: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1242430.033: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1302479.196: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1362612.673: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1422728.583: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1483100.099: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1542587.030: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1602632.747: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1662651.558: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1722980.047: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1782731.555: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1842404.289: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1902539.671: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1962657.038: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2022539.420: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2082957.542: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2142381.950: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2202360.644: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2262372.045: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2322316.512: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2382787.073: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2442454.071: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2502699.019: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2562326.723: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2622475.918: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2682897.477: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2742640.863: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2802827.365: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2863050.358: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2922174.986: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2982985.697: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3042784.326: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3103016.950: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3162171.083: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3222687.810: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3283215.185: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3342627.414: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3402826.096: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3463030.093: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3522160.261: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3582821.202: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3642290.356: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3702738.561: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3763028.722: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3822153.607: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3882947.840: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3942420.193: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4002841.816: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4062169.101: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4122871.718: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4183350.783: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4242755.064: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
008154.306: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
067325.348: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
127638.090: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
188115.224: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
247746.607: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
308044.648: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
367209.610: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
427872.253: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
487843.217: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
547236.718: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
607769.143: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
668042.008: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
727266.121: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
788025.286: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
847576.843: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
907843.315: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
968063.062: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1028115.313: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1087755.733: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1147307.153: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1207602.692: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1267799.581: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1328117.925: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1387577.455: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1447595.506: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1507818.925: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1568046.640: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1628158.572: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1687834.611: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1747399.034: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1807676.553: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1867850.098: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1928086.563: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1987481.109: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2048185.465: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2107324.511: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2167626.518: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2227824.729: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2288335.946: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2347812.053: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2408047.367: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2467203.671: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2527743.926: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2588157.566: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2647654.214: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2707873.840: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2768100.541: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2827250.332: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2887859.143: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3007955.704: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3067186.418: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3127463.437: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3188051.924: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3247526.869: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3367754.855: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3427940.399: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3488484.485: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3547907.356: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3608169.873: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3667319.426: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3727563.994: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3788045.326: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3847572.937: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3907805.983: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3968057.468: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4027271.575: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4087966.978: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4147487.652: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4207761.561: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4267971.556: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
033144.630: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
092780.346: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
152368.024: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
212923.099: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
273165.790: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
332309.762: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
393125.447: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
452659.617: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
513006.555: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
572297.029: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
632696.177: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
693288.481: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
752786.020: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
813188.890: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
872315.524: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
932911.707: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
993413.514: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1052937.825: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1112260.604: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1172824.582: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1233016.516: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1293588.798: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1352352.007: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1412857.085: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1473225.803: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1593447.391: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1596476.916: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1652875.351: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1713154.860: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1772554.970: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1832910.747: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1893485.716: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1952888.027: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2012328.900: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2072945.534: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2132277.800: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2193030.833: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2252567.930: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2312778.590: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2373010.805: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2433214.303: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2492713.192: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2552337.532: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2613035.958: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2673273.404: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2732501.272: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2792972.067: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2852504.305: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2912737.560: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2973002.597: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3033182.994: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3092622.843: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3153091.027: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3212356.867: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3272882.246: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3333136.788: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3392725.111: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3452310.099: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3512719.978: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3572918.862: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3633146.641: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3692509.033: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3753115.940: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3812343.400: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3872948.825: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3933197.584: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3992688.652: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4053176.478: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4112328.944: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4172786.936: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4233019.787: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4293550.967: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
058011.748: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
118305.294: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
177466.359: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
237984.327: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
298532.628: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
357936.042: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
418240.923: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
477458.456: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
537738.870: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
598203.528: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
657672.410: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
717971.056: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
778155.120: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
837347.289: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
897985.041: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
957692.725: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1017879.112: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1078144.615: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1137399.368: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1198214.771: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1257737.245: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1318040.557: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1378242.472: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1437359.574: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1497955.260: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1557502.113: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1617772.444: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1677980.470: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1738241.707: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1797686.999: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1858281.698: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1917596.608: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1977857.954: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2038154.110: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2097623.728: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2158113.522: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2218339.807: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2277491.050: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2337780.846: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2398262.748: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2457744.931: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2518007.819: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2578313.189: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2637446.062: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2698336.585: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2757932.084: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2817944.470: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2878138.013: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2938351.923: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2997827.070: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3058311.099: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3117469.886: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3177760.404: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3237956.848: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3298498.002: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3357945.967: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3418181.818: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3477398.650: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3537698.008: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3598171.200: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3657639.803: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3717886.097: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3778165.273: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3838350.955: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3897777.748: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3957795.378: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4018087.173: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4078285.817: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4137649.193: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4198178.551: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4257654.444: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
022919.053: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
083192.569: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
143212.244: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
202641.050: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
263255.868: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
322481.084: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
383068.718: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
443288.940: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
502820.284: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
563372.735: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
622521.248: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
683097.035: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
743365.191: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
802677.920: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
863342.769: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
922489.437: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
983005.850: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1043267.462: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1103668.914: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1163105.709: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1223397.983: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1282481.578: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1342878.760: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1403322.970: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1463120.873: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1523310.783: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1582502.821: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1642990.228: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1703506.827: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1763004.671: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1823236.905: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1882562.200: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1942875.550: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2003289.918: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2062666.147: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2122899.515: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2183103.909: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2243299.653: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2302815.202: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2362643.584: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2422961.184: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2483187.063: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2542576.222: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2603131.879: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2662866.610: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2723051.662: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2783288.940: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2842498.196: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2903052.136: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2962609.571: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3022925.165: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3083084.194: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3143329.819: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3202834.627: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3263265.815: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3323488.872: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3382696.739: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3442920.445: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3503446.247: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3562933.983: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3623140.420: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3683389.717: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3742706.365: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3803321.535: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3862811.460: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3923066.274: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3983319.408: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4042503.599: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4103325.292: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4162823.108: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4223028.869: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4283219.111: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
048486.724: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
107922.341: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
167558.703: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
228077.612: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
288315.103: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
348498.835: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
408801.040: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
468203.894: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
528612.488: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
587824.495: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
648015.098: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
708505.099: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
768035.337: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
828169.958: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
888403.628: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
947547.517: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1008341.369: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1068072.397: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1128330.807: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1188495.121: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1248516.852: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1308082.833: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1368442.371: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1427599.232: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1488007.676: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1548035.029: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1608515.703: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1668518.365: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1727625.779: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1788106.035: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1848071.468: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1908645.349: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1968030.077: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2028208.600: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2088463.397: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2148514.300: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2207925.458: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2268376.108: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2328523.032: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2387641.226: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2447951.814: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2508382.092: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2567870.404: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2628063.658: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2688188.092: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2748336.756: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2808774.863: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2868486.137: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2927537.864: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2987812.272: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3048027.894: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3108426.725: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3167887.988: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3228083.938: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3288401.653: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3348520.610: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3407937.407: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3468431.892: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3527648.994: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3588292.502: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3648412.996: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3707758.727: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3768397.169: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3828512.366: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3887569.403: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3947817.985: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4008290.280: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4067783.344: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4128096.485: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4188279.915: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4248224.043: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
013713.754: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
073290.327: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
133547.302: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
193575.576: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
252635.679: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
313414.129: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
372835.353: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
432927.647: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
493086.791: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
553319.503: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
613767.901: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
673163.713: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
733294.874: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
793402.554: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
853561.859: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
913014.884: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
973460.706: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1033597.043: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1092635.289: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1153169.361: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1213543.994: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1273046.077: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1333259.085: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1393393.646: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1453575.254: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1512884.921: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1573411.907: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1633503.298: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1693575.279: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1752714.110: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1813134.169: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1872605.133: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1932745.258: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
1992948.722: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2053029.666: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2113484.065: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2172924.706: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2233025.906: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2293126.733: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2353293.458: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2413617.198: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2473028.304: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2533232.297: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2593405.883: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2653509.148: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2713813.163: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2773235.167: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2833310.394: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2893488.574: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
2953605.092: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3012976.907: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3073560.579: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3133637.727: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3192757.513: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3253307.727: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3313732.087: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3373165.919: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3433418.807: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3493541.002: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3553589.410: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3613027.729: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3673453.150: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3733566.954: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3792682.778: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3853146.675: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3913558.413: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
3973007.887: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4033187.015: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4093284.512: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4153433.528: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4213864.792: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
4273407.760: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
038575.941: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
098663.416: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
157749.326: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
218098.657: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
277749.698: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
338141.504: gpioman: gpioman_get_pin_num: pin CAMERA_LED not defined
free -h:
             total       used       free     shared    buffers     cached
Mem:          117M        99M        18M        12M        16M        55M
-/+ buffers/cache:        27M        90M
Swap:          99M         0B        99M
df -h:
Dateisystem    Gr▒▒e Benutzt Verf. Verw% Eingeh▒ngt auf
/dev/root        15G    1,1G   13G    8% /
devtmpfs         55M       0   55M    0% /dev
tmpfs            59M       0   59M    0% /dev/shm
tmpfs            59M     13M   47M   21% /run
tmpfs           5,0M    4,0K  5,0M    1% /run/lock
tmpfs            59M       0   59M    0% /sys/fs/cgroup
/dev/mmcblk0p1   60M     21M   40M   35% /boot
uptime:
 14:48:40 up  8:38,  1 user,  load average: 0,01, 0,04, 0,05
sudo reboot && exit
doesn't work either. It leaves the machine in unreachable state. I need to pull the power plug and restart the hard way (my wife was at home and could do that, else it would have taken some more hours to access the Pi again).
Looks ugly on my data logging. :( I hope there is something obvious which can be easily solved.
Gavinmc42
Re: New 8MP Camera - Q&A thread
Mon May 09, 2016 1:17 pm
Power brown out?
What model Pi is it connected to?
or a memory leak?
Lots of voltage regs on the back of the pcb, 2.8,1.8,1.2V.
Bad or temperature sensitive capacitor?
Someone used Y5U instead of X7R? C7, C8?
I'm dancing on Rainbows.
Mon May 09, 2016 1:26 pm
@Koepi: So your RH and temperature sensors die at the same time? That's indicative of you doing something very bad. Even if the GPU dies (and that's what I suspect you've managed to do), that shouldn't kill off (I'm guessing) I2C access to your sensors to cause zeroes in your graphs.
Please try adding "start_debug=1" to config.txt, and "sudo vcdbg log asserts" when it dies.
Koepi
Mon May 09, 2016 1:43 pm
6by9: Oops, sorry, I chose a bad example - that "@esp01" indicates this sensor is connected via wifi (esp8266/model 01 of those boards). The BME280 directly on the Pi seems to continue to read data, but the BH1750 has a spike downwards (which could be coinciding with the "reboot by removing the power plug" time).
Edit3: These sensors look like this ...
I'll add the debug switches when I get home, hopefully it is possible to see something then.
As that Pi runs headless I can't tell if the reboot works at all or if it just kills the Wifi interface. As the crashes take many hours to occur it is hard to figure out a nice setup to catch it in the right time and to see what's going on. Maybe I should investigate the UART interface - but the Pi is in a bad position to work locally on it (in the kitchen window ... ;) )
Edit: Ok, added the start_debug=1 entry to config.txt and rebooted. Interestingly, in such a "fresh state", reboot works without issues, the Wifi answers exactly 30 seconds after the restart command to ping again.
Edit2: A more complete picture of the sensors - Pressure/Illuminance are directly on the Pi's i2c bus.
Sensors overview (no break @RasPi)
Sorry for causing such a confusion. It's about the raspistill program not being able to capture images after a few hundred calls on my Pi A+. I think I can rule out those three i2c sensors as cause for this behaviour. I will report back with the logs from "sudo vcdbg log asserts" as soon as this happens again.
CaptSunset
Mon May 09, 2016 3:15 pm
gordon77 wrote:
Koepi wrote:You seem to miss:
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install rpi-update
sudo rpi-update
-> Reboot
You obviously still use an old kernel or packages:
Gordon
I'm getting a little confused myself by now; will the older camera module still operate predictably on Pi's that are updated for the v2, on both the 2B & 3B?
&... What about the PiTFT hacks for screen hats? I think some are still based on Wheezy.
CaptSunset
Mon May 09, 2016 3:32 pm
Most of you prob'ly already know this, but in case not, this seems to be the best place to mention that
US-based Adafruit does carry various length Pi camera flex cables- from 2" to 2 meters.
https://www.adafruit.com/?q=Raspberry%2 ... ra%20cable&
On the same page, they also have a Pi 'spy camera' that is only the size of the module, not the circuit board of the official camera. PRODUCT ID: 1937
Some interesting maker tutorials too. They are into 3D printing & cosplay creations as well.
Unsolicited testimonal, btw.
Mon May 09, 2016 3:35 pm
CaptSunset wrote:I'm getting a little confused myself up now; will the older camera module still operate predictably on Pi's that are updated for the v2, on both the 2B & 3B?
Yes, the old camera is still fully supported. The GPU knows the different I2C addresses and ID registers, and will use the correct driver for the sensors found.
CaptSunset wrote:&... What about the PiTFT hacks for screen hats? I think some are still based on Wheezy.
Depends on how those have been done. Probably, as long as they can run with the latest firmware/kernel combination, and don't mess around with things like i2c-0.
If you're still stuck on wheezy, then you may get away with just updating the firmware, just don't complain if it doesn't work.
CaptSunset
Mon May 09, 2016 4:01 pm
6by9 wrote: Yes
Thanks 6x9; consider yourself liked! ;)
Looks like I'm going to have to start Change Logging myself...
kmoto
Mon May 09, 2016 4:41 pm
I did a quick side-by-side sharpness/focus comparison of the old V1 and new V2 cameras. Objects are 5 ft from the cameras. V1 resolution is 2592x1944, V2 is 3280x2464. I cropped the image to show more detail. In my opinion, the new V2 camera is substantially worse than the old V1. Very disappointing.
I suggest opening the two photos in separate browser windows so it is easy to click back and forth between them.
https://www.dropbox.com/s/oltrjagbh2d4h ... d.jpg?dl=0
https://www.dropbox.com/s/s1g8allj2v69w ... d.jpg?dl=0
caerandir
New 8MP Camera - Q&A thread - Feature request
Mon May 09, 2016 8:18 pm
Dear all,
I just got today the new 8MP camera, one normal and one NoIR. Quick test result (no in depth testing yet): Both work well with me, no unsharpness - on the contrary: The sharpness as compared to the 5MP module is considerably better! I realized the the angular size of a pixel with both cameras is about the same (8MP camera having a larger FOV), so the images can be compared very well. Also the colors are much more natural with the new module, but that's mainly software I suppose. I'll do some more detailed tests perhaps on the weekend - since I own several 5MP's and the two new 8MP's there should be some "statistics" ;) Will possibly post some example images.
Another remark: Along with the delivery came the 2m camera cable from Adafruit - the new camera works well with it. Runs now since two hours without any glitch.
One thing however I'd suggest as a feature for raspistill and raspivid: I'd appreciate if - like with omxplayer's --display option - you could throw the image from the cam to the HDMI output while the DSI display is connected and the primary/X display. Since this is mainly GPU stuff, I'd guess that should not bee to complicated, is it?
Cheers,
Caerandir
jbeale
Re: New 8MP Camera - Q&A thread - Feature request
Mon May 09, 2016 8:26 pm
caerandir wrote:I just got today the new 8MP camera, one normal and one NoIR. Quick test result (no in depth testing yet): Both work well with me, no unsharpness - on the contrary: The sharpness as compared to the 5MP module is considerably better!
Congratulations! It seems you got a good one. Would it be possible to post a full-res 8 MP image somewhere, so that we can admire it? Hopefully including some distant objects towards the edges of the frame?
caerandir
Mon May 09, 2016 9:36 pm
With quite some disappointment I need to revise my previous post - when digging out the camera modules I own, I realized that obviously one of them - the one I started testing with - is a "China knockoff": viewtopic.php?f=43&t=81500 - it was sold to me as the genuine article; I'm shocked - have to dig out the bill and see if anything can be done.
Picking a genuine v1 camera, image sharpness is indeed way better as compared to v2, at least in low light coming from two 60 Watts incandecent bulbs. However, dynamic range is somewhat better with the Sony module.
Still, will do exhaustive tests on the weekend and will post images then.
Return to “Camera board”
