cjan
Re: Guide: Chromium 50 on Raspbian Jessie
Sun May 29, 2016 1:08 am
kusti8 wrote:
cjan wrote:/etc/chromium-browser/default can not add 2 options? flashplugin was gone.
Did you add a space? Can you paste the file?
CHROMIUM_FLAGS="--ppapi-flash-path=/usr/lib/chromium-browser/plugins/libpepflashplayer.so --ppapi-flash-version=21.0.0.182-r1 -password-store=detect -user-data-dir"
CHROMIUM_FLAGS="--disable-gpu"
kusti8
Sun May 29, 2016 3:14 am
Remove the second line and add --disable-gpu to the first at the end with a space. You're overwriting the first with the second so it doesn't work.
shadowbyte
Mon May 30, 2016 4:10 am
Has Chromium been added officially at this point?
For some reason I was able to do an apt-get update and apt-get install chromium-browser tonight successfully.
It's fast and makes using the Raspberry Pi on the web feel normal again.
Shadow
gkreidl
Mon May 30, 2016 10:09 am
shadowbyte wrote:Has Chromium been added officially at this point?
Shadow
Check your sources.list
It's not in any of the main repositories.
Minimal Kiosk Browser (kweb)
Zofiel
Mon May 30, 2016 1:21 pm
Any idea to fix Speech synthesis API (Text To Speech) ?
thanks in advance!
kusti8
Mon May 30, 2016 9:12 pm
Zofiel wrote:Hi,
thanks in advance!
See this discussion:
viewtopic.php?p=964842#p964842
Zofiel
Tue May 31, 2016 12:09 pm
kusti8 wrote:
Zofiel wrote:Hi,
thanks in advance!
yes, I reviewed this post before reply. I have the same problem, SpeakIt works one time, after that I have to restart the browser to work It again.
JumpZero
Tue May 31, 2016 6:25 pm
Hi kusti8,
Thanks and congratulations for you work: awesome!
For my 8th Pi (a Pi 3) I decided it was time to try the GUI (all my others Pi are running headless, text only). I then followed your instructions to install Chromium. Everything smooth even it opens for first time on the page to install your youtube plugin. So easy to install and browsing the web on Pi 3 is perfectly acceptable.
100% good :D
Jmp0
gkreidl
Tue May 31, 2016 7:24 pm
By default Speakit uses some kind of web service. It may have some usage limitations. And sometimes it takes a long time to start at all.
acrogenesis
Wed Jun 01, 2016 8:10 am
Hi @kusti8, with the release of chromium v50 video loading on websites and animations have started to stutter where it didn't before. Do you know if there's something I have to change or how to fix this?
I've rolled back to v49 and it's working great again.
sudo apt-get install chromium-browser=49.0.2623.108-0ubuntu0.14.04.1.1113 chromium-codecs-ffmpeg-extra=49.0.2623.108-0ubuntu0.14.04.1.1113
gkreidl
Wed Jun 01, 2016 8:33 am
acrogenesis wrote:Hi @kusti8, with the release of chromium v50 video loading on websites and animations have started to stutter where it didn't before. Do you know if there's something I have to change or how to fix this?
Try this fix:
viewtopic.php?f=66&t=148452
bobbybouwmann
Wed Jun 01, 2016 9:22 am
I'm getting these errors since this morning when I ran the command below? Something wrong after updating maybe?
sudo apt-get install chromium-browser rpi-youtube -y
E: Failed to fetch http://dl.bintray.com/kusti8/chromium-rpi/pool/main/c/chromium-codecs-ffmpeg-extra/chromium-codecs-ffmpeg-extra_50.0.2661.102-0ubuntu0.14.04.1.1117_armhf.deb  rename failed, Structure needs cleaning (/var/cache/apt/archives/partial/chromium-codecs-ffmpeg-extra_50.0.2661.102-0ubuntu0.14.04.1.1117_armhf.deb -> /var/cache/apt/archives/chromium-codecs-ffmpeg-extra_50.0.2661.102-0ubuntu0.14.04.1.1117_armhf.deb).
E: Failed to fetch http://dl.bintray.com/kusti8/chromium-rpi/pool/main/c/chromium-browser/chromium-browser_50.0.2661.102-0ubuntu0.14.04.1.1118_armhf.deb  rename failed, Structure needs cleaning (/var/cache/apt/archives/partial/chromium-browser_50.0.2661.102-0ubuntu0.14.04.1.1118_armhf.deb -> /var/cache/apt/archives/chromium-browser_50.0.2661.102-0ubuntu0.14.04.1.1118_armhf.deb).
E: Failed to fetch http://dl.bintray.com/kusti8/chromium-rpi/pool/main/c/chromium-browser-l10n/chromium-browser-l10n_50.0.2661.102-0ubuntu0.14.04.1.1118_armhf.deb  rename failed, Structure needs cleaning (/var/cache/apt/archives/partial/chromium-browser-l10n_50.0.2661.102-0ubuntu0.14.04.1.1118_all.deb -> /var/cache/apt/archives/chromium-browser-l10n_50.0.2661.102-0ubuntu0.14.04.1.1118_all.deb).
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/w/webkitgtk/libjavascriptcoregtk-1.0-0_2.4.9-1~deb8u1+rpi1_armhf.deb  rename failed, Structure needs cleaning (/var/cache/apt/archives/partial/libjavascriptcoregtk-1.0-0_2.4.9-1~deb8u1+rpi1_armhf.deb -> /var/cache/apt/archives/libjavascriptcoregtk-1.0-0_2.4.9-1~deb8u1+rpi1_armhf.deb).
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libm/libmbim/libmbim-glib4_1.10.0-2.1_armhf.deb  rename failed, Structure needs cleaning (/var/cache/apt/archives/partial/libmbim-glib4_1.10.0-2.1_armhf.deb -> /var/cache/apt/archives/libmbim-glib4_1.10.0-2.1_armhf.deb).
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/m/modemmanager/libmm-glib0_1.4.0-1_armhf.deb  rename failed, Structure needs cleaning (/var/cache/apt/archives/partial/libmm-glib0_1.4.0-1_armhf.deb -> /var/cache/apt/archives/libmm-glib0_1.4.0-1_armhf.deb).
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libq/libqmi/libqmi-glib1_1.10.2-2_armhf.deb  rename failed, Structure needs cleaning (/var/cache/apt/archives/partial/libqmi-glib1_1.10.2-2_armhf.deb -> /var/cache/apt/archives/libqmi-glib1_1.10.2-2_armhf.deb).
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/w/webkitgtk/libwebkitgtk-1.0-common_2.4.9-1~deb8u1+rpi1_all.deb  rename failed, Structure needs cleaning (/var/cache/apt/archives/partial/libwebkitgtk-1.0-common_2.4.9-1~deb8u1+rpi1_all.deb -> /var/cache/apt/archives/libwebkitgtk-1.0-common_2.4.9-1~deb8u1+rpi1_all.deb).
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/w/webkitgtk/libwebkitgtk-1.0-0_2.4.9-1~deb8u1+rpi1_armhf.deb  rename failed, Structure needs cleaning (/var/cache/apt/archives/partial/libwebkitgtk-1.0-0_2.4.9-1~deb8u1+rpi1_armhf.deb -> /var/cache/apt/archives/libwebkitgtk-1.0-0_2.4.9-1~deb8u1+rpi1_armhf.deb).
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/g/geoclue-2.0/geoclue-2.0_2.1.10-2_armhf.deb  rename failed, Structure needs cleaning (/var/cache/apt/archives/partial/geoclue-2.0_2.1.10-2_armhf.deb -> /var/cache/apt/archives/geoclue-2.0_2.1.10-2_armhf.deb).
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/libm/libmbim/libmbim-proxy_1.10.0-2.1_armhf.deb  rename failed, Structure needs cleaning (/var/cache/apt/archives/partial/libmbim-proxy_1.10.0-2.1_armhf.deb -> /var/cache/apt/archives/libmbim-proxy_1.10.0-2.1_armhf.deb).
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/m/modemmanager/modemmanager_1.4.0-1_armhf.deb  rename failed, Structure needs cleaning (/var/cache/apt/archives/partial/modemmanager_1.4.0-1_armhf.deb -> /var/cache/apt/archives/modemmanager_1.4.0-1_armhf.deb).
E: Failed to fetch http://dl.bintray.com/kusti8/chromium-rpi/pool/main/r/rpi-youtube/rpi-youtube_5.0.1-1.deb  rename failed, Structure needs cleaning (/var/cache/apt/archives/partial/rpi-youtube_5.0.1-1_armhf.deb -> /var/cache/apt/archives/rpi-youtube_5.0.1-1_armhf.deb).
E: Aborting install.
kusti8
Wed Jun 01, 2016 11:07 am
Do you have enough space? Something is wrong with your filesystem and it may be corrupted. Try starting new.
torekk
Contact: ICQ
Thu Jun 02, 2016 9:11 am
How would I go about if I want to basically disable chromium's cache to reduce disk usage? I already tried the "--disk-dir-cache-size=N" flag with no effect and then just simply set ".cache/chromium" to read-only, which seems to work, but I don't know if that's the proper way.
kusti8
Thu Jun 02, 2016 11:10 am
torekk wrote:How would I go about if I want to basically disable chromium's cache to reduce disk usage? I already tried the "--disk-dir-cache-size=N" flag with no effect and then just simply set ".cache/chromium" to read-only, which seems to work, but I don't know if that's the proper way.
That seems the only way, but are you sure you're seeing significant disk usage from caching ?
torekk
Contact: ICQ
Thu Jun 02, 2016 5:06 pm
kusti8 wrote:That seems the only way, but are you sure you're seeing significant disk usage from caching ?
I'm not sure, but as long as chromium runs the green LED flashes more frequently than it does when I close chromium. I'm also using the Pi as a desktop replacement, so I'm basically trying to increase the lifetime of the SD card until I get an external harddrive.
kusti8
Thu Jun 02, 2016 7:06 pm
I wouldn't worry about it. Good SD cards last a long time and I doubt this will make any difference.
gkreidl
Thu Jun 02, 2016 8:25 pm
All browsers cache a lot (though kweb has an option to disable caching, but it will slow down web access) and it is a wear on the SD card. My first SD card started to wear out after about 6 months. That's when I decided to move the root file system to a HDD. All my RPis are running from HDD now; it's much faster and more reliable - and much more disk space / $ (and I always need a lot).
kusti8
Thu Jun 02, 2016 8:26 pm
Huh. I wish Chromium had such an option.
gkreidl
Thu Jun 02, 2016 8:30 pm
kusti8 wrote:Huh. I wish Chromium had such an option.
Perhaps you can find something in chrome://flags
cjan
Re: Guide: Chromium 49 on Raspbian Jessie
Fri Jun 03, 2016 3:17 am
gkreidl wrote:
cjan wrote:[
btw, youtube can not forward play.
This used to work with 49, so maybe there's a bug in this version/build.
this bother me a lot, can be fix?
kusti8
Fri Jun 03, 2016 3:19 am
cjan wrote:
gkreidl wrote:
cjan wrote:[
What is forward play?
gkreidl
Fri Jun 03, 2016 3:38 am
cjan wrote:
gkreidl wrote:
cjan wrote:[
Please explain, what you mean. Moving inside the video? I don't have any problem with that.
cjan
Fri Jun 03, 2016 5:19 am
gkreidl wrote:Please explain, what you mean. Moving inside the video? I don't have any problem with that.
forward play, jump to next time scope...?
gkreidl
Fri Jun 03, 2016 5:26 am
No problem for me. It works as it should. Move the slider to a new position and it starts playing from there.
