That should be simple.
What is the gap (in microseconds) between one channel and the next?
Currently there will be glitches from one frame to the next when the channels are changed but I know how to stop them.
Re: New pigpio Python module
well it's not expensive, but i fear with python you'll have some "lag" between the input and the output. But you have to try to understand how muchpickledgator wrote:Yea, I'm basically spoofing a controller signal from the rpi. To generate the 27ms frame, it'll have to run at ~37 Hz. Are the waveform generations expensive?
second question: what is the input of your spoofed controller?
you have to send the frame 37 times a second, but if you want to create a simil "real time" controller you also have to sample the input 37 times a second..
again, it's a matter of how much delay you can accept
but i'm quite curious of the result..
@joan: In implementation, we will want the total signal pulse + pause pulse to equal the desired channel width. We are actually only interested in the combined time; the signal to pause ratio lengths don't actually matter as the receiver is just looking for time between leading edges. So for example, a min command would be a total of 1000 microseconds, perhaps 500 pulse + 500 pause. A max command would be 2000 microseconds, perhaps 1500 pulse, 500 pause. But the ppm signal (from a receiver parsing standpoint) would be equivalent to min: 50 signal, 950 pause, max: 50 signal, 1950 pause. This page describes that process: https://sourceforge.net/p/arduinorclib/ ... %20Signal/. For sake of argument, let's pick a pause of 500 microseconds, but I assume it would be some type of parameter that can be adjusted.
@Massi: The input commands are coming from an xbox controller over a USB connection to the rpi using the linux driver. The joystick/button commands are interrupt driven, and populate a persistent input state, which is then run through some algorithms and converted to 8 signals (1000-2000 microseconds). The output thread will be separate from the input thread to ensure that the output commands/pigpio are run as deterministically as possible (may have to hack on the kernel a bit to reduce the OS interrupts, we'll see). I'm planning to release the code on github when it's done. The goal for the project is to utilize an xbox controller that mimics a standard RC controller. The BOM is only about $100 and would make for a controller that is smaller than most available on the market (e.g, taranis, turnigy, etc.).
You need a gap between the channels otherwise you can't tell the channel pulse length.
In this example code I have used 100µs as it is easily visible.
On my Pi Zero I can do 120 updates a second.
With the current pigpio there will be glitches when a channel is updated but it should give you the idea.
#!/usr/bin/env python
# PPM.py
# 2016-02-16
# Public Domain
import pigpio
class X:
GAP=100
WAVES=3
def __init__(self, pi, gpio, channels=8, frame_ms=27):
self.pi = pi
self.gpio = gpio
if frame_ms < 5:
frame_ms = 5
channels = 2
elif frame_ms > 100:
frame_ms = 100
self.frame_us = int(frame_ms * 1000)
if channels < 1:
channels = 1
elif channels > (frame_ms // 2):
channels = int(frame_ms // 2)
self.channels = channels
self._widths = [1000] * channels # set each channel to minimum pulse width
self._wid = [None]*self.WAVES
self._next_wid = 0
pi.write(gpio, pigpio.LOW)
def _update(self):
wf =[]
micros = 0
for i in self._widths:
wf.append(pigpio.pulse(0, 1<<self.gpio, self.GAP))
wf.append(pigpio.pulse(1<<self.gpio, 0, i))
micros += (i+self.GAP)
# off for the remaining frame period
wf.append(pigpio.pulse(0, 1<<self.gpio, self.frame_us-micros))
self.pi.wave_add_generic(wf)
wid = self.pi.wave_create()
self.pi.wave_send_repeat(wid)
self._wid[self._next_wid] = wid
print("create", self._next_wid, "with", wid)
self._next_wid += 1
if self._next_wid >= self.WAVES:
self._next_wid = 0
wid = self._wid[self._next_wid]
if wid is not None:
print("delete", self._next_wid, "with", wid)
self.pi.wave_delete(wid)
self._wid[self._next_wid] = None
def update_channel(self, channel, width):
self._widths[channel] = width
self._update()
def update_channels(self, widths):
self._widths[0:len(widths)] = widths[0:self.channels]
self._update()
def cancel(self):
self.pi.wave_tx_stop()
for i in self._wid:
if i is not None:
self.pi.wave_delete(i)
if __name__ == "__main__":
import time
import PPM
import pigpio
pi = pigpio.pi()
if not pi.connected:
exit(0)
ppm = PPM.X(pi, 6)
updates = 0
start = time.time()
for chan in range(8):
for pw in range(1000, 2000, 5):
ppm.update_channel(chan, pw)
updates += 1
time.sleep(0.03)
end = time.time()
secs = end - start
print("{} updates in {:.1f} seconds ({}/s)".format(updates, secs, int(updates/secs)))
ppm.update_channels([1000, 2000, 1000, 2000, 1000, 2000, 1000, 2000])
time.sleep(2)
ppm.cancel()
pi.stop()
@Joan, Thanks for this. It's very helpful. If I'm understanding correctly, I would want to generate the waveform from channels as an array of pulses, then call wave_create() which builds the wave form from the previous add functions. Then call wave_send_repeat() until I have a channel update. I suppose the tricky part you mentioned is that if I get a channel update, we need to wait until the current wave form is done sending before calling wave_delete() and building/sending the new modified wave form from the new channels? Looks like waiting for wave_tx_busy() would do the trick. Does that sound correct?
Spent some time rearchitecting the PPM class for my needs. Mainly, I separated the send and update calls into asynchronous methods. I'm hoping Joan can comment on whether or not it's smart to utilize wave_send_once for every update, by waiting on the wave_tx_busy() to clear. I'm guessing that strategy is not as efficient as wave_send_repeat(), but for my application, the send_once integrates better. Timing shows that I'm losing ~1ms every 130 frames or so. Not sure how that impacts the waveforms. I don't have an oscope handy and wasn't able to get the pre-built binaries of piscope to run (gtk errors), so I don't have any way to visualize the wave forms right now. The PPM code is available here: https://github.com/pickledgator/xboxrc/ ... ter/PPM.py. Open to comments/suggestions.
You can see the waveforms with piscope.
I have made the changes needed to pigpio to allow synchronisation with the current waveform. Depending on what I do with the documentation and other minor changes I may push V46 out today or tomorrow. In either case I'll post with the needed changes to the PPM code.
Using a repeated waveform is almost certainly the correct way to work. Send once and checking for completion will be subject to all sorts of jitter which will possibly confuse the receiver.
Great, looking forward to the synchronization mods. Thanks again for the help with this.joan wrote:I have made the changes needed to pigpio to allow synchronisation with the current waveform. Depending on what I do with the documentation and other minor changes I may push V46 out today or tomorrow. In either case I'll post with the needed changes to the PPM code.
Here is the code altered for V46.
There is one new function - wave_send_using_mode.
I have moved the update delay into the class and based it on the frame time. This means you can't update more often than the frame time (pointless) or delete a waveform before it has been used (bad).
# PPM.py
# 2016-02-18
# Public Domain
import time
import pigpio
class X:
GAP=100
WAVES=3
self.pi = pi
self.gpio = gpio
if frame_ms < 5:
frame_ms = 5
channels = 2
frame_ms = 100
self.frame_ms = frame_ms
self._frame_us = int(frame_ms * 1000)
self._frame_secs = frame_ms / 1000.0
if channels < 1:
channels = 1
self._next_wid = 0
self._update_time = time.time()
def _update(self):
wf =[]
micros = 0
wf.append(pigpio.pulse(0, 1<<self.gpio, self._frame_us-micros))
self.pi.wave_send_using_mode(wid, pigpio.WAVE_MODE_REPEAT_SYNC)
self._next_wid += 1
self._next_wid = 0
remaining = self._update_time + self._frame_secs - time.time()
if remaining > 0:
time.sleep(remaining)
if wid is not None:
self._update()
self._update()
def cancel(self):
for i in self._wid:
if i is not None:
import time
import PPM
import pigpio
pi = pigpio.pi()
exit(0)
pi.wave_tx_stop() # Start with a clean slate.
ppm = PPM.X(pi, 6, frame_ms=20)
updates = 0
start = time.time()
updates += 1
end = time.time()
secs = end - start
time.sleep(2)
ppm.cancel()
pi.stop()
Hello joan,
as always, this is not strictly a question regarding the python module, but the pigpio library itself
i was looking at the bb_i2c_open function (i've 3 ssd1306 displays, so one is spare
) and i haven't understood if this function creates a "fake" i2c bus (to be used with standard i2c functions) or it is only intended to be used with the bb_i2c_zip function
i suspect the case is the second, since the common i2c_open takes only 0 and 1 as bus..
is this cpu intensive?
thanks
thanks
The bb_i2c_open/close/zip functions must be used as a unit and allows arbitrary GPIO to be used for I2C. The i2c_* functions all use the standard Linux I2C driver which only allows the "proper" GPIO.Massi wrote:Hello joan,
i was looking at the bb_i2c_open function (i've 3 ssd1306 displays, so one is spare) and i haven't understood if this function creates a "fake" i2c bus (to be used with standard i2c functions) or it is only intended to be used with the bb_i2c_zip function
thanks
I haven't done any timings. They will be CPU intensive if you run at anything over 10 kbps (at least I think so, as I said I haven't actually done any timings). Of course they are only intensive while actually talking to a device.
Ok, very clear.joan wrote:The bb_i2c_open/close/zip functions must be used as a unit and allows arbitrary GPIO to be used for I2C. The i2c_* functions all use the standard Linux I2C driver which only allows the "proper" GPIO.
So the way is the i2c-0 bus
Joan,
i'm doing some testing with dt overlay and i2c muxes, so that now my sistem is full of i2c buses.
BUT
i've now discovered that pigpio i2c functions accept only 0 and 1 for i2c bus
is this something can be corrected easily?
thanks
BUT
thanks
You probably need to change #define PI_NUM_I2C_BUS 2 (pigpio.h) to some larger value depending on your multiplexor. You will need to re-make/install.
Perfect!
thanks
thanks
From V53 I've removed the bus number check so you no longer need to make that #define change (in fact the #define will no longer exist).Massi wrote:Perfect!
thanks
An error will be returned if you try to open a non-existent bus.
That's good, thanksjoan wrote:From V53 I've removed the bus number check so you no longer need to make that #define change (in fact the #define will no longer exist).Massi wrote:Perfect!
thanks
in my "to do list when i do not know what to do" there is a modification to pigpio to be able to show the list of open handles
and i do not know how to code it
Not so sure about that. What are you going to do when you get the list?Massi wrote: ...
in my "to do list when i do not know what to do" there is a modification to pigpio to be able to show the list of open handlesit should not be hard knowing how to code it
well, take i2c handlesjoan wrote:Not so sure about that. What are you going to do when you get the list?Massi wrote: ...
it's a number (handle id) connected with another number (device address) and another one (bus number)
Since it's a common problem when i'm testing something and i do not want to spend time with the try - except - finally code to use all handles and get the "no handles available" error, my idea was to have the possibility to show the handles list.
Then i can choose to close some unused handles, or to take back one of them and use again it..
For sure:
- this is not changing life using pigpio
- it will be much faster to do a pigpiod restart
- probably it's completely useless on production code (i've the handle's management in all the finally branch of my code)
But you know, that's for fun
I just do
for ((i=0;i<32;i++)); do pigs i2cc $i; done
I'm trying to do PWM with hardware_PWM on a Pi3
My problem is the PWM remains when the program has finished but I want it to stop. Also if I stop it manually by cleaning up the GPIO the program won't restart it when I run it again, I have to kill pigpio first then rerun it.
import time
import pigpio
pi = pigpio.pi()
import RPi.GPIO as GPIO
GPIO.setwarnings(0)
GPIO.setmode(GPIO.BCM)
GPIO.setup(18, GPIO.OUT)
pi.hardware_PWM(18, 1000, 250000) # 10kHz 25% dutycycle
time.sleep(5)
pi.stop() # Disconnect from Pi
If you want PWM to stop when you exit the script then you will have to stop it before exiting the script. pigpio does not guess your intentions.PlanB wrote: ...
In your script the following will switch hardware PWM on GPIO18 off.
pi.hardware_PWM(18, 0, 0)
You can stop it outside the script with the command
pigs hp 18 0 0
Could you give details about "Also if I stop it manually by cleaning up the GPIO the program won't restart it when I run it again, I have to kill pigpio first then rerun it.". What did you do?
thnx Joan, my sin was not using pi.hardware_PWM(18, 0, 0). I was forcing gpio18 low with a GPIO.output to stop the pwm & I couldn't restart pwm by rerunning the program because I didn't use pi.hardware_PWM(18, 0, 0) to end the previous instance.
Hey I like the ultra fine granularity I can potentially get with the 1 million steps for dutycycle with pi.hardware_PWM(gpio, frequency, dutycycle), just wondering why set_PWM_dutycycle(user_gpio, dutycycle) only has 255 steps? Is that an older version?
Lastly I've had a few crashes where pigpiod hasn't started for whatever reason, I get an error msg asking me if I've started the pigpio daemon but my program won't exit with ctrl c & I have to reboot. Is there a get-out-of-jail equivalent of hp 18 0 0 for this situation too?
There are two hardware PWM channels (on GPIO 12/18, 13/19). They provide the most flexible PWM. You will get precisely one million steps if the frequency is 250 Hz. More steps for lower frequencies, less steps for higher frequencies (steps is actually 250 million / frequency).PlanB wrote:thnx Joan, my sin was not using pi.hardware_PWM(18, 0, 0). I was forcing gpio18 low with a GPIO.output to stop the pwm & I couldn't restart pwm by rerunning the program because I didn't use pi.hardware_PWM(18, 0, 0) to end the previous instance.
The PWM on the other GPIO is timed with the DMA hardware and is restricted in its resolution (the details are specific to the implementation) but defaults to 800Hz and 250 steps (scaled to 255).
Only one copy of the pigpio daemon may be running at a time. Errors are invariably down to trying to restart the daemon (lock file exists) or trying to restart it before the previous network connection has timed out.
Do you have a repeatable failure example?
Perhaps try ctrl Z, then ps to find the script process id, kill -9 process id, fg (to go back), as an alternative to reboot.
So 25000 steps at 10kHz. Does that mean my PID loop should increment the duty cycle in blocks of 40 between 0 & 1000000?
dc=dc+40
pi.hardware_PWM(18, 10000, dc)
