My first post.
I'm attempting to use VLANs on my Ethernet interfaces for my Raspberry Pi running Raspbian Jessie. The VLAN interfaces will work if I manually configure the interfaces using ifconfig. I cannot reboot the Pi and have the interfaces remain.
From studying postings I know the old way of doing this is to add entries into /etc/network/interfaces. This file apparently is not read by default now.
I can successfully set a static IP for eth0 for example by adding lines to the end of dhcpcd.conf.
interface eth0
static ip_address=192.168.178.28/24
I cannot set VLAN interfaces or I don't know the proper syntax. I've tried coping the above changing to something like interface eth0.2 with no success.
How can this be done now with dhcpcd.conf? If not how do I change things such that /etc/network/interfaces is used?
I've looked around and haven't found an answer to this specific question. Any help would be appreciated.
Re: Raspbian Jessie VLAN dhcpd
I was having the same problem. New to Pi stuff I am building a home DNS/DHCP/NTP server from my old Pi model B. Not being new to Debian/Ubuntu/etc I was trying to set up two VLAN interfaces on eth0 and, while I got it to work, it was also requesting dynamic DHCP addresses for eth0, eth0.x and eth0.y and I wanted to stop that.
Much hair pulling and Googling later, I came across Pi2 gets static IP but also DHCP IP is assigned which gave me the answer - the raspberrypi-net-mods package and it's new network method of using Marple's dhcpcd.
So... in order to do the now "correct" thing of leaving /etc/network/interfaces alone and modifying /etc/dhcpcd.conf I came up with this. You still modify /etc/network/interfaces, but not as much. What you have to do is use it to create the VLAN interfaces so the dhcpcd can manipulate them.
So in /etc/network/interfaces, add lines to create your VLAN interfaces:
Now in your /etc/dhcpcd.conf append the following:
Changing the above x's and y's to whatever value you need.
Check the dhcpcd and dhcpcd.conf man pages for other options you can use.
# VLAN x Interface
auto eth0.x
iface eth0.x inet manual
vlan-raw-device eth0
# VLAN y Interface
auto eth0.y
iface eth0.y inet manual
# Leave Physical interface alone
denyinterfaces eth0
# Static IP configuration for VLan x and y
interface eth0.x
static ip_address=xxx.xxx.xxx.xxx/mm
static routers=xxx.xxx.xxx.xxx
static domain_name_servers=xxx.xxx.xxx.xxx
interface eth0.y
static ip_address=yyy.yyy.yyy.yyy/mm
static routers=yyy.yyy.yyy.yyy
static domain_name_servers=yyy.yyy.yyy.yyy
John H. Reinhardt
