PiiPatient
PiFi DAC+ V2.0
Mon Feb 16, 2015 7:53 pm
]Hi, I was wondering if anyone knew of any support for the PiFi DAC+ V2.0.
I own a Raspberry Pi B+ and got the sound card, but not sure how to configure it for the Pi. Any help would be appreciated. Thanks.
https://plus.google.com/u/0/photos?pid= ... 0967801914
Certified Glazier/Metal Mechanic, Certified Chef, Hobby Electronics enthusiast. Audiophile
x9e0317
Re: PiFi DAC+ V2.0
Sat Feb 28, 2015 12:49 pm
I got it two weeks ago. Installation was comparibly easy. I hv installed volumio on the rpi and followed the installation instructions. In volumio, the i2s driver settings for "Hifiberry +" can be applied. I assume the PiFi DAC+ is comparable to the HiFiBerry DAC+ in terms of the used HW.
Cheers!
louj
Re: PiFi DAC+ V2.0
Sat Jun 06, 2015 7:52 am
Hi
did this work for you?
I have the same card http://www.dx.com/p/pifi-digi-dac-hifi- ... XKk8WC51Kg
but the hifiberry + driver is not functioning (i don't see the output at the playback section)
Thx
PiiPatient
Re: PiFi DAC+ V2.0
Sat Jun 06, 2015 1:19 pm
Not yet. I kinda gave up on it just busy with other projects.
I am going to try and do some research.
However, with HDMI hooked up and having a TV (Panasonic Viera plasma) there is an option for an optical output that plugs into the surround sound (Sony 7.1 X 120 watts) with Dolby and all the other sound processing surround features...works flawlessly.
using Kodi the Pi the optical audio connection gives me all the Hifi I could ever want...
masayk
Re: PiFi DAC+ V2.0
Fri Sep 04, 2015 3:44 am
My I2S DAC (P1F1 DAC+ v2.0) works perfectly with RuneAudio release version: 0.4 (build: beta-20141216) with the audio output setting as HiFiBerry DAC+ (I2S). The sound is astonishing and better than most of USBDAC interface.
PiiPatient
Re: PiFi DAC+ V2.0
Sat Sep 05, 2015 3:26 pm
Thank you masayk for your reply. I will give that a try.
viorbe
Re: PiFi DAC+ V2.0
Mon Jan 25, 2016 9:48 am
I tried with runeaudio 0.3 but it doesn't work. I can't find 0.4 version.
Any idea?
gjcave
Re: PiFi DAC+ V2.0
Sun May 15, 2016 3:05 am
In version three you must uncomment out these two lines in /boot/config:
dtparam=i2s=on
dtoverlay=hifiberry-dacplus
technicalsatya
Re: PiFi DAC+ V2.0
Wed Jul 25, 2018 11:19 am
Only trusted workaround that can be found for your DAC or AMP is on the following link.
https://github.com/guussie/PiDS/wiki/09 ... -DACs-work
first find your DAC that are listed on the link and follow the steps to make your DAC
work properly. I have PiFi DAC+ (AliExpress) and it worked after I followed the steps given
under the section of
. (Chinese clone :lol: ) .
