bobo10
snappy ubuntu login/password on start up???/
Sat Feb 21, 2015 9:31 am
snappy ubuntu login and password???
Re: snappy ubuntu login/password on start up???/
Sat Feb 21, 2015 1:18 pm
bobo10 wrote:snappy ubuntu login and password???
On the http://www.raspberrypi.org/downloads page if you clicked on the More Info + it will expand the details of the download:
SNAPPY UBUNTU CORE
Snappy Ubuntu Core for Developers
Version:alpha-02
Release date:2015-02-03
Default login:ubuntu / ubuntu
URL:ubuntu.com
Kernel version:3.18.0
Download TorrentDownload ZIP
SHA-1:4ca8ea6b694ad644cf4b00337a625b28bc8f8455
Pi Version supported:Pi 2 only
jerobillard8
Fri Feb 27, 2015 9:41 pm
Login: ubuntu
Password: ubuntu
what to do after that, I'm not sure.
Fri Feb 27, 2015 10:58 pm
jerobillard8 wrote:Login: ubuntu
Password: ubuntu
You go to the Snappy Core Website and start developing "Cloud Apps & IoT Apps"
https://insights.ubuntu.com/2015/02/02/ ... berry-pi-2
http://developer.ubuntu.com/en/snappy
isimorgh
Mon Nov 14, 2016 12:46 am
Hi all,
I followed the instruction on https://developer.ubuntu.com/en/snappy/ ... erry-pi-2/
During the first boot it asked me to press enter to configure and later it asked me to enter my email address from my account in the ubuntu store. I did import an SSH Key into my Ubuntu SSO account already. After entering my email it connected to the store and then I got the 'Configuration Complete' screen, saying that remote access was enabled via authentication with SSO user <isimorgh> .
The green 'Finish' button was highlighted so I pressed Enter.
The next screen is 'Ubuntu Core 16 on 10.0.1.125 (tty1)'
I entered my username from the SSO account, isimorgh, and my password for SSO account, but the login is incorrect!? :?
I even tried my email address as login name.
Have I done anything wrong?
Appreciate any help.
Thanks in advance.
rafapira
Fri Nov 18, 2016 7:41 pm
Hi, exactly same issue as the friend above.
Does anyone have an idea what we could do?
isimorgh
Fri Nov 18, 2016 8:43 pm
@rafapira
It seems like it's not a common incident, but I don't know how to fix it.
andrefelipecl
Sat Dec 03, 2016 10:21 pm
Hi, guys.
I'm in the same problem. I created a SSO account; I generated a SSH Key; and so I logged in Ubuntu Core with my SSO email and now I can't login on ubuntu core...
I'm looking for something and if I found, I'll post here.
Hugs
waleedqk
Tue Dec 20, 2016 10:15 pm
Since I could not log in and was facing the same problem as you guys I used the ssh connection to create a root user with the username on the Ubuntu SSO account:
adduser username
In my case it gave a conflict saying that the username already existed. Since I couldn't figure out the password for it, I changed it:
sudo passwd username
Note: these commands were run from the ssh connection to the pi.
aldelbal
Fri Jan 06, 2017 9:19 pm
Hello, I have the same problem. After installation and download of SSH pub key into raspberri I cannot login from console nor ssh.
In case of ssh I am always asked to enter password which does not work.
Any help?
Thanks folks.
aldelbal
Tue Jan 10, 2017 8:12 pm
I wanted to give an update on the situation. I did two things:
1. Redid the SSH key as I did not use the correct format.
2. During login it might take few tries until it works well. After some time I could login without password as intended.
Cheers
mhelmer
Wed Aug 09, 2017 5:10 pm
What was the correct formatting for the SSH key?
giesjarr779
Fri Feb 16, 2018 7:30 pm
I came across the same issue what i have found to fix it is:
When you SSH into Ubuntu core ensure you open the RSA key file you created earlier that way when putty authenticates the key is imputed and it will allow you to login.
Its done this way to ensure that only your host machine can login and anyone else would need the key. A much more secure option to a simple password
