OBrandsen
Connecting with Huawai E3372 modem
Tue Feb 24, 2015 12:00 pm
I'm trying to connect with the usb modem Huawei E3372 using sakis3g. I've managed to connect with other Huawei USB modems, but not this one. Have anyone had success with this modem?
reptile
Re: Connecting with Huawai E3372 modem
Wed Feb 25, 2015 6:43 pm
I am about to order the same modem and was looking if its supported by the PI.
I found the following instructions:
https://translate.google.com/translate? ... F235361%2F
Give it a try and post your results here.
OBrandsen
Fri Feb 27, 2015 6:40 am
Hi, thanks for the tip!
I'll try this and report back soon
OBrandsen
Fri Feb 27, 2015 7:46 am
Hi, looked at the page. These instructions does not apply to Raspberry Pi and is about setting up the e3372 with "Cubietruck" as a hot pluggable USB modem. It does not talk about how to make e3372 connect to internet. At least from what I could understand....
Fri Feb 27, 2015 7:59 am
OBrandsen wrote:Hi, looked at the page. These instructions does not apply to Raspberry Pi and is about setting up the e3372 with "Cubietruck" as a hot pluggable USB modem. It does not talk about how to make e3372 connect to internet. At least from what I could understand....
This may give some ideas of alternative method as Sakis3G is afaiaa no longer developed
https://www.thefanclub.co.za/how-to/how ... and-wvdial
OBrandsen
Sun Mar 01, 2015 6:18 pm
Just tried out this. Had some success. Managed to switch modem, but failed to connect properly as I could not find the correct modem init commands.
reptile
Mon Mar 02, 2015 7:40 pm
what is the TargetProduct?
My default is
DefaultVendor= 0x12d1
DefaultProduct=0x1f01
necotheone
Tue Jun 02, 2015 3:24 pm
I'm trying to do the same, but it seems that I can't switch it with the usb_modeswitch. Someone did something to connect it?
gnutonio
Wed Jul 15, 2015 12:32 pm
Hi!
I managed to connect this device to my raspberry pi and it works flawlessly.
gnuton@rpi ~ $ lsusb | grep Hua
Bus 001 Device 004: ID 12d1:14dc Huawei Technologies Co., Ltd.
This is what you wanna see in order to get it working as HiLink modem.
here is dmesg output
[ 3.432410] usb 1-1.3: new high-speed USB device number 4 using dwc_otg
[ 3.564023] usb 1-1.3: New USB device found, idVendor=12d1, idProduct=14dc
[ 3.581151] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.592323] usb 1-1.3: Product: HUAWEI_MOBILE
[ 3.601214] usb 1-1.3: Manufacturer: HUAWEI_MOBILE
[ 3.617071] usb-storage 1-1.3:1.2: USB Mass Storage device detected
[ 3.626952] scsi host0: usb-storage 1-1.3:1.2
[ 4.371918] udevd[162]: starting version 175
[ 4.633505] scsi 0:0:0:0: Direct-Access HUAWEI TF CARD Storage 2.31 PQ: 0 ANSI: 2
[ 4.662783] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 4.815059] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 7.876604] cdc_ether 1-1.3:1.0 eth1: register 'cdc_ether' at usb-bcm2708_usb-1.3, CDC Ethernet Device, 0c:5b:8f:27:9a:64
[ 7.936841] usbcore: registered new interface driver cdc_ether
As HiLink modem, it basically behaves as a router reachable over ethernet (eth1).... and not as USB modem.
To get it working just be sure you have usb_modeswitch installed and that the modem is getting enough current. In my case the raspberry USB port was not able to giving out enough juice and I had to use a powered usb hub.
If the e3372 gets enough power you should see the led constantly lit.
Good luck!
BTW I would love to get it working as USB modem.. since HiLink doesn't allow me to open ports on the internet! :(
Has anyone of you managed to do that?
boelle
Mon Nov 30, 2015 10:48 pm
i know it has been 6 months but open ports... thats more your ISP
most mobile broadband providers run their stuff on a private network so you will not be able to connect from the outside
a select few provides a public ip as a business option at a prem price
yoodog
Thu Dec 29, 2016 2:30 am
Also interested I need to log in through DDNS back into pi (pi has 3g internet on E3372 ) How do I do that?
