janpihlgren
[Solved] I get Unable to open SPI device: Permission denied
Wed Apr 08, 2015 7:49 am
I'm trying to run a C-program via html.
I'm using Raspberry Pi B and PiFace Difgital I/O (1).
I use a html.index, piface-blink.php and the C-program piface-blink.c
When I run the c-progam it access OK and blinc the LED at PiFace.
When I try to run i through a web I get this error message in /var/log/apache2/error.log:
This is what I have done so far:
pi@Cisero ~ $ uname -a
Linux Cisero 3.18.7+ #755 PREEMPT Thu Feb 12 17:14:31 GMT 2015 armv6l GNU/Linux
Access through web, http://cisero_wifi/check/
I have opened SPI by raspi-config.
pi@Cisero ~ $ tail /var/log/apache2/error.log
[Wed Apr 08 07:48:12 2015] [notice] caught SIGTERM, shutting down
[Wed Apr 08 07:48:14 2015] [notice] Apache/2.2.22 (Debian) PHP/5.4.39-0+deb7u2 configured -- resuming normal operations
[Wed Apr 08 07:50:34 2015] [notice] caught SIGTERM, shutting down
[Wed Apr 08 07:50:35 2015] [notice] Apache/2.2.22 (Debian) PHP/5.4.39-0+deb7u2 configured -- resuming normal operations
[Wed Apr 08 08:02:25 2015] [notice] caught SIGTERM, shutting down
[Wed Apr 08 08:02:45 2015] [notice] Apache/2.2.22 (Debian) PHP/5.4.39-0+deb7u2 configured -- resuming normal operations
pi@Cisero /var/www/check $ ls -l
totalt 24
-rwxr-xr-x 1 pi pi 903 apr 8 06:23 index.html
-rwxr-xr-x 1 pi pi 7079 apr 8 06:28 piface-blink-2
-rw-r--r-- 1 pi pi 1452 apr 8 06:28 piface-blink-2.c
-rwxrwxrwx 1 pi pi 1340 apr 8 07:28 piface-blink.php
pi@Cisero /var/www/check $ ./piface-blink-2 1
argc=2
buf=1
LED nbr 7 blinking
pi@Cisero /etc $ sudo more sudoers
# This file MUST be edited with the 'visudo' command as root.
# Please consider adding local content in /etc/sudoers.d/ instead of
# directly modifying this file.
# See the man page for details on how to write a sudoers file.
Defaults env_reset
Defaults mail_badpass
Defaults secure_path="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin"
# Host alias specification
# User alias specification
# Cmnd alias specification
# User privilege specification
root ALL=(ALL:ALL) ALL
# Allow members of group sudo to execute any command
%sudo ALL=(ALL:ALL) ALL
# See sudoers(5) for more information on "#include" directives:
#includedir /etc/sudoers.d
pi ALL=(ALL) NOPASSWD: ALL
www-data ALL=(ALL) NOPASSWD: ALL
pi@Cisero /etc/sudoers.d $ ls -l
totalt 8
-r--r----- 1 root root 958 mar 3 2013 README
-r--r----- 1 root root 155 apr 8 07:21 www-data
pi@Cisero /etc/sudoers.d $ sudo more www-data
#/etc/sudoers.d/www-data
# sudoers file for the www-data user - very limited permissions only
www-data ALL=NOPASSWD: /var/www/piface/piface-blink
here are the programs:
index.html
<!DOCTYPE html>
<html lang="sv">
	<head>
		<meta http-equiv="CONTENT-TYPE" content="text/html; charset=utf-8">
		<title>Kör Piface-blink</title>
		<meta name="generator" content="Bluefish 2.2.4" >
		<meta name="CREATED" content="20140611;5273800">
		<meta name="CHANGED" content="2015-04-08">
		<meta name="DESCRIPTION" content="Testsida för att prova ,testa funktioner">
		<meta name="KEYWORDS" content="Testsida">
	</head>
	<body>
		<h1>Test av köra piface-blink</h1>
		<p>Programnamn = piface-blink.php.</p>
		<form method="POST" action="piface-blink.php">
		<form action="piface" metod="POST">
			<input type="checkbox" name="val" value="7">Blinka 7 LEDS
			<br />
			<input type="checkbox" name="val" value="1">Blinka 1 LED
			<br />
			<input type="submit" value="SKICKA">
		</form>
		<form metod="POST" action="index.html">
			<input type="submit" value="RESET">
		</form>
	</body>
</html>
piface-blink.php
<?php
 * piface-blink.php
 * Copyright 2015  Jan Pihlgren
 * This program is free software; you can redistribute it and/or modify
 * it under the terms of the GNU General Public License as published by
 * the Free Software Foundation; either version 2 of the License, or
 * (at your option) any later version.
 * This program is distributed in the hope that it will be useful,
 * but WITHOUT ANY WARRANTY; without even the implied warranty of
 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 * GNU General Public License for more details.
 * You should have received a copy of the GNU General Public License
 * along with this program; if not, write to the Free Software
 * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston,
 * MA 02110-1301, USA.
 if($_SERVER['REQUEST_METHOD'] == "POST") {
	 echo "Testmeddelande";
	 echo "<br />";
	 echo $_SERVER['REQUEST_METHOD'];
	 echo "<br />";
	 echo $_POST['val'];
	 echo "<br />";
	 $val = $_POST['val'];
	 echo "val = ", $val;
	 echo "<br />";
 $command="./piface-blink-2 {$val} &";
 echo "command = ", $command;
 echo "<br />";
exec($command);
exec('exit');
echo "<br>";
echo "Programmet klart!\n";
echo "<br>";
<html>
<body>
<form method="POST" action="index.html">
<input type="submit" value="TILLBAKA">
</form>
</body>
</html>
piface-blink-2.c
/* programnamn: piface-blink-2.c
* Jan Pihlgren 2015-04-02
* Kompilera med:
* gcc -L/usr/local/lib -lwiringPi -lwiringPiDev -o piface-blink-2 piface-blink-2.c
#include <stdio.h>
#include <string.h>
#include <wiringPi.h>
#include <piFace.h>
// Use 200 as the pin-base for the PiFace board, and pick a pin
//      for the LED that's not connected to a relay
#define PIFACE  200
#define LED     (PIFACE+2)
int main(int argc, char *argv[])
// Always initialise wiringPi. Use wiringPiSys() if you don't need
//      (or want) to run as root
	wiringPiSetupSys () ;
// Setup the PiFace board
	piFaceSetup (PIFACE) ;
	char buf[10]="";
	int val=0;
	int i;
	if(argc > 1) {
		strcpy(buf,argv[1]);	// Kopiera argv[] till buf
    printf("argc=%d\n",argc);
    printf("buf=%s\n",buf);
	val=atoi(buf);				// Omvandla char to int
	switch(val){
		case 0:
			break;
		case 1:
			blink1();
			break;
		case 2:
			blink7();
			break;
		case 7:
			blink7();
			break;
		default:
			return 0;
     return 0 ;
blink1()
	int i;
//		printf("buf=%s\n",buf);
		for(i=0;i<7;i++){
			digitalWrite(LED+5, 1);
			delay(100);
			digitalWrite(LED+5, 0);
			delay(100);
blink7()
	int i;
//	 printf("Blinka\n");
     for (i=0;i<=7;i++){
         digitalWrite(i+LED, 1);
         delay(100);
         digitalWrite(i+LED, 0);
         digitalWrite(i+1+LED, 1);
         delay(100);
         digitalWrite(i+1+LED, 0);
     return;
My question:
What else do I have to do or what does I had done wrong?
Edit:
For some reason I don't understand the program begun running with success. :)
joan
Re: I get Unable to open SPI device: Permission denied
Wed Apr 08, 2015 8:30 am
Who has permission to use SPI on your Pi?
ls -l /dev/spi*
crw-rw---- 1 root spi 153, 0 Apr  7 22:07 /dev/spidev0.0
crw-rw---- 1 root spi 153, 1 Apr  7 22:07 /dev/spidev0.1
Add the user you are using (www-data?) to the spi group.
sudo adduser www-data spi
Wed Apr 08, 2015 8:37 am
DO NOT add www-data to the sudoers file if you ever intend to open your machine to the public internet.
allows the webserver to access the SPI bus.
sudo adduser www-data i2c
does the same for the i2c bus.
akaodin
Re: [Solved] I get Unable to open SPI device: Permission denied
Wed Apr 11, 2018 5:52 pm
I ran
( which acknowledged that it indeed added the www-data user )
then
ls -l /dev/spi*
and got:
crw-rw---- 1 root spi 153, 1 Apr 9 17:29 /dev/spidev0.1
crw-rw---- 1 root spi 153, 0 Apr 9 17:29 /dev/spidev0.0
what happened? shouldn't www-data also be there?
joan
Wed Apr 11, 2018 5:55 pm
No. The spi group has rw access. You have made www-data a member of the spi group.
akaodin
Wed Apr 11, 2018 6:05 pm
I needed to reboot to make it work. Thanks.
Jutzi
Fri Jan 18, 2019 8:41 am
I have the same problem. The following commands solved it, as described above:
sudo chgrp spi /sys/class/gpio/export
sudo chmod 660 /sys/class/gpio/export
sudo chgrp spi /sys/class/gpio/unexport
sudo chmod 660 /sys/class/gpio/unexport
sudo chgrp spi /dev/spidev0.0
sudo chmod 660 /dev/spidev0.0
However, the settings disappear after reboot. Shouldn't they be permanent?
I have old Raspberry B and Piface Digital 1. Problems started after upgrading from Wheezy to Jessie.
mbehrens
Sun Jun 28, 2020 12:14 am
I added my user to the spi group and it worked well after logging back in:
sudo usermod -a -G spi  exampleusername
If you are logged in as that user, you should log out and then log back in. Use the group command to check that you are in the spi group.
Also, in my case, my LCD hat had instructions that told me to run sudo raspi-config and turn on SPI via the Interfaces menu under the Advanced option.
Hope this helps :)
