hotpaw2
How to connect to Bluetooth LE devices without being root (v
Mon Apr 27, 2015 1:13 am
I am running Raspbian with BlueZ 5.30 and a Cambridge Silicon Bluetooth USB Dongle installed. I can successfully bring up the BLE interface, as well as detect and connect to a TI SensorTag over BLE when logged in as "pi" and using sudo in front of every bluetooth command (such as hciconfig, hcitool, gatttool, ...)
Is there a way to set things up (file permissions, group memberships, etc.) so that a regular (non root, student) user can connect the the SensorTag (and other BLE peripherals) without having to use sudo all the time?
Douglas6
Re: How to connect to Bluetooth LE devices without being roo
Mon Apr 27, 2015 5:29 am
Gatttool works for the pi user without changes (too many 'tutorials' just put 'sudo' in front of everything). But bluetoothctl needs some work. Create a D-Bus security policy for the pi user.
sudo nano /etc/dbus-1/system.d/bluetooth.conf
and add the following policy:
  <policy user="pi">
    <allow send_destination="org.bluez"/>
    <allow send_interface="org.bluez.Agent1"/>
    <allow send_interface="org.bluez.GattCharacteristic1"/>
    <allow send_interface="org.bluez.GattDescriptor1"/>
    <allow send_interface="org.freedesktop.DBus.ObjectManager"/>
    <allow send_interface="org.freedesktop.DBus.Properties"/>
  </policy>
before the closing '</busconfig>' tag. Alternately, create a 'student' group and a <policy group="student">...</policy>
bluetoothctl should give you everything you need to manage the local and remote devices.
