ds18s20
Identify hardware version from within Raspbian
Wed May 27, 2015 9:32 pm
HI everyone,
Is there a way to Identify hardware version from within Raspbian?
By hardware version I do NOT mean the firmware level or the kernel;
I mean the bare metal which could be "+" model or the "2" model of the PCB
For example right now I could do:
  • pi@raspberrypi ~ $ /opt/vc/bin/vcgencmd version
    May 23 2015 16:42:55
    Copyright (c) 2012 Broadcom
    version 29d1114a122b6ef70bdfb7d4db3dd28bdfc38ac2 (clean) (release)
But that doesn't tell me which bare metal PCB this is running on?
Thank you
~B
kusti8
Re: Identify hardware version from within Raspbian
Wed May 27, 2015 9:36 pm
http://elinux.org/RPi_HardwareHistory
First thing on the page.
ds18s20
Wed May 27, 2015 9:46 pm
Thank you @kusti8 !
Works and the story checks out; my printed revision is corresponding to the actual PCB.
Hardware        : BCM2709
Revision        : a21041
AndyD
Wed May 27, 2015 9:52 pm
kusti8 wrote:http://elinux.org/RPi_HardwareHistory
There are a couple of revisions missing from that page. I wrote some code when the Pi 2 was released. The Readme has some tables of revisions that I believe are up to date.
kaspbar
Fri Nov 17, 2017 7:55 am
sudo apt-get update
sudo apt-get install lshw
sudo lshw # lists all kinds of info for your hardware
Fri Nov 17, 2017 8:03 am
cat /proc/cpuinfo
cat /sys/firmware/devicetree/base/model
jahboater
Fri Nov 17, 2017 8:06 am
See
/proc/device-tree/model
This file contains a NUL terminated text string like this:
Raspberry Pi 3 Model B Rev 1.2
Ooops, sorry Dougie for the cross post. Its the same as the /sys file.
bensimmo
Fri Nov 17, 2017 9:36 am
pinout
Should also work, you can also use it remotely with pigpio/gpiozero pin factories.
Return to “Raspberry Pi OS”
