jonrogersuk
Won't boot without HDMI connected (solved)
Sun Jul 15, 2012 2:31 pm
I've been using my RaspberryPi headless, connected to a USB hard disk and the network from the cupboard where my router lives. It was running for 21 days like that, no problems, then I re-started it. Now, bizarrely, it will only boot when I take it into the living room and connect it up to the TV with HDMI. I have tried all the available power supplies, so I don't think it's that, and simply un-plugging the HDMI cable is enough to stop the RPi from booting.
When I plug in power, the red light comes on, then the green OK light flickers for a couple of seconds. If the HDMI is not connected, that's all it will do. Network lights don't come on, I can't get anything to tell me what's happened. With HDMI, the network lights come on after a tiny pause and the green OK light keeps doing its thing.
I have tried different SD images, no good. I have tried booting with nothing connected, no good.
What can I do? It's not practical to keep the RPi where it is currently working - any suggestions? :
Re: Won't boot without HDMI connected
Sun Jul 15, 2012 2:51 pm
Have you tried rpi-update. There has been a fix for a problem just like this.
jonrogersuk
Sun Jul 15, 2012 8:01 pm
Amazing! Thanks, that was exactly what I needed - you deserve a medal! And if that was post number 1337 for you, even better!
Mark
Re: Won't boot without HDMI connected (solved)
Tue Jul 31, 2012 10:51 pm
I am having the exact same problem on a Pi I just received. I've run rpi-update but the problem persists.
As with the OP, everything works fine if I boot with HDMI connected. I'm using the latest Raspbian, updated, if that matters.
Tue Jul 31, 2012 11:07 pm
@Mark
You could try:
boot_delay=1
or
hdmi_force_hotplug=1
in config.txt.
Mark
Tue Jul 31, 2012 11:47 pm
hdmi_force_hotplug=1 seems to resolve it. Thanks!
KenT
Wed Aug 01, 2012 4:52 pm
There are a number of people with this problem. Is there any downside to configuring the software release to hdmi_safe being on, or at least hdmi_forcehotplug?
Once people have got their system going they can always change to unsafer options.
Pi Presents - A toolkit to produce multi-media interactive display applications for museums, visitor centres, and more
Download from http://pipresents.wordpress.com
Wed Aug 01, 2012 5:00 pm
KenT wrote:There are a number of people with this problem. Is there any downside to configuring the software release to hdmi_safe being on, or at least hdmi_forcehotplug?
hdmi_force_hotplug forces hdmi output. Someone with a composite TV will get nothing.
wymand
Contact: Website Facebook
Sat Nov 05, 2016 5:53 pm
I also had the no boot without HDMI problem and tried all the fixes listed to no avail. Then I noticed in rasp-config advance options I had enabled the GL driver. Once the GL driver was disabled, the pi boots fine without HDMI
Never stop learning
Never stop evolving
