Efcis
Simple Ham Radio FM receiver with rtl-sdr
Tue Jul 17, 2012 10:16 pm
Inspired by http://www.reddit.com/r/RTLSDR/comments ... er_rtl_fm/ , I tried to use my current DVB-T dongle and the raspi, as a first project.
After a succesful compilation of rtl_fm (I can elaborate, if needed), I'm currently facing various issues for a "complete" FM receiver.
1/ As "play" (from the sox package) can't find any default device (how to set that ?), I used aplay instead from the ALSA package. After much testing it appears the current sound driver (and/or aplay) only accept raw files sampled at 44100 and 48000 Hz. When using other sampling rates files, aplay doesn't complain, no sound is output, the raspi just hangs, and a reboot is required. I guess it is a sound driver bug (or a limitation ?).
2/ Thus, I used the 44100 sampling rate (a bit wide for NBFM), but it only works few seconds before hanging.
rtl_fm -f 144800000 -s 44100 -g 9 -l 10 - | aplay -t raw -r 44100 -c 1 -f S16_LE
(-l 10 ensures I can hear the FM background noise).
There are some indications of underrun, which mutes the audio for few milliseconds, and few seconds after, no more sound, no more network (I'm using SSH for now), and a reboot is required.
I'm using the 2012-07-15-wheezy-raspbian image.
If you own a DVB-T dongle and you are more proficient in linux that me, please try it and report your results !
Larry - F6FVY
Efcis
Re: Simple Ham Radio FM receiver with rtl-sdr
Sat Jul 21, 2012 3:06 pm
Few indications on my progress :
The ALSA thing can't handle for now sampling rates different from 44.1 kHz and 48 kHz. There is a dedicated thread on this issue in the Raspbian forum. Check here. For the record, I'm currently using the analog (jack) audio output. Maybe it differs with the HDMI output.
I also faced a power voltage issue. When the DVB-T dongle was hooked up, and one software of the rtl-sdr repo was running, the voltage between TP1 and TP2 could decrease under 4.7 volts. I thus decided to use another PSU, which was delivering a better voltage under these conditions. I now rather have between 5.3 and 5.4 volts, and things are getting much better.
Nevertheless, I'm still experiencing constant audio drop outs (every 5 seconds or so), despite using a sampling rate of 44100 Hz. I get "underrun" error messages in the console. I guess they are output by aplay ?
pi@raspberrypi ~/rtl-sdr/src $ ./rtl_fm -f 144800000 -s 44100 -g 9 -l 0 - | aplay -t raw -f S16_LE -r 44100 -c 1
Found 1 device(s):
  0:  Realtek, RTL2838UHIDIR, SN:
Using device 0: ezcap USB 2.0 DVB-T/DAB/FM dongle
Found Elonics E4000 tuner
Oversampling input by: 23x.
Oversampling output by: 1x.
Buffer size: 8.08ms
Tuned to 145053575 Hz.
Sampling at 1014300 Hz.
Exact sample rate is: 1014300.020041 Hz
Tuner gain set to 9.00 dB.
Playing raw data 'stdin' : Signed 16 bit Little Endian, Rate 44100 Hz, Mono
underrun!!! (at least 0.264 ms long)
underrun!!! (at least 0.178 ms long)
underrun!!! (at least 0.092 ms long)
underrun!!! (at least 0.529 ms long)
underrun!!! (at least 0.141 ms long)
underrun!!! (at least 0.052 ms long)
underrun!!! (at least 0.625 ms long)
underrun!!! (at least 0.404 ms long)
underrun!!! (at least 0.313 ms long)
^CAborted by signal Interrupt...
Signal caught, exiting!
User cancel, exiting...
For the record, the CPU load is around 20% for a 44100 bandwidth demodulation. Once we will be able to use sound samples with a lower sampling rate (11025 is enough for NBFM), it should decrease a bit.
To be continued...
Larry - F6FVY
kadamski
Sat Jul 21, 2012 5:27 pm
5.3 V is out of spec too. So now you have to much voltage! As for underruns, it is possible that rtl_fm is just not able to deliver sound fast enough. There may be some buffering issues - it may buffer too much data before sending it to stdout and aplay has no data to play, thus underrun messages.
Efcis
Mon Jul 23, 2012 5:12 pm
I'll try to find a Schottky diode to lower the overall voltage and keep it "nominal".
Meanwhile I modified the rtl_fm.c code a bit, and tried several 'capture' rate (from 1Msps to 2.4 Msps), for a given output rate (24k). Quite strangely, the underruns are less frequent with a higher capture rate, while the CPU load is higher :
Capture set at 1 Msps - Output rate 24k (CPU load 15.7 %) -> Underrun every 14 sec
Capture set at 2 Msps - Output rate 24k (CPU load 27.4 %) -> Underrun every 22 sec
Capture set at 2.4 Msps - Output rate 24k (CPU load 31.3%) -> underrun every 25 sec
I ordered several different audio USB dongles, and will check if it makes any difference with the built-in audio output.
To be continued...
jbeougher
Wed Jul 25, 2012 3:50 am
Could you post how you built rtl_fm on your rpi?
M0RBD
Wed Jul 25, 2012 11:37 am
jbeougher wrote:Could you post how you built rtl_fm on your rpi?
Follow the instructions here:
http://sdr.osmocom.org/trac/wiki/rtl-sdr
M0RBD
Wed Jul 25, 2012 1:21 pm
Efcis wrote:I'll try to find a Schottky diode to lower the overall voltage and keep it "nominal".
To be continued...
Have you tried using rtl_sdr and stream to a remote machine? Do you get buffer under-runs/crashes as well? It seems to be more stable if I do the other way around with my card both under rtl_sdr and rtl_fm. I.e lower the sampling rate.
I'm having this card btw http://erewhon.superkuh.com/gnuradio/rt ... _DVB-T.jpg
Efcis
Wed Jul 25, 2012 3:22 pm
FYI, I just did :
sudo apt-get install git libusb-dev libusb-1.0 libtool cmake
to install requirements (I'm using raspbian and use the beta "alsa sound driver" - check this)
Hope this helps
jbeougher
Thu Jul 26, 2012 11:47 am
How did you get gnuradio build? I'm am having trouble building that on the rpi.
Efcis
Thu Jul 26, 2012 1:05 pm
I haven't build gnuRadio personally (rtl_fm is standalone), but there are instructions here
Efcis
Thu Jul 26, 2012 6:52 pm
M0RBD wrote: Have you tried using rtl_sdr and stream to a remote machine? Do you get buffer under-runs/crashes as well? It seems to be more stable if I do the other way around with my card both under rtl_sdr and rtl_fm. I.e lower the sampling rate.
Actually, I don't have another linux machine at hand. I guess my best bet would be to install one in a VM with VirtualBox on my Win machine, and run rtl_fm on it, aplay on the Raspi, and link them with a ncat (for example) between them. Or the opposite.
Efcis
Fri Jul 27, 2012 12:42 pm
I finally installed Ubuntu into a VirtualBox VM on my Windows machine.
rtl_fm doesn't work much better on it than my previous experiments with the raspi. I still get constant underruns, while the CPU load of rtl_fm is only around 3% on it. A bit disappointing...
I also tried to run rtl_fm on the raspi and sent the demodulated output stream data to Ubuntu, running aplay, thru a ncat connection. Same failure. And finally, the opposite (rtl_fm on the Ubuntu VM and aplay running on the raspi) doesn't help.
I'm still puzzled by these results. I even tried various options on rtl_fm (rate, quality FIR, "high speed arctan"...) with no difference.
To be continued...
M0RBD
Fri Jul 27, 2012 3:50 pm
Efcis wrote:I finally installed Ubuntu into a VirtualBox VM on my Windows machine.
To be continued...
I have to admit I have not tested rtl_fm on my PC...
However, I got completely different results with the onboard USB2 card and an external card when using rtl_sdr on the same machine. I'm going to recompile libusb with debug log on this weekend to see whether it will shed some light on the matter. I believe it boils down to either libusb or the hw used.
That said, there appears to have been some regression introduced into libusb after 1.0.8 especially if using SDR and gnuradio, here is a post regarding that: http://www.libusb.org/ticket/131
Efcis
Thu Aug 02, 2012 4:13 pm
Just received today one of the USB dongle I ordered. Unfortunately, as a Linux / Rasbian newbie I can't find how to use it with aplay or even the plain speaker-test utility.
I *guess* the name of the device to use is "front" (no quotes), according to the aplay -L command :
 pi@raspberrypi ~/dvpt/rtl-sdr/src $ aplay -L
null
    Discard all samples (playback) or generate zero samples (capture)
sysdefault:CARD=ALSA
    bcm2835 ALSA, bcm2835 ALSA
    Default Audio Device
sysdefault:CARD=Device
    Generic USB Audio Device, USB Audio
front:CARD=Device,DEV=0
    Front speakers
surround40:CARD=Device,DEV=0
    4.0 Surround output to Front and Rear speakers
surround41:CARD=Device,DEV=0
    4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Device,DEV=0
    5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Device,DEV=0
    5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Device,DEV=0
    7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=Device,DEV=0
    IEC958 (S/PDIF) Digital Audio Output
but "speaker-test -D front" fails
pi@raspberrypi ~/dvpt/rtl-sdr/src $ speaker-test -D front
speaker-test 1.0.25
Playback device is front
Stream parameters are 48000Hz, S16_LE, 1 channels
Using 16 octaves of pink noise
ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.BRCM bcm2835 AL.pcm.front.0:CARD=0'
ALSA lib conf.c:4241:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:4720:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM front
Playback open error: -2,No such file or directory
Maybe an obscure configuration file requires an update ? ;-)
Any help appreciated !
Efcis
Thu Aug 02, 2012 8:00 pm
I finally edited /etc/asound.conf with :
pi@raspberrypi ~ $ cat /etc/asound.conf
pcm.!default {
        type hw
        card 0
ctl.!default {
        type hw
        card 0
pcm.usb {
        type plug
        slave {
                pcm "hw:1,0"
ctl.usb {
        type plug
        slave {
                ctl "hw;1,0"
pi@raspberrypi ~ $
Note : I'm not sure the ctl section requires the plug type, but it works. Critics welcome.
Now I can use my USB audio dongle by using the -D usb parameter, and can specify -c 1 (mono output) with aplay or speaker-test.
Unfortunately, I'm still facing the same underruns with rtl_fm :-(
m0ute
Mon Aug 06, 2012 9:45 pm
I'm having a hard time with rtl_fm. It constantly crashes like this :
Script started on Mon 06 Aug 2012 21:35:51 UTC
[01;32mpi@raspberrypi[00m [01;34m~ $[00m rtl_fm -f 144.8e6 -s 44100 - | aplay -t raw -r 44100 -c 1 -f S16_LE
Found 1 device(s):
  0:  Generic, RTL2832U, SN: 77771111153705700
Using device 0: Generic RTL2832U (e.g. hama nano)
Buffer size: 8.08ms
Tuner gain set to -1.00 dB.
Library error 0, exiting...
rtlsdr_demod_write_reg failed with -1
rtlsdr_demod_read_reg failed with -1
rtlsdr_write_reg failed with -1
[01;32mpi@raspberrypi[00m [01;34m~ $[00m exit
Script done on Mon 06 Aug 2012 21:36:20 UTC
Then I have to unplug and replug the device, otherwise i'm getting "Failed to open rtlsdr device #0".
I tried using libusb 1.0.8 without success. rtl_test crashes in a similar fashion.
I'm running on Raspbian wheezy by the way.
Any hints on what could be the problem here?
Efcis
Tue Aug 07, 2012 10:11 am
Hi
I'm not very familiar with getting version numbers of my installed packages but here's the listing of the dpkg command if it can help :
pi@raspberrypi ~ $ dpkg -l libusb*
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name           Version        Description
ii  libusb-0.1-4:a 2:0.1.12-20    userspace USB programming library
ii  libusb-1.0-0:a 2:1.0.11-1     userspace USB programming library
ii  libusb-1.0-0-d 2:1.0.11-1     userspace USB programming library developmen
ii  libusb-dev     2:0.1.12-20    userspace USB programming library developmen
un  libusb0        <none>         (no description available)
pi@raspberrypi ~ $
I also faced several crashes when my power supply voltage was too low. Check voltage between TP1 and TP2.
ltaing
Tue Sep 25, 2012 7:18 pm
m0ute, I'm having the same exact error messages. I have determined that it's a dongle problem: the dongle works for 2 mins and then it craps out with the err msgs that you posted. I then have to remove the dongle and wait like 10 minutes for the dongle to work again.
Have you gotten anywhere in terms of fixing this issue?--it seems to me a hardware issue--where the dongle is over-heating or over charging.
I'm using the ezcap USB 2.0 DVB-T/DAB/FM dongle which has the Elonics E4000 tuner.
m0ute wrote:Hi,
Found 1 device(s):
Buffer size: 8.08ms
Sonny_Jim
Tue Oct 23, 2012 10:48 pm
Just to add that I've had some success with a PROlectrix DV107669 plugged into my Pi. At the moment I've only got rtl-sdr compiled as per the instructions above. To test it I've been using multimode.py on a laptop connected to it via ethernet cable. I did try using a zd1211 wireless card but it causes stuttering audio.
On the Pi, I run rtl_tcp:
rtl_tcp -a PI_IP_ADDRESS
On my laptop, I run multimode.py like this:
multimode.py --devinfo=rtl_tcp=PI_IP_ADDRESS:1234
My next plan is to try and get uhd_modes running either natively on the pi (requires building gnu-radio) or modifying it so it can receive the signal via rtl_tcp.
Sonny_Jim
Wed Oct 24, 2012 8:35 pm
Another update, I've managed to get FM receiving working with rtl-sdr. The big stopping block was using play from SoX to playback the audio, which was causing stuttering. I'm now using aplay and it's working a lot better. I'm using the source from here as it has more options to control the samplerate:
https://github.com/keenerd/rtl-sdr
rtl_fm -f 88.2e6 -W -A -r 32e3 -l 0 - | aplay -r 32k -f S16_LE -t raw -c 1
Sander
Sun Nov 18, 2012 6:21 pm
I only get white noise with all the command I used. Tips how to solve that?
Furthermore, when I specify 98900000 (=98.9 MHz), rtl_fm tunes to 99152000 (99.152 Mhz), 252000 Hz (252 kHz) higher. Any reason for that?
sander@R540:~$ sudo rtl_fm -f 98900000 -s 12000 -g10 -l10  - | aplay -t raw -f S16_LE -r 12k -c 1
Found 1 device(s):
  0:  Realtek, RTL2838UHIDIR, SN: 00000013
Found Rafael Micro R820T tuner
Oversampling input by: 84x.
Buffer size: 8.13ms
Tuned to 99152000 Hz.
Sampling at 1008000 Hz.
Output at 12000 Hz.
Exact sample rate is: 1008000.009613 Hz
Tuner gain set to 10.00 dB.
Playing raw data 'stdin' : Signed 16 bit Little Endian, Rate 12000 Hz, Mono
^CSignal caught, exiting!
sander@R540:~$
and
sander@R540:~$ sudo rtl_fm -f 98648000 -s 12000 -g10 -l10  - | aplay -t raw -f S16_LE -r 12k -c 1
Found 1 device(s):
Buffer size: 8.13ms
Tuned to 98900000 Hz.
Output at 12000 Hz.
sander@R540:~$
and
sander@R540:~$ sudo rtl_fm -f 98648000 -s 12000 -g10 -l10  - | play -t raw -r 12k -e signed-integer -b 16 -c 1 -V1 -
Found 1 device(s):
-: (raw)
  Encoding: Signed PCM
  Channels: 1 @ 16-bit
Samplerate: 12000Hz
Replaygain: off
  Duration: unknown
In:0.00% 00:00:00.00 [00:00:00.00] Out:0     [      |      ]        Clip:0    Found Rafael Micro R820T tuner
Buffer size: 8.13ms
Output at 12000 Hz.
In:0.00% 00:00:08.19 [00:00:00.00] Out:90.1k [     -|-     ]        Clip:0    ^CSignal caught, exiting!
In:0.00% 00:00:08.34 [00:00:00.00] Out:98.3k [     -|-     ]        Clip:0
Aborted.
sander@R540:~$
dbrashear
Wed Nov 28, 2012 1:41 pm
rtl_fm -f 96900000 -W -s 200000 -r 48000 - | aplay -r 48k -f S16_LE -t raw -c 1
Found 1 device(s):
Oversampling input by: 2x.
Oversampling output by: 4x.
Buffer size: 5.12ms
Tuned to 97315000 Hz.
Sampling at 1600000 Hz.
Output at 48000 Hz.
Tuner gain set to automatic.
Playing raw data 'stdin' : Signed 16 bit Little Endian, Rate 48000 Hz, Mono
and it starts spitting out 96.9fm successfully and does so for ... well, minutes and then i got bored.
Playing with 160mHz range now.
zanco
Fri Dec 07, 2012 1:45 pm
I am running rtl_tcp as server on the Raspberry Pi. From a Windows machine I can connect to it by using software like sdrsharp.
On my Linux system I am trying to get multimode.py connect to the Pi. However, it always choosed "using device #0" which is locally connected to this Linux machine.
I am viewing the Pi by an SSH connection, it states:
raspbian@pisces:~$ rtl_tcp -a 192.168.0.50
Found 1 device(s).
Using ezcap USB 2.0 DVB-T/DAB/FM dongle
Tuned to 100000000 Hz.
listening...
Use the device argument 'rtl_tcp=192.168.0.50:1234' in OsmoSDR (gr-osmosdr) source
to receive samples in GRC and control rtl_tcp parameters (frequency, gain, ...)
On my Linux system I try this:
./multimode.py --devinfo=rtl_tcp=192.168.0.50:1234 which starts but then tells me:
Using device #0 Realtek RTL2838UHIDIR
What would be the right way to have multimode.py connect to the remote rtl_tcp and not to the local available device #0 ?
Thanks in advance.
Ben
geggino
Sat Jan 11, 2014 10:06 am
I try many test, but I always get the sound intermittent:
Found 1 device(s):
Using device 0: Generic RTL2832U OEM
Buffer size: 5.12ms
Tuned to 97316000 Hz.
Output at 48000 Hz.
underrun!!! (at least 9,574 ms long)
underrun!!! (at least 11,873 ms long)
underrun!!! (at least 7,504 ms long)
underrun!!! (at least 15,390 ms long)
underrun!!! (at least 6,811 ms long)
underrun!!! (at least 16,309 ms long)
underrun!!! (at least 5,701 ms long)
ersten
Sat Mar 08, 2014 3:46 pm
I have same problem - "rtl_fm ... | aplay ..." was generating a lot of underruns and sound was intermittent every second.
Today unexpectedly I found solution:
While the CPU have full load - rtl_fm and aplay works fine!
My solution:
1. Launch on first SSH session:
rtl_fm -f 97.5e6 -s 200000 -r 48000 - | aplay -r 48k -f S16_LE -t raw
2. On second SSH session launch CPU load:
tar -czf ./root.tgz /
After execution those commands I heard normal sound.
This solution work only for me?
Why this solution works? How CPU load influences to rtl_fm and aplay?
PS: sorry for my bad English.
Sorry for my bad English, I still learning.
Return to “Other projects”
