JonnyAlpha
Raspberry Pi Certified Educator
pigpio - cleaning up GPIO pins
Sun Jul 12, 2015 7:45 pm
Hi;
I am playing around learning some Python and am trying to use pigopi. I can blink and LED and now I am trying to control some servos.
What pigpio command do I use to set the position of a servo, I tried using pi.set_PWM_dutycycle(<pin>, <vlaue> ) but think this is for controlling motor speed, I am using Micro 9g servos.
Raspberry Pi Certified Educator. Main Hardware - Raspberry Pi 1 model B revision 2, Raspberry Pi 2 model B, Pi Camera
joan
Re: pigpio - cleaning up GPIO pins
Sun Jul 12, 2015 7:51 pm
You would normally use set_servo_pulsewidth.
JonnyAlpha
Sun Jul 12, 2015 8:18 pm
Sorry - just worked it out by looking at the pigpio library again, its pi.set_servo_pulsewidth(<pin>, <time in ms>).
Here's my code for testing the servos on my Pan and Tilt camera mount, it simply runs in a loop with each servo going from stop / anticlockwise / centre / clockwise.
import RPi.GPIO as GPIO
import time
import pigpio
pi = pigpio.pi()
#pi.set_mode(23, pigpio.OUTPUT) #set pin 23 as OUTPUT
#pi.set_mode(24, pigpio.OUTPUT)
var=1
print "Start loop"
try:
        while var==1 :
                print "Set servo 1 & 2 off"
                pi.set_servo_pulsewidth(23, 0)
                pi.set_servo_pulsewidth(24, 0)
                time.sleep(1)
                print "Set sero 1 & 2 anticlockwise safe"
                pi.set_servo_pulsewidth(23, 1100)
                pi.set_servo_pulsewidth(24, 1100)
                time.sleep(1)
                print "Set servo 1 & 2 centre"
                pi.set_servo_pulsewidth(23, 1500)
                pi.set_servo_pulsewidth(24, 1500)
                time.sleep(1)
                print "Set servo 1 & 2 clockwise safe"
                pi.set_servo_pulsewidth(23, 1900)
                pi.set_servo_pulsewidth(24, 1900)
                time.sleep(1)
except KeyboardInterrupt:
        print "Cleaning up"
        pi.stop()
Question:
I have changed the timings slightly but at one setting, (clockwise I think) it still sound like the servo is draining power. Also when I interrupt the program the servo stays buzzing.
I have initiated a pi.stop() but is there something else I need to do to stop the servo draining power.
I have commented out the pi.setmode as I don't think its needed.
Any help would be appreciated.
joan
Sun Jul 12, 2015 8:41 pm
You'll need to explicitly stop the servo pulses.
pigpio assumes that anything left running is meant to be left running, e.g. if you set a gpio high, it will be left high, if you started PWM or servo pulses on a gpio they will continue.
In your case you would need to change
        print "Cleaning up"
        pi.stop()
to
        print "Cleaning up"
        pi.stop()
If the servo is buzzing it may be acting against an end-stop.
JonnyAlpha
Mon Jul 13, 2015 5:17 am
Thanks joan :-)
christoskar
Fri Mar 30, 2018 7:02 pm
I am using a Raspberry Pi 2, Afro ESC’s, and t100 thrusters. I am a beginner. I am trying to connect the t100 thrusters to my raspberry pi 2. I had operated only one thruster with GPIO Pin 18 but I try to connect pins with different GPIO Pin but it isn’t work. I want connect four thruster. What’s happening?
Christos
My program:
from pygame import *
import time
import pigpio
pi = pigpio.pi()
init()
screen = display.set_mode((640, 480))
display.set_caption('the program')
motor1=23
motor2=24
led1=22
led2=25
endProgram = False
while not endProgram:
    for e in event.get():
        if e.type ==KEYDOWN:
           if (e.key == K_a):
              print ("key a")
              pi.set_servo_pulsewidth(motor1, 1200)
              pi.set_servo_pulsewidth(motor2, 1200)
              pi.set_servo_pulsewidth(led1, 1300)
              pi.set_servo_pulsewidth(led2, 1300)
              time.sleep(1)
           elif (e.key == K_c):
                print("key c")
                pi.set_servo_pulsewidth(motor1, 1800)
                pi.set_servo_pulsewidth(motor2, 1850)
                pi.set_servo_pulsewidth(led1, 1700)
                pi.set_servo_pulsewidth(led2, 1700)
                time.sleep(1)
           elif (e.key == K_b):
                print("key b")
                pi.set_servo_pulsewidth(motor1, 1700)
                pi.set_servo_pulsewidth(motor2, 1750)
                time.sleep(1)
           elif (e.key == K_q):
                print("key b")
                pi.set_servo_pulsewidth(motor1, 0)
                pi.set_servo_pulsewidth(motor2, 0)
                pi.set_servo_pulsewidth(led1, 0)
                pi.set_servo_pulsewidth(led2, 0)
                time.sleep(1)
           elif e.key == K_ESCAPE:
                endProgram = True
           else:
               print ("error")[code]
[/code]
JonnyAlpha
Fri Mar 30, 2018 8:47 pm
This thread isn’t about 3 years old. A thruster is a brushless motor and an esc is used to drive it. Not sure why you are using set_servo?
Anyway I found this which should help you out:
http://www.instructables.com/id/Driving ... pberry-Pi/
Return to “Python”
