Axy
Console goes blank after a while (on TFT)
Thu Oct 01, 2015 10:51 pm
My pi is set to login to console (no gui/desktop) and I have a TFT attached to it. However my console goes blank after a while, the TFT is still backlit but it's just black.
I've tried ediring /etc/kbd/config - changed POWERDOWN_TIME to 0 and BLANK_TIME to 0. Did not help.
How can I solve this?
(Jessie)
Axy
Re: Console goes blank after a while (on TFT)
Fri Oct 02, 2015 12:06 am
I've also tried the following command
setterm -blank 0 -powersave off -powerdown 0
and I get this as a response
setterm: terminal xterm does not support --blank
setterm: cannot (un)set powersave mode: Inappropriate ioctl for device
AndyD
Fri Oct 02, 2015 12:18 am
Have a look at this thread.
Axy
Fri Oct 02, 2015 12:25 am
@AndyD what's the solution in this case?
AndyD
Fri Oct 02, 2015 12:50 am
Hi @Axy, there is an ongoing conversation on the thread that a linked to above.
Axy
Fri Oct 02, 2015 12:33 pm
I believe I found a solution, not sure this is the best one or not.
No matter what I do, I've relaized that when I type
cat /sys/module/kernel/parameters/consoleblank
to console I get
as response. No workarounds above fixed it.
So I
sudo /boot/cmdline.txt
and added
consoleblank=0
to the end of the line.
So far it's working.
