grizzlyadams
Can I delay chromium in kiosk mode?
Thu Oct 01, 2015 11:20 pm
Hi.
I'm setting up a pi to run in kiosk mode as per the instructions in https://github.com/basdegroot/raspberry-pi-kiosk. Everything works as required. My pi is also running an Express server with a bunch of things behind it, that also works. But ... my Express instance is a bit slow starting up, and is not ready by the time Chromium in kiosk mode has loaded and looks for its intended URL. Is there some way I can delay the chromium startup process so Express has a chance to load?
My X startup script looks like
@lxpanel --profile LXDE-pi
@pcmanfm --desktop --profile LXDE-pi
@xset s off
@xset -dpms
@xset s noblank
@sed -i 's/"exited_cleanly": false/"exited_cleanly": true/' ~/.config/chromium/Default/Preferences
@chromium --noerrdialogs --kiosk http://127.0.0.1:3000/demo.html
I tried adding "sleep 5s" but I'm guessing that's not valid in this context. Any suggestions? Totally alternative routes are also good, even if it means a bit of coding, as long as it gets me there. Thanks!
firstness
Re: Can I delay chromium in kiosk mode?
Fri Oct 02, 2015 3:36 am
Not sure if this would work but you could replace the chromium entry with a Bash script.
#!/bin/bash
echo "Starting chromium in 5 seconds..."
sleep 5
chromium --noerrdialogs --kiosk http://127.0.0.1:3000/demo.html &
Save the above to /home/pi/start-chromium.sh (note the addition of & at the end of chromium line to start chromium as a background process, thus allowing the script to end immediately instead of waiting for chromium to close)
"Run chmod u+x start-chromium.sh" to give execute permission.
Replace chromium line in X startup script with "@/home/pi/start-chromium.sh"
grizzlyadams
Fri Oct 02, 2015 5:40 pm
Thanks firstness, that did exactly what I needed. Also, I learned how to call a bash script which I'm pretty sure I'll be using in the future. Much obliged.
firstness
Fri Oct 02, 2015 6:08 pm
No problem. I was also thinking that if chromium ever crashes you could have it restart automatically by editing the script like this:
#!/bin/bash
sleep 5
while :
    do
done
The script would stay running forever and restart chromium if it ever closes. I'm not sure if this would cause a problem with the X startup script considering it never exits but it could be worth a try. To end the script you would run "ps aux" to find the process id of the script and "kill [pid]"
grizzlyadams
Fri Oct 02, 2015 9:58 pm
Thanks again Firstness, that's another cool trick I've learned (this is my first week in Linux land).
For what it's worth, I switched Chromium for Epiphany (using xautomation to F11 full screen it after launch). Chromium 22 was too buggy to render my bleeding edge CSS3 animations.
firstness
Sat Oct 03, 2015 12:26 am
By the way you can try installing Chromium 45 if you have the newest Raspbian Jessie.
viewtopic.php?uid=160930&f=63&t=121195& ... 30GKU6JBE7
Bambamj
Fri Nov 06, 2020 12:47 pm
this is an old post but im doing the same could. I add this to the .bashrc file instead. thats where I have this code to get it to launch
[[ -z $DISPLAY && $XDG_VTNR -eq 1 ]] && startx -- -nocursor
