I've been using tightvncserver to sucessfully run remote sessions on my Pi but I'd like to be able to directly view/control the same session as I seen on my Pi HDMI connected monitor.
I understand I need to use x11vnc for this (which I've downloaded and installed) but I'm struggling with Mr Google to find a working example of what parameters to use with it.
Can anyone help please?
Simon
Setting up x11vnc on Raspbian
Seeking help with Scratch and I/O stuff for Primary age children
http://cymplecy.wordpress.com/ @cymplecy on twitter
Re: Setting up x11vnc on Raspbian
I'm sure someone asked a very similar question a few days ago. I don't think it was fully resolved though. I'll see if I can find the thread.
It was here...
http://www.raspberrypi.org/phpBB3/viewt ... 55#p129655
Don't know if you've seen that one (maybe it's where you got the x11vnc thing from?)
It was here...
Alex Eames RasPi.TV, RasP.iO
As you say - not really resolved
For things like this, you need the person who been there and got the t-shirt
Ta tho
Si
Ta tho
Si
thanks Simon. I was looking for the same answer and your solution worked.
Thanks Simon, I was looking for the same as well and worked for me as well.
Regards
Regards
I'm no expert but having spent some time trying various methods (without success), the following worked for me:
1. InstallNB I chose not to set a password
2. Auto-start
NB Previously configured auto-login & StartX by following: http://elinux.org/RPi_Debian_Auto_Login
Create new / edit existing ~/.xsessionrc file:NB no need to make it executable.
Comments:
-bg : run in background after screen setup. Without it I get a blank / black screen on local (& remote) display - had to SSH-in, to fix via CLI. So, this option seems *essential* for me, though is rarely mentioned!?
-nevershared -forever : on creating a new connection, drop existing. (I only need 1 connection). From x11vnc --help, this combo "guards against hung TCP connections that do not go away."
-nopw : I choose not to use a password; this prevents a warning.
-tightfilexfer : I use TightVNC client
-display 0 : default X11 server display
I use the TightVNC client, as UltraVNC connects but displays solid (red) window, no contents.
Hope this helps.
Cheers,
Pete.
References:
http://elinux.org/RPi_VNC_Server
http://www.penguintutor.com/linux/tightvnc
http://www.rpiforum.net/forum/tutorials ... -raspbian/
http://www.raspberrypi.org/phpBB3/viewt ... 63&t=24809
http://www.raspberrypi.org/phpBB3/viewt ... f=6&t=5540
1. Install
sudo apt-get install x11vnc
2. Auto-start
# Start X11VNC
x11vnc -bg -nevershared -forever -tightfilexfer -nopw -display :0
Comments:
Hope this helps.
Cheers,
Pete.
References:
hi Pete
Did you actually try
http://www.raspberrypi.org/phpBB3/viewt ... 62#p108862
because it worked for me and everyone else who's tried it
I use is on a daily basis as I'm remoting into battery powered robot RPi.
Its worked with both tightnvcviewer and ultravncviewer, both here at home and in 2 of my schools.
So I think its a runner
Simon
Simon
Hi Simon,
Thanks for your reply. Yeah, I did try that - it's near the end of http://www.raspberrypi.org/phpBB3/viewt ... 63&t=24809
Using the .config/autostart/x11vnc.desktop file, Ultravnc still gives me a solid red(ish) [on Auto] or blue [manual settings] window - no desktop contents.
With hindsight, I abandoned this method due to the above problem (I have) with UltraVNC [Win32, 1.0.9.6.1]; I've just confirmed it works fine with TightVNC.
Thanks again,
Pete.
Thanks again,
Pete.
Hi, first post. Have my headless Pi with x11vnc up and running, using the instructions on this page, thanks. Only issue is that if I boot the Pi without a monitor attached, I end up with a tiny little VNC window, apparently a default monitor size. If I boot with a monitor attached and then disconnect it, the VNC window is the size of the monitor that was previously attached. What do I need to do to tell x11vnc to create a session of a specific window size, e.g. 1920x1080? Thanks...
Figured out that it's not x11vnc that I need to tweek, but it's the X environment, so that when it's headless, it doesn't default to the small 656x416 window size. What do I need to change? A default 1024x768 would be enough for me.
Solved my own problem, got it working by forcing hdmi in config.txt. Defaults to a decent screen size now.
Could you post more details on how you did this?pbanders wrote:Solved my own problem, got it working by forcing hdmi in config.txt. Defaults to a decent screen size now.
I think he meant that you have to edit /boot/config.txt and force hdmi display.ghunter wrote:Could you post more details on how you did this?pbanders wrote:Solved my own problem, got it working by forcing hdmi in config.txt. Defaults to a decent screen size now.
hdmi_force_hotplug=1
After making this change i get a decent screen in my vnc connection.
PS: Sorry about my English. I'm not a native English speaker.
Hello PiMates,
Hope someone would find it helpful.
Step 1:
- By default PiCamera can’t be viewed over vnc.
- This link https://www.raspberrypi.org/blog/get-ba ... c-connect/ would help you to get started
Step 1:
- Enable VNC on the Raspberry Pi
- or you could follow a commandline sudo raspi-config > Interfacing Options > VNC > Enable
- Update your vnc, either go to https://www.realvnc.com/en/connect/down ... spberrypi/ download and install from vnc [preffered]
- Download the deb file from the above link, install using "dpkg -i <package>.deb"
- Check your vnc connect server version 6.3 should be good as of Aug 2018
- Start vnc server $vncserver :1
- Display looks too small and unscaled
- Fix it by changing few display parameters for hdmi in "$ sudo nano /boot/config.txt"
hdmi_ignore_edid=0xa5000080
hdmi_group=2
hdmi_mode=16
More info https://elinux.org/RPi_Configuration
Now you need to reboot "sudo reboot now"
- Now open VNC to the pi, and enable "experimental direct capture mode"
- Reconnect VNC
- Thats it Guys.
