Spectre
Problem with Touchscreen-Driver
Sun Oct 18, 2015 9:44 pm
i've got some trouble getting the Touchscreen running on Gentoo. I've installed the needed driver (rpi-ft5406) as Kernel (4.1.10-v7+) Module (also testet built-in). I've loaded the Module but nothing happens. Nether a Event-Device spawns nor a Event in dmesg happens.
Tested the Device with raspian and it worked. So what i'm missing here?
[edit]
I've installed arch-Linux and inspected the Kernel-Config. Was building the Kernel with the config from Arch-Linux but same Problem. The ft5406 is running on Arch but not on Gentoo.
Does the Device needs a firmware-blob or something else?! This would explain why the Device works on Raspian and Arch but not in Gentoo.
[/edit]
Best Regards Spectre
Spectre
Re: Problem with Touchscreen-Driver
Mon Oct 19, 2015 11:57 am
I've found the Problem...
The Perl-Script mkknlimg (in */scripts/) can't decompress a XZ compressed kernel... So it doesn't do it's voodoo to the Kernel. After rebuild the kernel and compressing it with gzip it's working.
[edit]
The final Problem is that unxz is not actual enough to support the Parameter "--single-stream". Updating xz-utils to 5.2.2 solves the Problem. I've opened a Issue on git because of that Problem.
[/edit]
Return to “Official Display”
