yanuarbp17
Contact: Yahoo Messenger
[HELP]error build openCV
Fri Oct 30, 2015 7:42 am
Linking CXX shared library ../../lib/libopencv_features2d.so
[ 64%] Built target opencv_features2d
[ 64%] Generating opencv_perf_features2d_pch_dephelp.cxx
Scanning dependencies of target opencv_perf_features2d_pch_dephelp
[ 64%] Building CXX object modules/features2d/CMakeFiles/opencv_perf_features2d_pch_dephelp.dir/opencv_perf_features2d_pch_dephelp.cxx.o
Linking CXX static library ../../lib/libopencv_perf_features2d_pch_dephelp.a
[ 64%] Built target opencv_perf_features2d_pch_dephelp
[ 64%] Generating perf_precomp.hpp
[ 64%] Generating perf_precomp.hpp.gch/opencv_perf_features2d_RELEASE.gch
[ 64%] Built target pch_Generate_opencv_perf_features2d
[ 64%] Building CXX object modules/features2d/CMakeFiles/opencv_perf_features2d.dir/perf/perf_agast.cpp.o
[ 64%] Building CXX object modules/features2d/CMakeFiles/opencv_perf_features2d.dir/perf/perf_batchDistance.cpp.o
[ 64%] Building CXX object modules/features2d/CMakeFiles/opencv_perf_features2d.dir/perf/perf_fast.cpp.o
[ 64%] Building CXX object modules/features2d/CMakeFiles/opencv_perf_features2d.dir/perf/perf_orb.cpp.o
[ 64%] Building CXX object modules/features2d/CMakeFiles/opencv_perf_features2d.dir/perf/perf_main.cpp.o
[ 64%] Building CXX object modules/features2d/CMakeFiles/opencv_perf_features2d.dir/perf/opencl/perf_fast.cpp.o
[ 65%] Building CXX object modules/features2d/CMakeFiles/opencv_perf_features2d.dir/perf/opencl/perf_orb.cpp.o
[ 65%] Building CXX object modules/features2d/CMakeFiles/opencv_perf_features2d.dir/perf/opencl/perf_brute_force_matcher.cpp.o
Linking CXX executable ../../bin/opencv_perf_features2d
[ 65%] Built target opencv_perf_features2d
[ 65%] Generating opencv_test_features2d_pch_dephelp.cxx
Scanning dependencies of target opencv_test_features2d_pch_dephelp
[ 65%] Building CXX object modules/features2d/CMakeFiles/opencv_test_features2d_pch_dephelp.dir/opencv_test_features2d_pch_dephelp.cxx.o
Linking CXX static library ../../lib/libopencv_test_features2d_pch_dephelp.a
[ 65%] Built target opencv_test_features2d_pch_dephelp
[ 65%] Generating test_precomp.hpp
[ 65%] Generating test_precomp.hpp.gch/opencv_test_features2d_RELEASE.gch
[ 65%] Built target pch_Generate_opencv_test_features2d
[ 65%] Building CXX object modules/features2d/CMakeFiles/opencv_test_features2d.dir/test/test_agast.cpp.o
[ 65%] Building CXX object modules/features2d/CMakeFiles/opencv_test_features2d.dir/test/test_detectors_regression.cpp.o
[ 65%] Building CXX object modules/features2d/CMakeFiles/opencv_test_features2d.dir/test/test_nearestneighbors.cpp.o
[ 65%] Building CXX object modules/features2d/CMakeFiles/opencv_test_features2d.dir/test/test_keypoints.cpp.o
[ 65%] Building CXX object modules/features2d/CMakeFiles/opencv_test_features2d.dir/test/test_fast.cpp.o
[ 65%] Building CXX object modules/features2d/CMakeFiles/opencv_test_features2d.dir/test/ocl/test_brute_force_matcher.cpp.o
[ 65%] Building CXX object modules/features2d/CMakeFiles/opencv_test_features2d.dir/test/test_orb.cpp.o
[ 65%] Building CXX object modules/features2d/CMakeFiles/opencv_test_features2d.dir/test/test_matchers_algorithmic.cpp.o
[ 65%] Building CXX object modules/features2d/CMakeFiles/opencv_test_features2d.dir/test/test_descriptors_regression.cpp.o
[ 65%] Building CXX object modules/features2d/CMakeFiles/opencv_test_features2d.dir/test/test_rotation_and_scale_invariance.cpp.o
[ 65%] Building CXX object modules/features2d/CMakeFiles/opencv_test_features2d.dir/test/test_brisk.cpp.o
[ 65%] Building CXX object modules/features2d/CMakeFiles/opencv_test_features2d.dir/test/test_mser.cpp.o
[ 66%] Building CXX object modules/features2d/CMakeFiles/opencv_test_features2d.dir/test/test_main.cpp.o
Linking CXX executable ../../bin/opencv_test_features2d
[ 66%] Built target opencv_test_features2d
[ 66%] Generating opencv_latentsvm_pch_dephelp.cxx
Scanning dependencies of target opencv_latentsvm_pch_dephelp
[ 66%] Building CXX object modules/latentsvm/CMakeFiles/opencv_latentsvm_pch_dephelp.dir/opencv_latentsvm_pch_dephelp.cxx.o
Linking CXX static library ../../lib/libopencv_latentsvm_pch_dephelp.a
[ 66%] Built target opencv_latentsvm_pch_dephelp
[ 66%] Generating precomp.hpp
[ 66%] Generating precomp.hpp.gch/opencv_latentsvm_RELEASE.gch
[ 66%] Built target pch_Generate_opencv_latentsvm
[ 66%] Building CXX object modules/latentsvm/CMakeFiles/opencv_latentsvm.dir/src/lsvmc_resizeimg.cpp.o
[ 66%] Building CXX object modules/latentsvm/CMakeFiles/opencv_latentsvm.dir/src/lsvmc_routine.cpp.o
[ 66%] Building CXX object modules/latentsvm/CMakeFiles/opencv_latentsvm.dir/src/lsvmc_latentsvmdetector.cpp.o
[ 66%] Building CXX object modules/latentsvm/CMakeFiles/opencv_latentsvm.dir/src/lsvmc_matching.cpp.o
[ 66%] Building CXX object modules/latentsvm/CMakeFiles/opencv_latentsvm.dir/src/lsvmc_parser.cpp.o
[ 66%] Building CXX object modules/latentsvm/CMakeFiles/opencv_latentsvm.dir/src/lsvmc_featurepyramid.cpp.o
[ 66%] Building CXX object modules/latentsvm/CMakeFiles/opencv_latentsvm.dir/src/lsvmc_function.cpp.o
[ 66%] Building CXX object modules/latentsvm/CMakeFiles/opencv_latentsvm.dir/src/lsvmc_latentsvm.cpp.o
[ 68%] Building CXX object modules/latentsvm/CMakeFiles/opencv_latentsvm.dir/src/precomp.cpp.o
Linking CXX shared library ../../lib/libopencv_latentsvm.so
[ 68%] Built target opencv_latentsvm
[ 68%] Generating opencv_perf_latentsvm_pch_dephelp.cxx
Scanning dependencies of target opencv_perf_latentsvm_pch_dephelp
[ 68%] Building CXX object modules/latentsvm/CMakeFiles/opencv_perf_latentsvm_pch_dephelp.dir/opencv_perf_latentsvm_pch_dephelp.cxx.o
Linking CXX static library ../../lib/libopencv_perf_latentsvm_pch_dephelp.a
[ 68%] Built target opencv_perf_latentsvm_pch_dephelp
[ 68%] Generating perf_precomp.hpp
[ 68%] Generating perf_precomp.hpp.gch/opencv_perf_latentsvm_RELEASE.gch
[ 68%] Built target pch_Generate_opencv_perf_latentsvm
[ 68%] Building CXX object modules/latentsvm/CMakeFiles/opencv_perf_latentsvm.dir/perf/perf_precomp.cpp.o
[ 68%] Building CXX object modules/latentsvm/CMakeFiles/opencv_perf_latentsvm.dir/perf/perf_main.cpp.o
[ 68%] Building CXX object modules/latentsvm/CMakeFiles/opencv_perf_latentsvm.dir/perf/perf_cascadeclassifier.cpp.o
Linking CXX executable ../../bin/opencv_perf_latentsvm
[ 68%] Generating opencv_test_latentsvm_pch_dephelp.cxx
Scanning dependencies of target opencv_test_latentsvm_pch_dephelp
[ 68%] Building CXX object modules/latentsvm/CMakeFiles/opencv_test_latentsvm_pch_dephelp.dir/opencv_test_latentsvm_pch_dephelp.cxx.o
Linking CXX static library ../../lib/libopencv_test_latentsvm_pch_dephelp.a
[ 68%] Built target opencv_test_latentsvm_pch_dephelp
[ 68%] Generating test_precomp.hpp
[ 68%] Generating test_precomp.hpp.gch/opencv_test_latentsvm_RELEASE.gch
In file included from /home/pi/opencv-3.0.0/build/modules/latentsvm/test_precomp.hpp:15:0:
/home/pi/opencv-3.0.0/modules/highgui/include/opencv2/highgui.hpp:698:1: fatal error: can’t write PCH file: No space left on device
 } // cv
compilation terminated.
modules/latentsvm/CMakeFiles/pch_Generate_opencv_test_latentsvm.dir/build.make:53: recipe for target 'modules/latentsvm/test_precomp.hpp.gch/opencv_test_latentsvm_RELEASE.gch' failed
make[2]: *** [modules/latentsvm/test_precomp.hpp.gch/opencv_test_latentsvm_RELEASE.gch] Error 1
CMakeFiles/Makefile2:10463: recipe for target 'modules/latentsvm/CMakeFiles/pch_Generate_opencv_test_latentsvm.dir/all' failed
make[1]: *** [modules/latentsvm/CMakeFiles/pch_Generate_opencv_test_latentsvm.dir/all] Error 2
Makefile:137: recipe for target 'all' failed
make: *** [all] Error 2
Hi.. I've some trouble when build openCV..
I just follow this instruction http://www.pyimagesearch.com/2015/10/26 ... an-jessie/
I try to "make clean" then "make" again, but same problem..
so..I need help to this problem... :D
thank in advance.. :)
AndyD
Re: [HELP]error build openCV
Fri Oct 30, 2015 8:56 am
You have run out of disk space. Try reclaiming some space by removing some of the bigger packages. For example if you don't use mathmatica, you could uninstall that. Also, you may be able to get some space back by cleaning the aptitude cache.
sudo apt-get clean
Fri Oct 30, 2015 11:03 am
A quick and dirty way to get a lot of space freed up is: sudo rm /var/cache/apt/archives/*.deb
yanuarbp17
Fri Oct 30, 2015 3:53 pm
thanks AndyD.. now I want to retry, hehe :D
Fri Oct 30, 2015 7:02 pm
DougieLawson wrote:A quick and dirty way to get a lot of space freed up is: sudo rm /var/cache/apt/archives/*.deb
or with less typing: sudo apt-get clean
It does the same thing. Equally quick, not dirty at all. :)
Return to “C/C++”
