JumpZero
ssh host keys generated on first boot
Sat Nov 07, 2015 2:58 pm
Today I had a look a the recently published MagPi "conquer the command line"
https://www.raspberrypi.org/magpi-issue ... ash_v1.pdf and found on page 48 this statement:
With Raspbian, you have a pair of keys (public and
private) in /etc/ssh/. Unfortunately, they’ll be the same as those
held by everyone else with a copy of the Raspbian image that you
downloaded.
I am very surprised by this. I have checked on 3 pi running Raspbian Wheezy all of them have different host keys. Also I remember when I re-installed a fresh Raspbian and ssh'ing to it from another computer I received a message about the host key has changed.
Also I mounted the Raspbian wheezy image (not yet switched to Jessie) and found there is only config files in /etc/ssh/ no keys at all. Hence I believe there is a script generating host keys at the very first ssh run.
Have I miss something? Is the above statement is true?
Jmp0
Re: ssh host keys generated on first boot
Sat Nov 07, 2015 5:48 pm
The above is 100% wrong. You've regenerated them as part of the first run of raspi-config.
The easy fix if you need to regenerate them is
sudo rm /etc/ssh/ssh_host*
sudo ssh-keygen -A
JumpZero
Sun Nov 08, 2015 4:02 pm
Dougie,
Thanks for the clarification.
It makes more sense this way.
Jmp0
Return to “Raspberry Pi OS”
