srhode66
64GB SD Card Problem
Fri Nov 27, 2015 11:04 pm
I own a Macbook. I downloaded NOOBS and formatted my 64GB SD CARD into exFAT format using SDFormatter.
According to the Instructions-ReadMe in NOOBS: I copy all the files from the NOOBS file I extracted and past them into my SD Card after it has been formatted.
So now I plug it into my Raspberry Pi 2 with the power supply and still nothing is happening.
Can anyone help?
mahjongg
Re: 64GB SD Card Problem
Sat Nov 28, 2015 12:12 am
NOOBS files can't be read by the boot system when they are in an exFAT partition, the partition MUST be an FAT32 partition, so after formatting in exFAT you must use a utility to convert the exFAT partition to FAT32 before copying any files to it.
The sticky, "common pitfalls for beginners" has a section on it.
srhode66
Sat Nov 28, 2015 12:58 am
Can't seem to find any utility for a MacBook that would covert the exFAT partition to FAT32?
Joe Schmoe
Sat Nov 28, 2015 1:04 am
srhode66 wrote:Can't seem to find any utility for a MacBook that would covert the exFAT partition to FAT32?
You can't "convert" one to the other, but you can reformat it to the desired filesystem type.
What does the command:
diskutil listFileSystems
display on your system?
Sat Nov 28, 2015 7:22 am
srhode66 wrote:I own a Macbook. I downloaded NOOBS and formatted my 64GB SD CARD into exFAT format using SDFormatter.
Can anyone help?
http://www.tweaking4all.com/hardware/ra ... e-pi-baker
srhode66
Sat Nov 28, 2015 7:42 pm
These file system personalities can be used for erasing and partitioning.
When specifying a personality as a parameter to a verb, case is not considered.
Certain common aliases (also case-insensitive) are listed below as well.
PERSONALITY USER VISIBLE NAME
ExFAT ExFAT
Free Space Free Space
(or) free
MS-DOS MS-DOS (FAT)
MS-DOS FAT12 MS-DOS (FAT12)
MS-DOS FAT16 MS-DOS (FAT16)
MS-DOS FAT32 MS-DOS (FAT32)
(or) fat32
HFS+ Mac OS Extended
Case-sensitive HFS+ Mac OS Extended (Case-sensitive)
(or) hfsx
Case-sensitive Journaled HFS+ Mac OS Extended (Case-sensitive, Journaled)
(or) jhfsx
Journaled HFS+ Mac OS Extended (Journaled)
(or) jhfs+
srhode66
Sat Nov 28, 2015 7:49 pm
Can anyone help?
The apple pi baker won't work on my laptop! It says it can't open due to an unidentified developer
srhode66
Sat Nov 28, 2015 8:02 pm
I have my 64GB SD Card formatted to exFAT right now. Can I use "disk utility" to simply reformat it to MS-DOS (FAT) format?
Sat Nov 28, 2015 8:10 pm
srhode66 wrote:I have my 64GB SD Card formatted to exFAT right now. Can I use "disk utility" to simply reformat it to MS-DOS (FAT) format?
I suspect so. Try it?
kusti8
Sat Nov 28, 2015 8:20 pm
You need to right click on the file and press open if it says it's from an unidentified developer. Then press open on the prompt and it should open.
srhode66
Sat Nov 28, 2015 8:54 pm
kusti8 wrote:You need to right click on the file and press open if it says it's from an unidentified developer. Then press open on the prompt and it should open.
For some reason it wasn't opening when I did that. Opened now though, Thanks kusti8.
