stroh
i2s port on header pins Rpi zero
Fri Dec 18, 2015 10:01 am
hi, i´m Stephan and I want to do a soundprojekt on pi zero. at the moment i´m not the lucky guy to have one in my hand.
so is there a i2s port on header pins on pi zero that i could use it in the future?
Re: i2s port on header pins Rpi zero
Fri Dec 18, 2015 11:26 am
The Pi0 has the same GPIO pin setup as the other Pi's which have I2S. However, the zero does not have the header soldered on, so you will need to do that, or solder wires direct to the board.
BMS Doug
Fri Dec 18, 2015 11:47 am
stroh wrote:hi, i´m Stephan and I want to do a soundprojekt on pi zero. at the moment i´m not the lucky guy to have one in my hand.
you may find this blog post by HiFiDuino useful:
Specifics:
GPIO 18 (Pin12) is BITCLOCK;
GPIO 19 (Pin 35) is LRCLOCK;
GPIO 20 (Pin 38) is DATA IN;
GPIO 21 (Pin 40) is DATA OUT;
Doug.
