k7cwa
How to change display timeout
Wed Dec 23, 2015 5:52 pm
I am running Raspbian on my Raspberry 2B unit. It works perfectly but I want to figure out how I can change the screen timeout time. I want to monitor a screen for long periods of time and I can't stop the screen from timing out and going blank. Where is this timeout period determined and set?
Re: How to change display timeout
Wed Dec 23, 2015 7:36 pm
k7cwa wrote:I am running Raspbian on my Raspberry 2B unit. It works perfectly but I want to figure out how I can change the screen timeout time. I want to monitor a screen for long periods of time and I can't stop the screen from timing out and going blank. Where is this timeout period determined and set?
sudo apt-get update
sudo apt-get install xscreensaver
Navyscourge
Sat Dec 26, 2015 1:19 pm
If you are using the GUI windowed display, open a Terminal screen and type
xset s noblank
xset s off
xset -dpms
That will stop it going blank. Unfortunately, if you reboot the Pi the screen will start blanking again. Still using the Terminal, type
sudo nano /etc/xdg/lxsession/LXDE/autostart
Add these lines at the bottom:
@xset s noblank
@xset s off
@xset -dpms
Then hold down the Ctrl key and press O (thats 'Oh'), press Enter to access the file name (don't change that), and then hold down the Ctrl key and press X (to exit)
HOD
Mon Mar 18, 2019 10:21 pm
Also the default X screensaver can have it's timeout changed by setting a value in seconds with:
@xset s 120
(in this example 120s or 2 minutes).
Regards,
Ian.
Andyroo
Mon Mar 18, 2019 11:08 pm
If you ever go headless (now that’s a strange thing to say) then there is an older thread where we hit our head against a problem where these do not help viewtopic.php?p=1426207
Fortunately the fix was worked out :lol: and is in the thread
klricks
Tue Mar 19, 2019 12:02 am
xset s noblank
xset s off
xset -dpms
@xset s noblank
@xset s off
@xset -dpms
xset s noblank is not needed but won't hurt.
The correct path to autostart is:
sudo nano /etc/xdg/lxsession/LXDE-pi/autostart
Note that if you haven't updated in awhile then autostart may still be at the old location:
nano /home/pi/.config/lxsession/LXDE-pi/autostart
klricks
Tue Mar 19, 2019 1:02 am
@xset s 120
In the Raspbian desktop there are 2 screen-blankers running at the same time both with default 10 min. timeout.
So you have to either set both to the same value or turn one of them off.
xset s 120
xset dpms 120 120 120
or
xset s 120
xset -dpms
To view the current settings:
xset q
klricks
Tue Mar 19, 2019 1:14 am
You did not mention if you are booting to desktop or running CLI only.
If CLI then see this: https://www.raspberrypi.org/documentati ... ensaver.md
If desktop then either use the xset commands as mentioned or install xscreensaver then set the mode: [Disable Screen Saver]
Note xscreenaver is a 40MB install and adds a background process.
