Kimovitzh
Installing node_latest_armhf.deb
Sun Dec 27, 2015 11:11 am
Hi.
I've just got my first Raspberry pi, and is total new to all this coding and command line and so on, so the inevitable happened and i got an error and googling it didn't help.
I'm trying to install the HomeKit with siri stuff, and is, this time, trying to follow the guide shown here: https://www.youtube.com/watch?v=RX2lBAby2hc
But, when i get to
dpkg -i node_latest_armhf.deb
i always encounter this error
dpkg: regarding node_latest_armhf.deb containing node:
 nodejs-legacy conflicts with node
  node (version 4.2.1-1) is to be installed.
  node provides node and is to be installed.
dpkg: error processing archive node_latest_armhf.deb (--install):
 conflicting packages - not installing node
As said, i've tried googling but didn't find anything, and since i'm new in this game i can't use my logics to figure this one out ... so what's happening? And how do I fix this?
Regards - Kim
asandford
Re: Installing node_latest_armhf.deb
Sun Dec 27, 2015 5:58 pm
For various reasons, the version of node bundled is pretty old.
To upgrade:
sudo apt-get remove nodered
sudo apt-get remove nodejs nodejs-legacy
sudo apt-get remove npm   # if you installed npm
Then for Pi 2:
curl -sL https://deb.nodesource.com/setup_4.x | sudo bash -
sudo apt-get install -y build-essential python-dev nodejs npm
Or Pi 0 /1:
wget http://node-arm.herokuapp.com/node_archive_armhf.deb
sudo dpkg -i node_archive_armhf.deb
sudo apt-get install -y build-essential python-dev npm
To re-install Node Red (if required):
sudo npm install -g --unsafe-perm  node-red
Kimovitzh
Sun Dec 27, 2015 6:46 pm
So instead of doing
wget http://node-arm.herokuapp.com/node_latest_armhf.deb
I just do
Right?
I've got the Pi 2 b.
asandford
Sun Dec 27, 2015 6:57 pm
Kimovitzh wrote:So instead of doing
I just do
Right?
Yes.
Those instructions were lifted from the Node Red docs.
Kimovitzh
Sun Dec 27, 2015 7:11 pm
asandford wrote: Yes.
Thanks a lot!
Is there anything else that should be changed, or is it just the two commands?
All commands from the video can be found here: https://drive.google.com/file/d/0B6GR9H ... dTVEE/view
asandford
Sun Dec 27, 2015 7:23 pm
Kimovitzh wrote: All commands from the video can be found here: https://drive.google.com/file/d/0B6GR9H ... dTVEE/view
I have no iDevices (apart from my work iphone - which is so locked down, I couldn't experiment with it even if I wanted to), so have no idea what else may be required.
Kimovitzh
Sun Dec 27, 2015 10:47 pm
Found a solution and it's up an running.
Thanks a lot :)
knowack
Sun Jan 03, 2016 1:21 am
What was your solution?
krishnadass
Fri May 20, 2016 2:10 pm
Hi, I am getting problem while installing node red.
sudo dpkg -i node_latest_armhf.deb
package architecture (armhf) does not match system (i386)
DirkS
Fri May 20, 2016 2:22 pm
krishnadass wrote:Hi, I am getting problem while installing node red.
Is this on a Raspberry Pi or are you trying to install this on an Intel based computer?
Return to “Raspberry Pi OS”
