elacson
Network drive on fstab does not mount on start-up
Thu Dec 31, 2015 1:45 am
I have been all over the web looking for an answer for this. Essentially, I have a network drive mounted via /etc/fstab and works pretty well via 'mount -a'. However, I won't mount after restart.
This seems to be a common issue that has to do with fstab doing the mount before the network is available. Tried this putting this script on init.d as suggested in one of the post in stackexchange:
#! /bin/sh
# /etc/init.d/mountscript
### BEGIN INIT INFO
# Provides: Mounting of all drives
# Required-Start: $remote_fs $syslog
# Required-Stop: $remote_fs $syslog
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: Simple script to mount drives at boot
# Description: Added 30jan 2014
### END INIT INFO
#Now mount all drives
sudo mount -a
echo "All drives mounted"
Tested it with the following which works fine:
sudo /etc/init.d/mountscript start
...and finalled registered the script to be run at start-up:
sudo update-rc.d mountscript defaults
Everything seems to check well until I did a restart and the drive is not yet mounted. Starting the script manually mounted back the drive. This one seems to work fro most people but does not seem to work for me. I am running on Raspbian Jessie 4,1 with the latest updates,
Would appreciate some wisdom,
Erik
Re: Network drive on fstab does not mount on start-up
Thu Dec 31, 2015 9:35 am
Have you added
,x-systemd.automount
to the lines in /etc/fstab? Try that and you won't need your script running at boot time.
elacson
Fri Jan 01, 2016 4:05 am
Thanks for the reply. I disabled the script and modified /etc/fstab as follows. but still does not mount in startup:
proc /proc proc defaults 0 0
/dev/mmcblk0p1 /boot vfat defaults 0 2
/dev/mmcblk0p2 / ext4 defaults,noatime 0 1
//thisisoffline/seagate\040backup\040plus\040drive /media/networkshare/seagatedrive cifs guest 0 0 ,x-systemd.automount
# a swapfile is not a swap partition, so no using swapon|off from here on, use dphys-swapfile swap[on|off] for that
JimmyN
Fri Jan 01, 2016 5:07 am
It just needs a little re-arranging to get everything in the right column.
//thisisoffline/seagate\040backup\040plus\040drive /media/networkshare/seagatedrive cifs guest,x-systemd.automount 0 0
LesGirauds
Fri Jan 01, 2016 7:01 pm
I had the same problem with a recent project; network drives would not mount from fstab. Even in a script started at startup (init.d) they wouldn't. Running the script manually (after boot up) worked. As did, as you say, mount -a (when I had the mount in the fstab) Searching the web suggested what was called a 'race condition' - basically the Pi boots more quickly than the network is recognised.
The way I got around it was to code a simple 'sleep 10' into my script. Not ideal but it worked.
I noted that in the recent Raspbian Jessie image, the rasp-config utility has the option to have the Pi boot process wait for network. Maybe it's always been there, I don't know, but it's worth a look.
rubikwizard
Fri Jan 01, 2016 7:13 pm
This works really well, and worth a try.
elacson
Sat Jan 02, 2016 9:01 am
This returned an invalid argument error. Will try via raspi-config worse case.
Thanks to all!
Cheers!
Erik
Gedarius
Sun Jul 10, 2016 9:17 pm
sorry to late reply, but i had the same problem and this is how i solve it:
first give permission to your mount point:
sudo chown -R pi:pi /mnt/HD1
sudo chmod -R 775 /mnt/HD1
sudo setfacl -Rdm g:pi:rwx /mnt/HD1
sudo setfacl -Rm g:pi:rwx /mnt/HD1
then, write the line below in the fstab:
//192.168.0.111/myNetworkFolder     /mnt/HD1   cifs username=MyUsr,password=MyPass,sec=ntlm,uid=pi,gid=pi,_netdev,xsystemd.automount 0 0
username and password parameters are credentials of you network drive, in my case, its a FTP from my router (a USB pendrive)
pay attention on the sec=ntlm parameter, this make all the difference for me
this is it, reboot your raspberry and see it works =]
Return to “Raspberry Pi OS”
