yoosi
Virtual Printer
Wed Jan 06, 2016 12:28 am
I work with a legacy server that sends LPR print jobs to a given IP address at scheduled times. It is headless and no user interaction is required. I'd like to replace the existing printer with a Rasberry Pi that emulates a printer. Instead of spitting out paper, it would save the print job as a timestamped PDF on a SAMBA file share. Do you know of an existing solution I can work with? I'm prepared to write the software if needed but it isn't ideal.
Re: Virtual Printer
Wed Jan 06, 2016 12:58 am
CUPS has a driver that will write a PDF from a virtual printer.
http://www.cups-pdf.de/
Re: Virtual Printer
Wed Jan 06, 2016 7:08 am
DougieLawson wrote:CUPS has a driver that will write a PDF from a virtual printer.
In Raspbian:
sudo apt-get install cups-pdf
yoosi
Re: Virtual Printer
Sat Jan 09, 2016 11:14 pm
Thanks all. I'll give this a shot!
JuicyGoose
Re: Virtual Printer
Thu Jan 12, 2017 4:14 am
Has anybody had any success with this method? If so, could you post your steps? I am seeking to do something similar with saving PDFs from a printer.
Cheers
Return to “Other projects”
