plugwash
mirror redirection system available for testing
Sun Aug 05, 2012 10:59 am
I have now set up mirrorbrain to provide mirror redirection services for raspbian. It is available at http://mirrordirectortest.raspbian.org/raspbian
I will point mirrordirector.raspbian.org when I am sure it is working correctly and when I have more mirrors set up.
I chose mirrorbrain over the http.debian.net code because the http.debian.net code makes (in particular it assumes that the mirrors are doing 2-stage syncs with trace files which most of ours are not)
plugwash
Re: mirror redirection system available for testing
Fri Aug 10, 2012 12:52 am
has anyone actually tested this yet? if so can you please provide feedback on whether it works fine for you. The system seems to be working fine to me but i'd like some feedback before I throw the switch and point all our users at it.
paaland
Fri Aug 10, 2012 8:29 pm
What exactly do you want us to test? I did a quick test and I was sent to a working mirror. But it was not the closest one, but I'm not sure how you decide where to send request and if all the mirrors from the Wiki is included or not.
Dragon 32>BBC Model B>PC>PC>PC>PC>Raspberry PI (circle complete)
plugwash
Fri Aug 10, 2012 8:47 pm
Mostly I want people to use it as their apt source for a while and make sure things still work for them.
Which mirror were you sent to? Not all mirrors on the wiki are included because they either didn't respond to my request for permission or because of other issues.
aboudou
Sat Aug 11, 2012 10:02 am
plugwash wrote:Which mirror were you sent to? Not all mirrors on the wiki are included because they either didn't respond to my request for permission or because of other issues.
Is it possible to know (or have a way to know) which mirrors are included ? As the owner of one of the mirrors, I suppose I would have been notified in case of issue ?
Regards
https://goddess-gate.com/ - My main website
http://raspberrypi.goddess-gate.com/ - A website about (and hosted by) my Raspberry Pi
https://twitter.com/boudouarnaud - Follow me on Twitter
http://www.fablab-sud31.fr/ - Fab Lab Sud31-Val d'Ariège
plugwash
Sat Aug 11, 2012 12:32 pm
I don't think there is a way for the general public to get the list directly but the current list is
raspbian:~# mb list
raspbian.canterburycomputers.com
mirror.de.leaseweb.net
goddess-gate.com
mirror.nl.leaseweb.net
mirror.us.leaseweb.net
ramses.wh2.tu-dresden.de
distribution-us.hexxeh.net
mirror.aarnet.edu.au
distribution-eu.hexxeh.net
raspbian:~#
aboudou
Sat Aug 11, 2012 1:51 pm
Nice, thanks :)
jerry.tk
Sun Aug 12, 2012 10:25 am
I installed Raspbian using installer pointed to mirrordirectortest without any problems. Will use it as a source for a while.
adskiremote
Thu Nov 01, 2012 3:47 am
I'm having problems with the mirror director. I'm in Thailand and it connects to a university in China which often fails.
Can someone advise me on a UK or other reliable mirror.
Thank you.
Adam
adskiremote
Thu Nov 01, 2012 11:28 am
Worked it out myself.
edited apt-get sources.list.
Removed the mirror director and used archive.raspberrypi.org.....
If anyone else has problems with the China mirror then there's your answer ;-)
plugwash
Thu Nov 01, 2012 12:18 pm
Based on this comment I have now decided to restrict that mirror to serve china only.
adskiremote wrote: Removed the mirror director and used archive.raspberrypi.org.....
umm, archive.raspberrypi.org is the foundation's repo for the packages they add to raspbian in their images. The main repo for raspbian is archive.raspbian.org.
HZimmer
Fri Apr 01, 2016 5:28 pm
Please remove mirror.nbtelecom.com.br. It is a mess and preventing updates and pkg installations.
Return to “Raspberry Pi OS”
