Fran008
Integrated Bluetooth not woking in RPi 3
Wed Mar 02, 2016 12:57 pm
Hello.
I am trying to test the integrated bluetooth service with my new Raspberry Pi 3 and it doesn't work.
Here's what I do, in bold, and the responses. Note: it happens in an updated RetroPie, but also in an updated Raspbian.
pi@retropie:~ $ sudo service bluetooth status
● bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled)
Active: inactive (dead)
Docs: man:bluetoothd(8)
pi@retropie:~ $ sudo service bluetooth start
Job for bluetooth.service failed. See 'systemctl status bluetooth.service' and 'journalctl -xn' for details.
Active: failed (Result: exit-code) since Wed 2016-03-02 12:46:04 UTC; 4s ago
Process: 1108 ExecStart=/usr/lib/bluetooth/bluetoothd (code=exited, status=203/EXEC)
Main PID: 1108 (code=exited, status=203/EXEC)
Mar 02 12:46:04 retropie systemd[1]: bluetooth.service: main process exited...EC
Mar 02 12:46:04 retropie systemd[1]: Failed to start Bluetooth service.
Mar 02 12:46:04 retropie systemd[1]: Unit bluetooth.service entered failed ...e.
Hint: Some lines were ellipsized, use -l to show in full.
dgordon42
Re: Integrated Bluetooth not woking in RPi 3
Wed Mar 02, 2016 1:25 pm
I believe you need:
sudo apt-get update
sudo apt-get install pi-bluetooth
Hope this helps,
Dave.
Douglas6
Wed Mar 02, 2016 1:34 pm
I'm guessing bluez-firmware is missing. Pi-bluetooth should fix that.
Wed Mar 02, 2016 1:40 pm
also
sudo apt-get install blueman
to get some gui tools
ShiftPlusOne
Wed Mar 02, 2016 1:47 pm
As an alternative to blueman, bluetoothctl is a command line tool which works quite well and is already installed. I've found blueman to be very slow, glitchy and, in some parts, unusable.
Wed Mar 02, 2016 2:51 pm
ShiftPlusOne wrote:As an alternative to blueman, bluetoothctl is a command line tool which works quite well and is already installed. I've found blueman to be very slow, glitchy and, in some parts, unusable.
https://wiki.archlinux.org/index.php/bl ... ia_the_CLI
Fran008
Wed Mar 02, 2016 5:04 pm
Thank you so much: now it works on RetroPie! I have not tested in Raspbian yet, but all i wanted to do is play with my PS3 wireless controller. "sudo apt-get install pi-bluetooth" did the trick, so mission accomplished (I think you could mark it as solved).
Bobylein
Thu Mar 03, 2016 7:50 pm
I am using osmc and if enter:
sudo apt-get install bluetooth-pi
it returns
E: Unable to locate package bluetooth-pi
any idea which source I need to add to "/etc/apt/sources.list"?
Douglas6
Thu Mar 03, 2016 7:53 pm
Try
Bobylein
Thu Mar 03, 2016 8:09 pm
Douglas6 wrote:Try
No luck :(
Thu Mar 03, 2016 8:24 pm
Bobylein wrote:I am using osmc and if enter:
it returns
Best to ask on the osmc forum, but I believe osmc needs to update some BT packages before BT works on the Pi3.
Douglas6
Thu Mar 03, 2016 8:25 pm
It's in the regular Raspbian Jessie repo; not sure how that works with OSMC. You might be better off with the old
But best to ask on the OSMC forum.
alanjds
Wed Jul 27, 2016 2:11 pm
To have pi-bluetooth package and others, I had to manually add this lines to /etc/apt/sources.list :
deb http://archive.raspberrypi.org/debian/ jessie main staging
deb-src http://archive.raspberrypi.org/debian/ jessie main staging
Then, following the guide on https://www.pi-supply.com/make/fix-rasp ... th-issues/, had done:
sudo apt-get update
sudo apt-get upgrade -y
sudo apt-get dist-upgrade -y
But bluetooth only started to work after installing raspberrypi-sys-mods: (somebody told to, but I do not remember where)
sudo apt-get install raspberrypi-sys-mods
sudo usermod -G bluetooth -a volumio
After all this, the BT seems to be working. Check via: systemctl
systemctl status hciuart.service
Husker53
Wed Aug 10, 2016 3:43 pm
I asked this same question over on the FPP site, but this looks like a more appropriate place to post this question (so sorry if it looks like I am shotgunning the question).
Sorry for the bother and here is another Raspberry Pi/FPP rookie question. Got my new Pi 3 yesterday and loaded FPP & got it running without much difficulty. Can access the Pi via wireless or wired (ethernet). However, I want to use bluetooth to play audio but can not figure out how to get BT to work. Whenever I do anything to attempt to access bluetooth (apt-get <anything bluetooth> via the command line), I get the alert ""e: Unable to locate package pi-bluetooth".
I have seen this same error referenced a lot on the internet but have not found anywhere that definitively provides a solution. Do you think the recommendations in this post are applicable to my problem?
I have tried all the apt-get updates/upgrades etc, with no luck. Any help would be greatly appreciated. Perhaps the answer is already on this site and I just missed it. I have not yet tried editing as suggesting here, as I don't want to needlessly screw anything else up.
Douglas6
Wed Aug 10, 2016 5:22 pm
After Googling 'FPP' ("The Falcon Player is a standalone sequence player allowing playback of your sequences without a dedicated PC."), I still don't know what it is, or what a 'sequence' is. Specifically, no idea what OS it uses. Apparently, not Raspbian. You could edit the sources.list to include the Raspbian repo, but no telling if it will play nice with FPP. Best to ask the FPP guys.
SWSboarder13
Wed Feb 01, 2017 4:24 am
Hi, I appear to be getting a similar error with my RPi 3 running retropie. I keep getting "failed to start configure bluetooth modems connected by uart" and "failed to start bluetooth service".
I have tried the whole:
sudo apt-get update
And reinstalling them, but nothing has seemed to fix my issue.
I have two RPi3 controllers, and it works on one but not the other; same SD Card was used in both. This all starting after doing an update all packages on the pi that doesn't work (which is why I assume it is not a hardware thing). Any other suggestions or ideas would be really appreciated.
