sai1995
C++ internal compile error
Tue Mar 29, 2016 6:55 am
Hi again
Im building opencv. I was doing MAKE, but now at 91% after 8 hours of waiting im facing the following issue guys
c++: internal compiler error: killed (program cc1plus)
and it states certain modules have failed target directories and all! normal make interrupt issues! :(
I gave a go at google.. it said that its because of the compiler and it ran out of memory! how to fix this guys..please help me
Im using ubuntu mate 15.10 with pi 2 and i did job 2 -j2 in make command
Thanks in advance
AndyD
Re: C++ internal compile error
Tue Mar 29, 2016 8:09 am
You can create a swap file. There is a thread about it in the C/C++ sub forum about building g++ on the Raspberry Pi that has the specific ... is it possible to compile a newer gcc/ g++ on the pi itselve
jahboater
Tue Mar 29, 2016 9:28 am
To create a 1GB swapfile. You will need to re-do the swapon if you reboot the Pi.
sudo dd if=/dev/zero of=/swapfile1GB bs=1M count=1024
sudo mkswap /swapfile1GB
sudo swapon /swapfile1GB
topguy
Tue Mar 29, 2016 9:51 am
You could also remove the "-j2" which makes it run two build jobs in parallel, that should also reduce memory usage.
sai1995
Tue Mar 29, 2016 10:57 am
thank you all !
what topguy suggested did the trick! processing 2 jobs was a bit more for this device! :)
Thank you jahboater and andy.. for suggesting me those idea. As im a noob i followed topguy
Thanks all !
