I have a playback error with VC using Raspbian and Kodi 16.0 (also in 15.2). When I try to play IPTV and some MKV videos, Kodi only shows a black screen and logs the following errors:
mmal: mmal_vc_port_enable: failed to enable port vc.ril.video_decode:in:0(MVC ): ENOMEM
mmal: mmal_port_enable: failed to enable port vc.ril.video_decode:in:0(MVC )(0x664b6340) (ENOMEM)
mmal: mmal_port_enable: failed to enable port vc.ril.video_decode:in:0(MVC )(0x564c51f0) (ENOMEM)
mmal: mmal_vc_port_enable: failed to enable port vc.ril.image_fx:out:0(OPQV): ENOSPC
mmal: mmal_port_enable: failed to enable port vc.ril.image_fx:out:0(OPQV)(0x5e3c1b70) (ENOSPC)
mmal: mmal_vc_port_send: no pool on port 0x6ebfea40
mmal: mmal_port_send_buffer: vc.ril.video_decode:out:0(OPQV): send failed: EINVAL
mmal: mmal_port_disable: port vc.ril.video_decode:out:0(OPQV)(0x6ebfea40) is not enabled
mmal: mmal_connection_disable: output port couldn't be disabled
mmal: mmal_port_enable: failed to enable port vc.ril.image_fx:out:0(OPQV)(0x72beda20) (ENOSPC)
mmal: mmal_vc_port_send: no pool on port 0x72b82a50
mmal: mmal_port_disable: port vc.ril.video_decode:out:0(OPQV)(0x72b82a50) is not enabled
mmal: mmal_connection_disable: output port couldn't be disabledCould anyone help me fixing it? Thanks in advance.
