wlan0 IEEE 802.11bgn ESSID:"XXXXXXXX"
Mode:Managed Frequency:2.462 GHz Access Point: 9C:C1:72:F4:31:5A
Bit Rate=72.2 Mb/s Tx-Power=31 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Encryption key:off
Power Management:on
Link Quality=61/70 Signal level=-49 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:1927 Invalid misc:0 Missed beacon:0
iw wlan0 station dump
Station XX:XX:XX:XX:XX:XX (on wlan0)
inactive time: 0 ms
rx bytes: 3919818827
rx packets: 6473534
tx bytes: 349515425
tx packets: 2184210
tx failed: 1929
signal: -48 [-48] dBm
tx bitrate: 72.2 MBit/s
rx bitrate: 65.0 MBit/s
authorized: yes
authenticated: yes
WMM/WME: yes
TDLS peer: yes
iw phy:
Wiphy phy0
max # scan SSIDs: 10
max scan IEs length: 2048 bytes
Retry short limit: 7
Retry long limit: 4
Coverage class: 0 (up to 0m)
Device supports roaming.
Device supports T-DLS.
Supported Ciphers:
* WEP40 (00-0f-ac:1)
* WEP104 (00-0f-ac:5)
* TKIP (00-0f-ac:2)
* CCMP (00-0f-ac:4)
* CMAC (00-0f-ac:6)
Available Antennas: TX 0 RX 0
Supported interface modes:
* IBSS
* managed
* AP
* P2P-client
* P2P-GO
* P2P-device
Band 1:
Capabilities: 0x1020
HT20
Static SM Power Save
RX HT20 SGI
No RX STBC
Max AMSDU length: 3839 bytes
# cat /lib/firmware/brcm/brcmfmac43430-sdio.txt
# NVRAM file for BCM943430WLPTH
# 2.4 GHz, 20 MHz BW mode
# The following parameter values are just placeholders, need to be updated.
manfid=0x2d0
prodid=0x0727
vendid=0x14e4
devid=0x43e2
