MomuuBhaii
how to record video using webcam in pi sd card [obsolete]
Tue Apr 12, 2016 3:07 pm
hi everybody. this is my first time to ask question here.
first of all excuse my English :P
let me tell u about my concept.
i am trying to record video using webcam, starting at specific time ( like 11:00am and stopping at 12:00pm ) and save it automatically in the specific folder on the desktop.
i have pi-2 with Raspbian installed and a webcam.
plz help me ,i tried to follow many tutorials on youtube.com and other sites but failed.
thanks in advance :)
MarcScott
Re: how to record video using webcam in pi sd card
Thu Apr 14, 2016 8:30 am
Can you post the make and model of the webcam please.
MomuuBhaii
Thu Apr 14, 2016 11:22 am
this is the webcam i have.
product of DANY.
MarcScott
Thu Apr 14, 2016 12:37 pm
Can you try this for me?
sudo apt-get update && sudo apt-get install fswebcam
cd ~/
You should see an image called web-cam-shot.jpg in your home directory
MomuuBhaii
Thu Apr 14, 2016 6:13 pm
Thank you sir :)
Will you please also tell me , how to record video for 2mins using webcam ???
Your help will solve my problem :)
kolban
Fri Apr 15, 2016 3:46 am
For recording a video for a period of time, I use:
ffmpeg -t 120 -f v4l2 -framerate 25 -video_size 640x80 -i /dev/video0 output.mkv
The "-t time" flag specifies the duration of the recording in seconds.
FREE book on Raspberry Pi usage and programming
https://leanpub.com/pi
MomuuBhaii
Fri Apr 15, 2016 11:56 am
Bash error :(
sir i am working in python IDLE medium and want to record video e.g at 9:00am for 2 mins (every day). so what would be the code for this process ?
MarcScott
Fri Apr 15, 2016 12:27 pm
Sorry, I didn't read your post properly. Though you wanted images.
kolbans command can be used in Python
Make sure you have ffmpeg
sudo apt-get install ffmpeg
Then in Python:
import os
os.system('ffmpeg -t 120 -f v4l2 -framerate 25 -video_size 640x80 -i /dev/video0 -t 300 output.mkv')
MomuuBhaii
Sat Apr 16, 2016 7:23 am
sir thanks for the reply :) but the code still not working :(
when i execute it, a command window appears for a quarter of a second and then disappears in the shell.
MarcScott
Wed Apr 27, 2016 6:35 am
Is there no video file in the directory that holds your python script?
YuvrajSandip
Tue Mar 21, 2017 6:16 pm
Sir,it says no ffmpeg library exist..
Could you please tell us an alternate library to install or how to get the library installed?
tsteles
Tue Apr 18, 2017 6:50 pm
You can use
sudo apt-get install libav-tools
and then write "avconv" instead of "ffmpeg" or create a alias.
See this viewtopic.php?t=125367
tsteles
Tue Apr 18, 2017 7:24 pm
Example:
avconv -t 10 -f video4linux2 -i /dev/video0 video0.avi
OutsourcedGuru
Tue Jun 20, 2017 12:04 am
Keep in mind that the 8MP Pi NoIR v2 camera at its highest resolution probably eats 1GB of memory every 8 minutes of video. So in perhaps 24 minutes or so you could fill your partition if you have a 4GB card.
Return to “Staffroom, classroom and projects”
