The_Handy_Andy
USB hub mod
Tue Apr 19, 2016 3:56 pm
Hi hoping for a bit of help. The first image is of the PCB of a hub I got cheap from Maplin (Unitek Y-2142) where:
A. Power in (pin is +)
B. Is the host conection
C. are USB ports
D. Is a 2A (max) iPod charging port (no data connection)
What I am thinking of doing to remove the risk of backfeed (which may be a good/bad thing), is to cut the track at point 1 and solder a diode between points 2 and 3.
The questions I have are:
1. Is this a good idea / will it work?
2. What diode should I use?
Andrew
The_Handy_Andy
Re: USB hub mod
Tue Apr 19, 2016 3:57 pm
PS the images have come out in the wrong order (doh!)
gregeric
Re: USB hub mod
Tue Apr 19, 2016 4:13 pm
With what model Pi will you use the hub?
If Zero, use it unmodified & allow it to backpower - just don't connect any other power supplies. Similarly with the A+, though be aware you'd be bypassing the main 2A polyfuse protection.
Other Pi with 40-pin header: just cut the track & don't bother with a diode. A Schottky diode can be fitted if you insist / want to use it as an unpowered hub as an occasional option.
The_Handy_Andy
Re: USB hub mod
Tue Apr 19, 2016 6:06 pm
Iv'e got 2 Pi2s.
gregeric
Re: USB hub mod
Tue Apr 19, 2016 6:20 pm
Cut the track in that case. Diode (anode Pi side, cathode hub side) optional, only of use should you remove the hub's own power cable.
Return to “Other projects”
