Duhjoker
Incorrect login or password Pi 3
Tue May 03, 2016 2:39 am
I just booted up my Pi after installing a fresh Raspbian Jessie and I'm having a couple problems.
After doing a sudo raspi-config and rebooting cannot login. I have not changed the password or the login in any way. It first started doing this when it would boot to the desk top and I couldn't log out to to the cli and the password and login kept saying it was incorrect.
Now after running sudo raspi-config and making it boot to the cli I can't get past the password or login to be recognized.
Rive
Re: Incorrect login or password Pi 3
Tue May 03, 2016 3:19 am
Are you using special char in password like #? Or is it 'raspberry'? Type the password in the username and see if it is actually entering the correct char.
I noticed mine did that as it kept defaulting back to uk keyboard. I had to end up setting the keyboard default to us.
DNPNWO
Duhjoker
Tue May 03, 2016 3:22 am
Like i said i didnt change the password or login.
Ive tried raspberry and pi and pi and raspberry
Rive
Tue May 03, 2016 3:28 am
Duhjoker wrote:Like i said i didnt change the password or login.
Default is:
pi
raspberry
So...
You expanded the file system after install of the OS?
You did not login as root (sudo su startx) ?
No one else has access to the pi3?
I suggest you restore your backup
DNPNWO
Duhjoker
Tue May 03, 2016 3:34 am
I just burned the image to the sd card my self 5 minutes before installing it into my Pi 3. The card was on my person the whole time.
I just re-installed it once more. Expanded the file system and yada yada then fed it the wi-fi password and did sudo apt-get and sudo apt-get -y git dialog.
After re-booting now it goes straight to the desktop and freezes. I've used two mice and two keyboards and nothing.
Rive
Tue May 03, 2016 3:39 am
Duhjoker wrote:I just burned the image to the sd card my self 5 minutes before installing it into my Pi 3. The card was on my person the whole time.
So everything works fine until you try to install the retropie emulation?
DNPNWO
klricks
Tue May 03, 2016 3:40 am
After expanding.... "yada yada" above MUST include reboot before attempting any updates.
Duhjoker
Tue May 03, 2016 3:43 am
No I wasn't trying to do retro pie those two update commands were with my set up guide that I can't find right now.
Yes I rebooted before the updates. It started freezing after installing the two commands though.
Rive
Tue May 03, 2016 3:48 am
Duhjoker wrote:No I wasn't trying to do retro pie those two update commands were with my set up guide that I can't find right now.
Then restore your backup and don't install and see if issue reoccurs
DNPNWO
Duhjoker
Tue May 03, 2016 3:50 am
I can't do that. It freezes after going to desktop. I have no mouse or keyboard control
Rive
Tue May 03, 2016 3:53 am
Duhjoker wrote:I can't do that. It freezes after going to desktop. I have no mouse or keyboard control
So you are unable to physically remove power, remove sdcard, put it into a reader on pc, clean it with something like diskpart 'clean' command, then write the backup image you should have made using something like diskimager?
DNPNWO
Duhjoker
Tue May 03, 2016 3:57 am
I don't know what's going on!!! Now I can use the mouse and keyboard and the password is working.
Sooooooooo weird I never had this problem on my 2 or zero.
Duhjoker
Tue May 03, 2016 4:23 am
Im gonna try to re burn the image again. For some reason it doesnt like any of my mice or keyboard.
dogoncouch
Sun Sep 08, 2019 7:22 pm
I just figured out what might be your issue, after having this problem myself repeatedly.
I was setting the password, and THEN changing the keyboard layout. When you go from UK to US keyboard layout, a few special characters move to different parts of the keyboard, like @ and ". I noticed that the initial boot setup for the full GUI versions of raspbian set the keyboard layout before having you set your password, so I tried it in that order and it solved the problem. Hope this helps.
