dancer3103
Wlan Stick with RTL8192EU Chipset
Mon May 16, 2016 3:45 pm
2016-05-16 15_41_00-Program Manager.png (39.28 KiB) Viewed 36253 times
Hello and good afternoon,
at first, please excuse my poor English, i am from Germany and try my best to explain as good as possible.
This morning i made an updat of my Raspian System. The RTL8192EU Driver is not in the repos include.
In the former Version of Raspberry i build the Driver with some help, but in this Version i hac an Error.
Everything is fine until i get to the point "sudo make ARCH=arm"
i get the Message:
pi@raspberrypi:~/rtl8192eu-linux-driver $ sudo make ARCH=arm
make ARCH=arm CROSS_COMPILE= -C /lib/modules/4.4.9-v7+/build M=/home/pi/rtl8192e u-linux-driver modules
make[1]: *** /lib/modules/4.4.9-v7+/build: Datei oder Verzeichnis nicht gefunden . Schluss.
Makefile:1335: recipe for target 'modules' failed
make: *** [modules] Error 2
Translation: File or Directory not found Exit
The Make command is searching for Kernel Header which are absent, where is a place to Download the Kernel Header for 4.4.9-v7+????
MrEngman
Re: Wlan Stick with RTL8192EU Chipset
Mon May 16, 2016 7:54 pm
The error is because the link to the linux source is missing. You can make the link with command
sudo ln -s /home/pi/src/linux /lib/modules/$(uname -r)/build
You will need to change directory /home/pi/src/linux to where your Linux source/headers are stored.
To get the linux source to compile your driver you can look here. I do not use this but I have seen many people recommend this.
I compile the 8192eu driver and you can download and install it using commands
wget https://dl.dropboxusercontent.com/u/80256631/8192eu-4.4.9-v7-884.tar.gz
tar xzf 8192eu-4.4.9-v7-884.tar.gz
./install.sh
MrEngman
fukipa
Sat May 28, 2016 6:29 am
Hi MrEngman,
I have tried to build a .ko module for TP-Link TL-WN823N 300Mbps Mini Wireless N USB Adapter but in vain.
make[1]: *** [kernel/bounds.s] Error 2
Makefile:990: recipe for target 'prepare0' failed
make: *** [prepare0] Error 2
make: *** Waiting for unfinished jobs....
  HOSTCC  scripts/dtc/dtc-parser.tab.o
  HOSTLD  scripts/genksyms/genksyms
  HOSTLD  scripts/dtc/dtc
Makefile:555: recipe for target 'scripts' failed
make: *** [scripts] Error 2
I am using raspbian latest version.
uname -a
Linux kraken-pi 4.4.11-v7+ #888 SMP Mon May 23 20:10:33 BST 2016 armv7l GNU/Linux
lsusb
Bus 001 Device 005: ID 2357:0109
Bus 001 Device 004: ID 03f0:0024 Hewlett-Packard KU-0316 Keyboard
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
I have tried to use use your 8192eu.ko you have compiled also. It is not picking up ID ID 2357:0109- which is fairly new device
The driver is 8192eu.ko
http://www.tp-link.com/res/down/soft/TL ... _Linux.zip
Could you please compile this .ko file for me ( and others who are stuck with this TP-Link TL-WN823N )
Thanks and Regards
fukipa
lesliewednesday
Tue May 31, 2016 4:43 pm
Dear MrEngman,
You are a master of raspberry kernel, as I see.
Today I upgraded my piradio software. I plan to use a new Wifi dongle also instead of old one. (The new one is RTL8192eu, lsusb command says this: 0bda:818b)
My current new kernel is: Linux piradio 4.4.11+ #891 Tue May 31 12:23:05 BST 2016 armv6l GNU/Linux
Have you got a compiled kernel for this wifi dongle? Can I get this from you?
Many thanks
Lesliewednesday
MrEngman
Tue May 31, 2016 7:13 pm
lesliewednesday wrote:Dear MrEngman,
Many thanks
Lesliewednesday
I wouldn't say I'm anywhere near a master but I do compile various wifi drivers.
Using my standard naming format you can download and install using the filename format
wget https://dl.dropboxusercontent.com/u/80256631/8192eu-kernel-build.tar.gz
tar xzf 8192eu-kernel-build.tar.gz
./install.sh
replacing kernel and build with the values from the command uname -a.
As an example for a Pi 2 B or 3 B, using raspbian 4.4.11-v7+ #886 use commands
wget https://dl.dropboxusercontent.com/u/80256631/8192eu-4.4.11-v7-886.tar.gz
tar xzf 8192eu-4.4.11-v7-886.tar.gz
./install.sh
For the Pi A/A+/B/B+/Zero the kernel version will not have -v7 like
wget https://dl.dropboxusercontent.com/u/80256631/8192eu-4.4.11-886.tar.gz
tar xzf 8192eu-4.4.11-886.tar.gz
./install.sh
In your case kernel = 4.4.11+ and build = 891 so replace the values in the commands above.
As an alternative I also have a script that can automatically download and install the driver. You can get the script using commands
wget https://dl.dropboxusercontent.com/u/80256631/install-wifi.tar.gz
tar xzf install-wifi.tar.gz
Run command ./install-wifi -h to get the infomation on how to use it.
MrEngman
lesliewednesday
Thu Jun 02, 2016 12:00 pm
Thanks a lot. I try them.
I did not mean to embarrass you...
Br,
lesliewednesday
NaTivE
Thu Jun 30, 2016 4:01 pm
i downloaded your script for automatic installation and got this output:
Your current kernel revision = 4.4.13-v7+
Your current kernel build    = #894
Checking for a wifi module to determine the driver to install.
Your wifi module is unrecognised.
**** Unable to identify your wifi module ****
The script only works for wifi modules using the rtl8188eu, rtl8192eu, rtl8812au, mt7601, mt7610 and mt7612 drivers.
Looking for your wifi module the script detected the following USB devices:-
If you are certain your module uses one of the drivers the script installs check the output of command
'lsusb' shows your wifi module. If lsusb shows your wifi module try running the script again. If the
script fails to detect your wifi module again the driver may need updating to add your module USB id.
If lsusb does not show your wifi module you will need to resolve that issue before the script can be
used to install the driver you need.
Can u help me pls?
MrEngman
Fri Jul 01, 2016 3:53 pm
NaTivE wrote:Hi,
Can u help me pls?
That version of the driver did not include the USB ID for your wifi. I have now updated it and you can download and install it using commands
wget https://dl.dropboxusercontent.com/u/80256631/8192eu-4.4.13-v7-894.tar.gz
tar xzf 8192eu-4.4.13-v7-894.tar.gz
./install.sh
The driver also has some additional updates so I hope it works OK for you. I have tried it with a different wifi adapter and it appears to be OK.
EDIT: I have updated the script to include the new TP-Link wifi adapters. You can download it using
Use command ./install-wifi -h to get details on using it.
MrEngman
ambrosa
Tue Jul 26, 2016 8:02 pm
Dear MrEngman,
thanks for your efforts.
Today I've bought a new TP-LINK 300Mbps Mini Wireless N USB Adapter TL-WN823N.
The sticker into bottom of the box says "Model: TL-WN823N(EU) Ver.2.0"
Surprise: as thread author, the usbID is
Bus 001 Device 004: ID 2357:0109
and my system doesn't recognized it (it's a Raspbian fresh installation into an old "model A" with 256MB RAM, kernel is "Linux myPi 4.4.13+ #894 Mon Jun 13 12:43:26 BST 2016 armv6l GNU/Linux")
I've downloaded your latest install-wifi and your 8192eu module load correctly and works fine :-)
The problem is: is there a way to update/notify the original Raspbian kernel source to add offcially for future the support for this new USB dongle ?
PS: it works fine with a 1300 mAh power supply
abcd567
Wed Aug 03, 2016 6:42 pm
Hi MrEngman
I tried to use your method on my 2 Pis. It succeeded with Pi B+ ( 4.4.13+ #894 ), but could not download driver for Pi Model 2 (4.1.19-v7+ #858).
Can you help me please?
~ $ uname -a
Linux raspberrypi 4.1.19-v7+ #858 SMP Tue Mar 15 15:56:00 GMT 2016 armv7l GNU/Linux
~ $ sudo wget https://dl.dropboxusercontent.com/u/802 ... 858.tar.gz
--2016-08-03 14:29:39-- https://dl.dropboxusercontent.com/u/802 ... 858.tar.gz
Resolving dl.dropboxusercontent.com (dl.dropboxusercontent.com)... 45.58.70.5
Connecting to dl.dropboxusercontent.com (dl.dropboxusercontent.com)|45.58.70.5|:443... connected.
HTTP request sent, awaiting response... 404 Not Found
2016-08-03 14:29:39 ERROR 404: Not Found.
MrEngman
Wed Aug 03, 2016 9:04 pm
abcd567 wrote:Hi MrEngman
~ $ uname -a
Check the filename you used in the wget command.
I would expect it to be 8192eu-4.1.19-v7-858.tar.gz, not 8192eu-4.4.19-v7-858.tar.gz.
Might work then. :lol: :lol: :lol:
MrEngman
abcd567
Thu Aug 04, 2016 1:31 am
MrEngman wrote: Check the filename you used in the wget command.
MrEngman
Oops! I made the typing mistake. With correct number (1 instead of 4) it downloaded!
Thanks a lot.
abcd567
Sun Aug 21, 2016 2:07 am
Hi MrEngMan!
I have recently burned Flightaware's PIaware3 image on microSD card of my RPi Model 2
(img downloaded from here: http://piaware.flightcdn.com/piaware-sd ... .4.img.zip)
I wanted to use my WiFi dongle RTL8192EU, but like Raspbian Jessie Lite, Piaware3 (based on Debian) also needs a driver.
pi@piaware:~$ uname -a
Linux piaware 4.4.0-1-rpi2 #1 SMP Debian 4.4.6-1+rpi14 (2016-05-05) armv7l GNU/Linux
Using above details, I tried to download the driver by method described by you above, but I am unable to download it.
The response to wget command is "ERROR 404: Not Found".
Need your help. Thanks
Best Regards,
abcd567
marian.bik
Tue Aug 23, 2016 7:54 pm
I have just purchased a TL-WN823N(EU) Ver. 2.0 and I can't seem to find the drivers. I have no experience compiling the driver myself so I would kindly ask if it is possible to post a tutorial on how to do it or provide a compiled version.
I do have the Linux version of the driver here https://db.tt/c19lc25s (downloaded from tp-link) if it helps.
Thank you!
Best regards,
Marian
MrEngman
Tue Aug 23, 2016 10:59 pm
marian.bik wrote:Hello,
Thank you!
Best regards,
Marian
I have compiled versions of various wifi drivers for Raspbian including the driver for the TL-WN823N v2.
I have a script which will automatically determine which driver your wifi uses and which version of the kernel you are using and then download and install the version of driver needed. You can download the script using commands
Run command ./install-wifi -h to see details on how to use the script.
MrEngman
janrasp
Wed Aug 24, 2016 7:14 am
thank you, this script worked like a charm for my TL-WN823N
marian.bik
Wed Aug 24, 2016 8:33 am
Thank you MrEngman! I tried that already, however it is not available for my kernel version. I am using OSCM and I see that their July's release uses kernel version 4.4.16. Any chance of having a driver compiled for that version?
I also tried installing an older version of OSMC with kernel 4.4.11 #1 (if I remember correctly, as I don't have access at the Pi right now) and I got the same error that there is no driver for my kernel.
Marian
marian.bik
Wed Aug 24, 2016 4:14 pm
Hello MrEngman,
I have tried installing with no succes. I get the following message
./install-wifi 8192eu
Your current kernel revision = 4.4.8-3-osmc+
Your current kernel build    = #1
Checking for a new 8192eu wifi driver module for your current kernel.
A driver does not yet exist for this update.
I have the following kernel
Linux osmc-Waldo 4.4.8-3-osmc #1 SMP PREEMPT Sun May 1 18:57:43 UTC 2016 armv7l GNU/Linux
I then did an update of the OSMC and run the commands again with same result. Output is
Your current kernel revision = 4.4.16-1-osmc+
Any tips? Thank you for your help.
MrEngman
Fri Aug 26, 2016 6:48 pm
marian.bik wrote:Hello MrEngman,
Sorry for the delay in responding.
As I mentioned in my reply to your previous post the script is for installing drivers for Raspbian, wheezy or Jessie, which are the drivers I normally compile and won't install drivers for other OSes. Compiling drivers for Raspbian is so easy compared with any of the other OSes that are around. All the data needed is so easily accessible. Trying to find the source and other files to make compiling straight forward for other OSes is such a problem.
I have compiled drivers for OSMC a few times in the past so I'll see what I can come up with. Just need to find all the data necessary.
MrEngman
MrEngman
Fri Aug 26, 2016 11:42 pm
marian.bik wrote:Thank you MrEngman! I tried that already, however it is not available for my kernel version. I am using OSCM and I see that their July's release uses kernel version 4.4.16. Any chance of having a driver compiled for that version?
Marian
Hi Marian
I have just got OSMC 4.4.16-1-osmc running with the 8192eu driver on a Pi 2 B. I am connected to my Pi from my laptop using SSH via the wifi. Seems to be working OK.
For a Pi 2 B or 3 B you can download and install the driver using commands
wget https://dl.dropboxusercontent.com/u/80256631/8192eu-rbp2-4.4.16-1-osmc.tar.gz
tar xzf 8192eu-rbp2-4.4.16-1-osmc.tar.gz
./install.sh
MrEngman
marian.bik
Sat Aug 27, 2016 8:42 am
Thank you very much MrEngman! Everything works great.
danm14
Thu Sep 01, 2016 4:41 pm
Hi MrEngman
Would it be possible for you to compile a version of this driver for OSMC (same kernel and build as the previous poster) for the original Raspberry Pi?
Daniel
MotS
Fri Sep 02, 2016 5:26 am
Dear MrEngman,
i used your compiled driver and it works fine, but i'm interested in how to compile the driver on my own.
Can you present me a guide?
My problem is that i don't have the linux headers for my rasberian kernel version 4.4.13-v7+
Thank you
MrEngman
Sun Sep 04, 2016 7:50 pm
danm14 wrote:Hi MrEngman
Daniel
Hi danm14,
I have finally been able to get round to compiling the 8192eu driver for osmc rbp1 - 4.4.16-1-osmc. Currently on a Pi B+ but should be OK for older versions of the Pi as well.
You can download and install it using commands
wget https://dl.dropboxusercontent.com/u/80256631/8192eu-rbp1-4.4.16-1-osmc.tar.gz
tar xzf 8192eu-rbp1-4.4.16-1-osmc.tar.gz
./install.sh
After installing the driver you will need to reboot your Pi.
MrEngman
Castle1310
Sun Oct 02, 2016 12:51 pm
I have been trying to complile a version of the driver for PiCore (PiCoreplayer), but to no avail.
I can get it to work on plain Rasbian but TinyCore is something else and I would apreciate some help :)
Thx in advance!!
Grtz,
Jelle
Return to “Raspberry Pi OS”
