jessismerkovitz
cat w1_slave No File or Directory
Tue May 17, 2016 5:32 pm
Hello.
I am in the process of getting my temperature sensor all set up and working on my Pi etc.
I am using DS18B20 Temp Sensor#374
So far I am only at the code set up for now.
Iv'e executed the following code:
First adding in
dtoverlay=w1-gpio
Into
sudo nano /boot/config.txt
then I have executed:
sudo modprobe w1-gpio
sudo modprobe w1-therm
cd /sys/bus/w1/devices
ls
cd 28-xxxx (changed ' xxxx'  to match what serial number pops up eg. 28-000003cee4ca)
Then successfully I get into the cd...
Now When executing
cat w1_slave
I receive back:
No such file or directory...
(That error)
Can anyone guide me in what I am doing wrong or anything?
Jess Smerkovitz
svedr
Re: cat w1_slave No File or Directory
Wed May 18, 2016 5:21 am
Run command from terminal
Sudo modprobe w1-gpio
Run "cat w1_slave" inside folder /sys/bus/w1/devices/SERIAL OF PROBE
jessismerkovitz
Wed May 18, 2016 5:30 am
When you say serial of probe you mean the actual serial number right ?
Now I can't even get the serial number when I run
ls[/code
Once I'm in those cds (/sys/...)
But before, when I was receiving a serial number and I was in all those cds and running the cat .... Code it would give me the no file or directory error
Jess Smerkovitz
Wed May 18, 2016 5:42 am
You don't need the modprobe commands, just the "dtoverlay=w1-gpio" line in /boot/config.txt.
If you don't see the probes in /sys/bus/w1/devices, then it is probably that they aren't connected correctly.
Can you show a picture or diagram of your wiring?
You should get something like this:
pi@raspi2 ~ $ cd /sys/bus/w1/devices
pi@raspi2 /sys/bus/w1/devices $ ls
28-00044a1f53ff  28-00044c7a5aff  w1_bus_master1
pi@raspi2 /sys/bus/w1/devices $ cd 28-00044a1f53ff
pi@raspi2 /sys/bus/w1/devices/28-00044a1f53ff $ cat w1_slave
25 01 55 00 7f ff 0c 0c 08 : crc=08 YES
25 01 55 00 7f ff 0c 0c 08 t=18312
muralidharanv
Sun Apr 28, 2019 4:16 pm
Dear All,
i have followed below commands but getting error "cat w1_slave No File or Directory".
Board:
1. raspberry pi 3 B+
2. DS18B20 Water Proof Temperature Sensor Probe
3.1 x 4.7k Ω resistor
1. sudo nano /boot/config.txt
2. dtoverlay=w1-gpio
3. sudo reboot
4. sudo modprobe w1-gpio
5. cd /sys/bus/w1/devices
6. pi@raspberrypi:/sys/bus/w1/devices $ ls
00-200000000000 00-600000000000 00-a00000000000 w1_bus_master1
7. pi@raspberrypi:/sys/bus/w1/devices $ cd 00-100000000000
pi@raspberrypi:/sys/bus/w1/devices/00-100000000000 $ cat w1_slave
cat: w1_slave: No such file or directory
Kindly help me resolve the issue.
Regards,
Muralidharan.V
[email protected]
pcmanbob
Mon Apr 29, 2019 7:24 am
Your sensor is not being found that's why you only have devices starting with 00 , are you sure you have it connected up correctly ?
Post some pictures of you setup so we can check for you.
Mon Apr 29, 2019 7:53 am
By following step 2 (the recommended way), you don't need step 4. The modules (drivers) will be loaded automatically.
That isn't the cause of your problems, but is just an unnecessary step.
Unreadable squiggle
pcmanbob
Mon Apr 29, 2019 3:39 pm
Also make sure you are connecting the data wire to the correct gpio pin ( gpio4, board pin 7 is the default ).
arslankhawar112
Tue Dec 24, 2019 7:12 pm
00-080000000000 00-700000000000 00-f00000000000 w1_bus_master1
these are the directories showing .
and when i write cat w1_slave
No such file or directory error is showing .
kindly any one help me it will be a big help for me in my finak year project.!
Thanks in advance ....!!!!
pcmanbob
Tue Dec 24, 2019 9:13 pm
Hi.
Check your DS18B20 sensors are connected correctly , the results you are seeing suggest your sensors are not connected correctly.
there are lots of examples on line
but here is the basics
arslankhawar112
Wed Dec 25, 2019 11:03 am
Thanks for replying...!!!
I have followed the steps and also change the sensor but again directories are not starting with 28-xxxx.
these are the direcetories showing
00-380000000000 00-b80000000000 w1_bus_master1
and here is the code that i'm using
import os
import glob
import time
os.system('modprobe w1-gpio')
os.system('modprobe w1-therm')
base_dir = '/sys/bus/w1/devices/'
device_folder = glob.glob(base_dir + '28*')[0]
device_file = device_folder + '/w1_slave'
def read_temp_raw():
    f = open(device_file, 'r')
    lines = f.readlines()
    f.close()
    return lines
def read_temp():
    lines = read_temp_raw()
    while lines[0].strip()[-3:] != 'YES':
        time.sleep(0.2)
    equals_pos = lines[1].find('t=')
    if equals_pos != -1:
        temp_string = lines[1][equals_pos+2:]
        temp_c = float(temp_string) / 1000.0
        temp_f = temp_c * 9.0 / 5.0 + 32.0
        return temp_c, temp_f
while True:
	print(read_temp())
	time.sleep(1)
(mod edit to add code tags)
Wed Dec 25, 2019 12:42 pm
Ok, please add Code tags around your code to make it more readable (there's a code button at the top of the post edit screen to do that for you).
You shouldn't need the two "modprobe" lines if you have enabled the 1-wire interface in the configuration program.
If you get entries starting with "00-" it almost certainly means your sensors are not wired up correctly. Double check your wiring.
Unreadable squiggle
pcmanbob
Wed Dec 25, 2019 3:42 pm
Please post pictures of your wiring making sure to show both the connections to the sensors and the pi, then we might be able to spot you problem.
arslankhawar112
Wed Dec 25, 2019 5:40 pm
here is the sensor i' using
here is the sensor
arslankhawar112
Wed Dec 25, 2019 5:48 pm
And using pin 7 of pi zero w
and 5v is given to sensor from power supply
pcmanbob
Wed Dec 25, 2019 7:18 pm
Did you not look at the diagram I posted, you should be powering the sensor from the 3.3V pin as you are using the same supply for the pull up, connecting 5V to the pi gpio pins can and will damage your pi.
arslankhawar112
Wed Dec 25, 2019 7:30 pm
Thnaks for reply
and follow the steps you ask me to but the error is still same . :'(
Regards !
Arslan
pcmanbob
Wed Dec 25, 2019 9:22 pm
Looking at you pictures I only see one cable connected to the pi
Can you post a picture or pictures showing a bit more of the pi / sensors so we can see a bit more of your wiring.
