I'm trying to get WiFi working on Raspberry Pi. I've installed wicd-curses.
Once I set the network details such as WPA2 passphrase, I press Shift-C to connect.
I see some status messages at the bottom, it usually makes it to "Authenticating" or "Obtaining IP address" then just falls back to "Not Connected".
I've tried three different WiFi adapters, two SD cards, and a Raspberry Pi Model A and Model B.
I have another Raspberry Pi Model B that I set up about a year ago running wicd-curses and this has always been stable.
The only thing I can think of is something that changed in the Raspbian distro in the past year.
Does anyone have any ideas?
Are there any logs I can provide?
Cannot get wicd-curses to connect to WiFi
Re: Cannot get wind-curses to connect to WiFi
Take a look at the diagnostic steps in my post: http://captainbodgit.blogspot.co.uk/201 ... ry-pi.htmlextest wrote:...Does anyone have any ideas?
I had similar problems once ... in my case it was because I tried to connect to wifi with the ethernet still connected ... there is some setting in wicd to prefer cable connection over wifi ... and this was preventing wifi connection to complete...
And sometimes I just forgot to save the wifi settings (I guess F10)
regards,
MikeDK
EDIT: when you do a "dmesg" after such a connection attempt, do you see any wifi related errors ...? I also had problems once because the firmware file of the wlan adapter could not be found
regards,
MikeDK
Re: Cannot get wicd-curses to connect to WiFi
Figured out what the problem was...
Sometime within the last year, Raspbian started including dhcpcd.
You cannot run multiple network managers at the same time.
The steps to correctly install and configure wicd-curses on Raspbian are:
- 1) sudo apt-get install wicd-curses
- 2) sudo systemctl disable dhcpcd
- 3) sudo /etc/init.d/dhcpcd stop
- 4) sudo wicd-curses
Thanks for that! I was wondering why it would get a DHCP address from the server, and then not connect...
Cheers extest for the post
Bj
Bj
tonyjobson
Thanks - This fixed the problems I've been having for a week!
