I'm having some trouble getting my python based gpio audio player to run on boot. It's a short piece of that plays a single wave file to its end then waits for another button press to trigger it again.
It works perfectly fine in Idle3 in the GUI and also when I run via python in terminal.
Issue is, I want to run this via CRON on boot. When I call the program to run by setting it as an executable via chmod 755 etc, I get an error as follows:
The line in code is the usual:pygame.error: Couldn't set hardware audio parameters: Success
pygame.mixer.init(frequency=44100, size=16, channels=2, buffer=512)
Full code as follows:
#!/usr/bin/env python3
# Pi GPIO Music player Single file
# By Andrew
# 1st September 2016
# Version 1.0
# ____________________________Notes_________________________________
# 1 gpi pin triggers playback of one file in a single instance
# pressing another gpi pin to ground stops playback
# player waits for pin 1 to go low and will only trigger once until
# completion.
# __________________________________________________________________
# Imports
from gpiozero import Button
from signal import pause
import pygame.mixer
pygame.mixer.pre_init(44100, 16, 2, 512)
from pygame.mixer import Sound
global busyCh
# Setup
def setup():
pygame.mixer.init()
global button
global button2
button = Button(2)# Define button 1
button2 = Button(3) # Define button 2
busyCh = 0
pygame.mixer.music.load('files/1.wav') #load the file
pygame.mixer.music.set_volume(0.4) # Set the volume. 1.0 distorts
# Loop
def loop():
# print("main loop")
button.when_pressed = onPress #pygame.mixer.music.play
def onPress():
if busyCh==0:
print("playing file")
pygame.mixer.music.play()
# Main
setup()
while True:
busyCh = pygame.mixer.music.get_busy()
# print(busyCh)
button2.when_pressed = pygame.mixer.music.stop
if busyCh==0:
loop()
I also have a related issue of which the above is a step in the process of an attempted fix. I did get the above to run by removing the parameters of mixer.init which I assume is putting in a lengthy buffer. This produces a working program but every few button presses, the file doesn't play and it also takes a bit of time for the file to start playing. The file needs to play almost immediately after the button press as it will be tied in with other automation from a separate system.
Many thanks for any tips / advice. I'm quite new to python so if there's any better methods, I'm very open to suggestion.
All my project needs to do is play a file once on its own and wait for another button press to make it go again.
All the best.
Andrew
