foul_owl
[Solved] Mouse lag
Wed Sep 21, 2016 11:52 pm
Hi folks,
Brand new Tecknet wireless mouse. It works fine on my Debian 8 x86 desktop, but lags by about 2 seconds or so on my RPi 2b.
What could be going on with the rpi that would cause this?
wh7qq
Re: Mouse lag
Wed Sep 21, 2016 11:58 pm
Are you using any USB 3.0 accessories? They can interfere with your keyboard/mouse reciever even if plugged into a USB 2.0 port.
foul_owl
Re: Mouse lag
Thu Sep 22, 2016 9:35 pm
No USB 3.0.
I actually found a fix, which is to append:
usbhid.mousepoll=0
to /boot/cmdline.txt
I wonder why that isn't default?
gkreidl
Re: Mouse lag
Fri Sep 23, 2016 5:48 am
foul_owl wrote:No USB 3.0.
usbhid.mousepoll=0
Some time ago the default polling rate for mouse/keyboard was reduced, which was a very sensible decision (reduces processor work).
This didn't work for some USB wireless keyboard/mouse combo chips. Then the optional boot option was added to fix this.
BTW, you can also experiment with other values, if your mouse wheel is not working correctly after adding this option. I'm using "usbhid.mousepoll=4"
Minimal Kiosk Browser (kweb)
wh7qq
Re: Mouse lag
Fri Sep 23, 2016 4:46 pm
Good call. I have had a similar problem with a wireless Anker keyboard/mouse combo. Trying the "0" setting, it seems to remove the irritating typing lag I experienced. I had just chocked it up to the slower characteristics of the processor.
foul_owl
Re: Mouse lag
Mon Nov 28, 2016 4:31 am
Well...I thought it was fixed.
The other day my system didn't boot, so I wiped it and installed a fresh image.
Now the mouse is back to being super laggy.
I added that line back in, but the mouse is still just as laggy.
Any ideas?
gkreidl
Re: Mouse lag
Mon Nov 28, 2016 7:26 am
foul_owl wrote:Well...I thought it was fixed.
Any ideas?
Check you cmdline.txt. It may not contain any line breaks.
foul_owl
Re: Mouse lag
Tue Jan 03, 2017 8:25 am
My mistake! (And I forgot to update)
I dumped that line into config.txt, not cmdline.txt!
Sorry about that!
maxfaber
Re: [Solved] Mouse lag
Mon Apr 17, 2017 7:14 am
Worked for me as well, thanks! For the people searching: worked for wireless mouse (touchpad) / keyboard ZW-51010
YMita
Thu Aug 03, 2017 3:11 pm
Thank you, al!
First I do the very simple, but bad mistake to fix this problem.
I edited the cmdline.txt, but add new line after already line, and wrote usbhid.mousepoll=0.
It's not work.
Next, I add new line before already line. It's not boot! Need to fix from start up with continuous pushing SHIFT key.
At last, add usbhid.mousepoll=0 to the already line. It's work perfect!
