HermannSW
Pi Zero works with 3 USB cameras and ethernet
Mon Sep 26, 2016 6:17 pm
I tried cheap 3-port USB hubs with RJ45 before, but they did not work.
RJ45 did work, but Pi Zero froze when connecting something to USB.
Then I did read "We've tested heaps of these adapters and this one is by far the best!" on pimoroni.com (where I bought two of my 4 Pi Zeros) for their "Three Port USB Hub with Ethernet - microB connector":
https://shop.pimoroni.com/products/thre ... -connector
Although that one costed £10 plus £4 shipping I did buy it, it arrived 5 days after shipping (over the weekend) and just works. I did connect 3 cheap 2$ USB cameras (a fake 5M camera, but really good 0.3M, see report) to it and ethernet:
After identifying the Pi Zero IP address with "nmap -sn 192.168.178.1/24" I did "ssh -X pi@192.168.178.124" with X11 forwarding. Started "eog X.jpg &" with X in {4,5,6} to view the image taken by the USB camera "/dev/videoY" with Y in {0,1,2}. The images get shown on Laptop by X11 forwarding and get updated when new picture gets taken by "fswebcam -d /dev/videoY -r 320x240 X.jpg". The photos of the cameras do show the other camera(s) [right click for bigger screenshot]:
Summary:
£14 is not cheap, but a good price for quick delivery and working well.
Hermann.
HermannSW
Re: Pi Zero works with 3 USB cameras and ethernet
Mon Sep 26, 2016 7:10 pm
I remembered on how to connect to Pi Zero via UART:
viewtopic.php?p=1021437#p1021437
So this is a method to use a single USB camera with Pi Zero and control it over UART:
This time I had to select 38400 speed in minicom, then it worked perfectly:
[  297.110134][  297.320975] usb 1-1: Product: USB2.0 PC CAMERA
[  297.320990] usb 1-1: Manufacturer: Generic
[  297.394042] media: Linux media interface: v0.10
[  297.420642] Linux video capture interface: v2.00
[  297.463119] uvcvideo: Found UVC 1.00 device USB2.0 PC CAMERA (1908:2311)
[  297.465764] input: USB2.0 PC CAMERA as /devices/platform/soc/20980000.usb/us0
[  297.468396] usbcore: registered new interface driver uvcvideo
[  297.468423] USB Video Class driver (1.1.1)
pi@raspberrypi01:~$ fswebcam 7.jpg
--- Opening /dev/video0...
Trying source module v4l2...
/dev/video0 opened.
No input was specified, using the first.
Adjusting resolution from 384x288 to 352x288.
--- Capturing frame...
Captured frame in 0.00 seconds.
--- Processing captured image...
Writing JPEG image to '7.jpg'.
pi@raspberrypi01:~$
Now the problem is how to the taken photo off the Pi Zero over the UART connection.
I know an answer is to use PPP over minicom, have not tried that yet:
https://www.ibiblio.org/pub/packages/in ... er-minicom
Hermann.
HermannSW
Mon Sep 26, 2016 10:56 pm
I did this with UART connection, but it is the same with three port USB plus ethernet hub.
I connected an ili9341 320x240 LCD to above setup.
Then I did hold the camera high above the scene and took this 320x240 photo and displayed it on the LCD:
This is higher resolution photo, right click to see more details:
Here are the steps I did:
1) Take the photo:
pi@raspberrypi01:~$ fswebcam --png 0 -r 320x240 7.png
/dev/video0 opened.
Setting output format to PNG, quality 0
Writing PNG image to '7.png'.
pi@raspberrypi01:~$
2) convert .png to raw rgb565 image format of framebuffer
pi@raspberrypi01:~$ avconv -vcodec png -i 7.png -vcodec rawvideo -f rawvideo -pi
x_fmt rgb565 7.raw
avconv version 11.7-6:11.7-1~deb8u1+rpi1, Copyright (c) 2000-2016 the Libav deve
lopers
  built on Jun 17 2016 02:13:49 with gcc 4.9.2 (Raspbian 4.9.2-10)
Input #0, image2, from '7.png':
  Duration: 00:00:00.04, start: 0.000000, bitrate: N/A
    Stream #0.0: Video: png, rgb24, 320x240, 25 tbn
File '7.raw' already exists. Overwrite ? [y/N] y
Output #0, rawvideo, to '7.raw':
  Metadata:
    encoder         : Lavf56.1.0
    Stream #0.0: Video: rawvideo, rgb565le, 320x240, q=2-31, 200 kb/s, 25 tbn, 2
5 tbc
    Metadata:
      encoder         : Lavc56.1.0 rawvideo
Stream mapping:
  Stream #0:0 -> #0:0 (png (native) -> rawvideo (native))
Press ctrl-c to stop encoding
frame=    1 fps=  0 q=0.0 Lsize=     150kB time=10000000000.00 bitrate=   0.0kbi
ts/s
video:150kB audio:0kB other streams:0kB global headers:0kB muxing overhead: 0.00
0000%
pi@raspberrypi01:~$
3) activate framebuffer (needed once only)
pi@raspberrypi01:~$ sudo modprobe fbtft_device name=rpi-display gpios=reset:23,d
c:24,led:18 rotate=90
pi@raspberrypi01:~$
4) copy raw image to framebuffer for displaying
pi@raspberrypi01:~$ cat 7.raw > /dev/fb1
pi@raspberrypi01:~$
Hermann.
P.S: Instead of micro USB to USB cable a 0.31$ OTG converter could be used as well:
https://www.aliexpress.com/item/Android ... 37793.html
HermannSW
Sat Nov 04, 2017 3:40 pm
I used the Pimoroni "Three Port USB Hub with Ethernet - microB connector" for more than a year now without any issues. Only today after having installed a new cable modem I realized that it allows for 10/100Mbps. This is from laptop:
I used same ethernet cable with Pi Zero, and same speedtest-cli:
pi@raspberrypi:~ $ speedtest-cli
Testing from Kabel BW (46.223.20.147)...
Selecting best server based on ping...
Hosted by PfalzKom (Ludwigshafen) [20.29 km]: 35.818 ms
Testing download speed................................................................................
Download: 64.66 Mbit/s
Testing upload speed....................................................................................................
Upload: 19.62 Mbit/s
pi@raspberrypi:~ $
Anyway, 64Mbps sounds like a nice value for Pi Zero.
