chinaguy
Help installing astrill-setup-linux.deb
Tue Sep 27, 2016 7:51 am
I am trying to install (Debian astrill-setup-Linux.deb file) Astrill VPN onto my RP3. I have copied the file and tried the straight forward double click self install option with the following error "Failed to install file".
I then tried the sudo dpkg -I /home/pi/downloads/astrill-setup-Linux.deb
But again failed.
Anybody know how to install ASTRILL VPN onto a RP3 running Raspbian.
My other computer is a VIC20.
Re: Help installing astrill-setup-linux.deb
Tue Sep 27, 2016 8:21 am
chinaguy wrote:I am trying to install (Debian astrill-setup-Linux.deb file) Astrill VPN onto my RP3. I have copied the file and tried the straight forward double click self install option with the following error "Failed to install file".
But again failed.
According to the Astrill Download page the Linux download is for x86 CPU Architecture...
......the Raspberry Pi has ARM CPU Architecture !!!!
pinatl
Sat Feb 11, 2017 11:08 am
there is no astrill client provided by Astrill for Raspberry. However you can install openvpn , get the certificate from you astrill account and good to go.
sudo apt-get install openvpn
download a certificate for OpenVPN with configuration files (from member page VPN services)
sudo openvpn --config 01-USA-Dallas-1.ovpn (for example if you want to use the server in Dallas)
Return to “Raspberry Pi OS”
