mymx
/dev/video missing,while use LEDE(openwrt).
Mon Oct 10, 2016 2:45 am
I cannot find /dev/video device while use LEDE(openwrt) system.
the output from dmesg show "bcm2835-v4l2: error -1 while loading driver".
running modprobe bcm2835-v4l2 as follow.
[code]
root@lede:~# modprobe bcm2835-v4l2
[ 4029.624122] bcm2835-v4l2: error -1 while loading driver
1 module could not be probed
- bcm2835-v4l2
[/code]
while use raspbian just add "bcm2835-v4l2" to /etc/modules it works fine.I can fine "/dev/video" after reboot.
but It doesn't work on the LEDE。
it's someone can help me?thank you!
munjeni
Re: /dev/video missing,while use LEDE(openwrt).
Sat Sep 08, 2018 12:05 pm
Extract two files (start-x.elf and fixup-x.dat from NOOBS desktop and simple replace start.elf and fixup.dat with these two files, camera will work! Hope this help! I searched whole day for solution for Lede, found nothing on google search, so started researching and found solution byself.
Return to “Camera board”
